10-03-2007, 09:24 PM | #1 |
Sierra Grande Club
Crank pulleys.
What are you running for crank pulleys? The one on my truck was added after the PO put power steering on. it’s not inline with the water pump & alt.
I went to the wrecking yard looking for something but didn’t find anything. Anyone have suggestions? It needs to be a 3 grove to work. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
10-04-2007, 10:06 AM | #2 |
Re: Crank pulleys.
I think Summit sells crank pulley shims.
10-04-2007, 10:23 AM | #3 | |
OLD FART(I GUESS)
Re: Crank pulleys.
1967 Shorty Stepside 1967 Shorty Fleet 1967 3/4 Fleet LB 1972 LB Fleet ....RAP IS TO MUSIC WHAT ETCH A SKETCH IS TO ART.... |
10-04-2007, 10:38 AM | #4 |
Re: Crank pulleys.
^Yep. I ran into this problem when adding my vintage air set-up.
Basically, the groove closest to the balancer should be AGAINST the balancer if you have a short water pump set up (which is what you would want if you have factory power steering). If your pulley groove closest to the balancer is about an 1" away from the balancer, it's for a long water pump. This is a pic of a long water pump set up. The second is hard to see, but my new SWP set up, the pulley groove is against the balancer.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 10-04-2007 at 10:40 AM. |
10-04-2007, 10:43 AM | #5 |
Re: Crank pulleys.
Also, the third groove is kind of an add on. Trucks that came with the two groove pulley had the power steering pulling is an add on that goes over and inside the two groove pully (at least the ones I've seen have).
You're probably having a hard time finding the pulley at a yard because all 73+ trucks used a long water pump. You'd need to find an original swp set up.... or go to Jegs or ebay...
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 10-04-2007 at 10:46 AM. |
10-04-2007, 01:08 PM | #6 | |
Re: Crank pulleys.
Scan the parts board. People jump fast on AC brackets when somebody posts that they are parting an AC truck. After that dust settles ask if you can buy the crank pulleys. You may as well get the waterpump pulley too. That way you know you got a matched set.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
10-04-2007, 01:08 PM | #7 |
Sierra Grande Club
Re: Crank pulleys.
It’s a short water pump & the pulley is against the Harmonic balancer. The first grove needs to be 5/8inch from the face of the harmonic balancer to match the water pump pulley.
Can someone double check this measurement for me? If I shim this out I’m concerned that it will throw off my power steering alignment. I’ll get a picture up tonight. Thanks. s/t
10-26-2007, 05:53 AM | #8 |
Re: Crank pulleys.
67CRN is right....the one I have has two pulleys, then a spacer and then a third pulley. That said my alt is off a bit and it makes it squeal...gotta fix that someday.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
10-04-2007, 01:15 PM | #9 |
Re: Crank pulleys.
Is it possible you have the wrong water pump pulley? Does it look like the one in my second pic?
Does your truck have A/C? Is the upper pulley single groove or double? Is your power steering off a 73+ truck or 68-72?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 10-04-2007 at 01:15 PM. |
10-04-2007, 03:31 PM | #10 |
Sierra Grande Club
Re: Crank pulleys.
It’s a single pulley water pump pulley and it seems original. I’m sure the only thing that was changed was the bottom pulley, to accommodate the power steering. I don’t know what the power steering is off of, but the brackets that were used for the power steering pump were incorrect. I have the correct ones now. I plan on replacing the pump before I get this on the road. I can specify for a correct pump then. What should I ask for? (The engine is out at the moment)
s/t
10-04-2007, 03:43 PM | #11 |
Re: Crank pulleys.
Not the best pic but I used all the 76 and newer brackets and accesorys and everything lined up even being bolted to the older style harmonic damper
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap |
10-04-2007, 03:45 PM | #12 |
Re: Crank pulleys.
It sounds like the crank pulley was designed for use with the long style pump
If you dont mind paying for shipping I'll give you my original pulleys (what I have left)
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap Last edited by Scott68-93-97; 10-04-2007 at 03:46 PM. |
10-04-2007, 04:17 PM | #13 | |
Sierra Grande Club
Re: Crank pulleys.
Thanks for the offer Scott, I don’t mind paying and may just take you up on the offer. But can you measure from your Harmonic Balancer to the middle of your first belt? BTW- I thought the inner most pulley is for the alternator? Maybe this has something to do with your alternator being on the Passenger side? s/t
10-04-2007, 04:41 PM | #14 |
Re: Crank pulleys.
I am in the same boat. I posted about stock pulley set up. I am probably going to the yard soon to scrounge stuff up. Could end up going Summit.
10-05-2007, 06:54 AM | #15 |
Sierra Grande Club
Re: Crank pulleys.
thanks, Matt that is exactly what I need. I have some pictures of my old pulley system, but it was nothing near correct. I have all the
original brackets now. s/t
10-05-2007, 10:24 AM | #16 |
Re: Crank pulleys.
Glad I could help. If you need any more help or any parts, let me know. I've done been through this battle, so I'm willing to help in any way possible.
10-05-2007, 11:05 AM | #17 | |
Sierra Grande Club
Re: Crank pulleys.
This would help me determine if the water pump pulley is correct. s/t
10-05-2007, 11:45 AM | #18 |
Re: Crank pulleys.
Just curious but what kind of belts are those?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
10-05-2007, 11:47 AM | #19 |
Re: Crank pulleys.
I don't remember the name, but they look just like mine and I got them from Advance
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 10-05-2007 at 11:47 AM. |
10-05-2007, 01:25 PM | #20 |
Re: Crank pulleys.
S/T here's my setup now. It should help to see what you need. I have a 2-groove wp pulley for a short water pump and a 3-groove crank pulley. My old setup in the pictures above were taken before the restoration. I had(I believe) a 2-groove wp pulley and a 2-groove crank pulley. The crank pulley had two peices. The crank pulley that turned the Water pump and alt. was directly aginst the balancer. The second piece of the crank pulley was basically an add on extension to work the power steering. Your crank pulley has three grooves. The one directly against the balancer should drive the wp and alt. The middle groove will be for A/C if you have it. The outside should drive the p/s.
I wouldn't be able to tell if you have the correct wp pulley just by seeing it. I'll try to check my old pulley in a little while to get dimensions for you. I'll try to see how long and deep the wp pulley should be. The oulley is at my dad's place, so I'll have to check it in a few minutes. Meanwhile, here some of my current setup. They are Dayco TOP COG. They are the only kind of V-belt I will buy. Don't buy cheap stuff. You get what you pay for. My brother learned this lesson with his truck. He went to Auto Zone and told them he needed new belts. They automatically gave him the cheap ones. They haven't stopped squealing after a year.
10-05-2007, 03:53 PM | #21 | |
Sierra Grande Club
Re: Crank pulleys.
s/t
10-06-2007, 08:42 AM | #22 | ||
Re: Crank pulleys.
10-06-2007, 10:17 AM | #23 | |
Sierra Grande Club
Re: Crank pulleys.
If you could put a tape measure against the face of your harmonic B, and tell me what the measurement is to the center of the first belt. (I need 5/8) in one of your pictures it look like it could be...but a mounted measurement will be best. I also checked my water pump pulley. It was within a 1/16 of your measurement. So I think it's ok. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. Last edited by Sport/Truck; 10-06-2007 at 10:20 AM. Reason: grammar |
10-05-2007, 01:33 PM | #24 |
Re: Crank pulleys.
You can also check out Alan Grove. They have all dimensions listed on their site so you can determine what you need.
10-05-2007, 03:42 PM | #25 |
Re: Crank pulleys.
OK my wp pulley dimensions are:
2 13/16" tall 5 13/16" wide GM part #3995646 AH Crank pulley dimensions are: 2 1/16" tall with ps pulley (this dimension will only be about 2" if installed to balancer) 6 3/4" wide Single crank pulley for wp and alt part # 3755820 BC ps pulley part # 3751232 BB
