03-07-2008, 05:30 PM | #1 |
GEARHEAD
Siezed engine problem
I have a Jimmy with a siezed engine. I'm working on it's replacement right now, but then realized my problem. How to I get the torque converter bolts out to remove the tranny on an engine I can't rotate? I didn't want to pull the tranny and transfer case with it, just wanted to swap the motors, but that may not be possible. Will the tranny pull back far enough to reach them? Can I turn the transmission enough to get the torque converter off the tranny, then take it off the flywheel? Any ideas will help at this point.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
03-07-2008, 05:39 PM | #2 |
Re: Siezed engine problem
Sing along now, the crankshaft is connected to the flexplate, the flexplate is connected to the torque converter, the torque converter is connected to the input shaft.........
Unbolt the transmission from the engine and seperate. The torque converter will remain on the flexplate. Any oil in the converter will come out with the input shaft, so be careful not to take a bath.
trailers are for boats |
03-07-2008, 06:01 PM | #3 |
It may be better to just pull the engine tranny out together and unbolt the tranny then pull it off the TC. Like 69rut said, the converter will stay with the flywheel but you will have access to the rest of the bolts. BTW, how did the engine sieze?
Mike 68 C10 LWB midnight blue metallic 307ci, 700R4, HEI front discs, leaf spring rear tilt steering wheel, stock ride height, rally wheels, 2007 Dodge Charger(Hemi) |
03-07-2008, 06:58 PM | #4 |
pull engine and if its seized that you cant turn it just take the pan off and pull the crank out with flexplate and converter attached then you'll be able to get to all the bolts on the converter
03-07-2008, 07:06 PM | #5 |
Weekend Warrior
Will the motor turn @ all??? or is it solid? If you can get it to turn try turning it as far one way as possible, and then back the other way. Sometimes when a rod breaks and jams somewhere you can do the opposite rotation thing and get enough rotation to get the bolts. If the motor is just seized up solid then:
Probably have to pull the converter with the motor. Be sure to have a couple buckets under it and lots of old towels and speedy dry handy. This is a great way to make a mess of your shop floor.
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered Last edited by arkracing; 03-07-2008 at 07:07 PM. |
03-07-2008, 09:52 PM | #6 |
The Older Generation
If you take the transmission housing bolts out and pull the engine you shouldn't have any problem getting the torque converter bolts out... LockDoc
03-07-2008, 10:34 PM | #7 |
i wonder what type of converters you've been woring on the ones ive seen require turning engine over to access ALL the bolts
03-08-2008, 06:02 AM | #8 |
GEARHEAD
I bought the Jimmy from a junkyard with siezed engine. Its a 400 sbc and after pulling the heads, I figure it had a cracked block, then sat and rusted solid. It no movey no more.
BTW, thanks everyone for the help. I wasn't sure the tranny would pull away enough or if the torque converter would turn enough to come away from the tranny input shaft. Longhorn 321, if you pull the pan on a siezed motor, you can loosen all the bolts, but if the pistons wont slide up the cylinder, the crank will not drop out. Because the rods are coming in at opposing angles, it will still be stuck, unless of course you use a torch to cut the rods. At that point, why bother.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff Last edited by hgs_notes; 03-08-2008 at 06:12 PM. |
03-08-2008, 08:16 AM | #9 |
Weekend Warrior
Holy crap that's pretty bad, looks like a saltwater boat motor - well it's an anchor now. I've never seen a 400 with pistons that didn't have valve reliefs. Do the bores measure to 400 specs? 4.125" or larger?
just yank the converter still attached to the flexplate. - Be ready with the towels & speedydry
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered Last edited by arkracing; 03-08-2008 at 08:19 AM. |
03-08-2008, 09:29 AM | #10 | |
Size Matters
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ...WOOOO HOOOO!!!! |
03-07-2008, 10:21 PM | #11 |
if you pull the converter with the engine you may be able to take the convertor off with a wrench after it is out
03-07-2008, 10:45 PM | #12 |
Just pull the engine with the converter still attached to the flywheel. Best way. Been there, done that.
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 Last edited by fine69; 03-07-2008 at 10:45 PM. Reason: spelling |
03-08-2008, 09:42 AM | #13 |
Don't forget to change the front seal in the transmission when you have the engine and converter out. Been there made that mistake before!
