need some help
i just got my first standard hot rod its a saginaw 4 spd and was wondering if someone could help me out with this question how do u service the tranny (drain hole and fill) never serviced a standard always had automatics if someone could help thanks
![]() Join Date: Sep 2005
Re: need some help
well u can pullt he driveshaft out and jack the front up it will drain that way for the most part, then refill till it comes out the hole
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 01-20-2008 at 06:52 AM. |
Fabricate till you "puke"
Re: need some help
Try pulling the lowest bolt for the tail housing.....IIRC, the hole goes through the main case). Jack er up as posted above, & just let it drip overnite. refilll,(you will find a plug on the pass side,about 1/2way up the maincase). It just needs to be @ the bottom edge of the threads ,with the truck back down on the wheels......or slightly dripping out the hole as stated above. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
I'M TRUCK CRAZY!
Re: need some help
You could get a siphon pump at the auto parts store and pump it out too. Threw the fill hole.
its all about the +6 inches
Re: need some help
Re: need some help
thanks guys this place really helps YALL ROCK
