Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 06-19-2008, 06:46 PM   #1
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Mystery modification!
I started work on a mystery modification. I only had my cell phone for pictures. Here is a tease picture.
I'll post the rest after it's complete. Hopefully tomorrow!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 06-20-2008, 12:23 PM   #2
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
Re: Mystery modification!
Some kind of Forced air induction maybe?
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Old 06-20-2008, 12:49 PM   #3
trailwart
trailwart's Avatar
i had 1 of those ram air setups on a cavalier years ago and loved it. plain jane cavi 2.2 5 speed no ac ran valvoline and always put a couple ounces of PF201 in it and would get about 48mpg on the hway. installed the ram air and picked up some more pep at speed and cruising on hway mpg's jumped up to 51-53 mpg. let me know how it works out for you
72 chevy 3\4 ton 4 speed 4x4
84 1\2 ton 4x4 (gone but not forgotten, thanks for the memories)
1999 suburban 4x4
1982 chevrolet S-10 V-8 (Thanks uncle EARL)
trailwart is offline   Reply With Quote
Old 06-20-2008, 03:17 PM   #4
gchemist
gchemist's Avatar
Stealth ram air intake for the 4.3.
What ya think?
I finished the installation today. I'm driving nearly 150 miles this afternoon. I should get a good feel on how it works. I hope to increase city MPG to 19+. The Jimmy averages 18.5 MPG since PCM programming.
The snorkel costs $17.50 at a local performance shop. I had to buy some 3" hose clamps. Everything else was sitting in my garage. The black hose is actually race quality brake cooling hose. I used it on my 83 Chevy ram air intake too.
Old 06-20-2008, 06:35 PM   #5
trailwart
trailwart's Avatar
i know from my cavi that i noticed having to give less throttle at highway speeds.
1999 suburban 4x4
Old 06-21-2008, 12:13 AM   #6
trailwart
trailwart's Avatar
pm sent
1999 suburban 4x4
Old 06-21-2008, 09:19 AM   #7
gchemist
gchemist's Avatar
trailwart,
Thanks for the PM.
Yes, I noticed less throttle on the highway too. It does accellerate better too. It revs past 5000 really easy. I'll keep posting updates.
Old 06-21-2008, 08:32 PM   #8
BarryB
BarryB's Avatar
Is your 4.3 throttle body?? I couldn't tell much from the pics. There were to small.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 06-22-2008, 11:47 AM   #9
gchemist
gchemist's Avatar
No TBI.
Here another option.
http://meticulous-s10.itgo.com/custom3.html
You can do the same with a TBI. It may take a little more or less work though. The modification was easy. The hardest part was removing the air dam. I did not want to cut it while mounted.
Old 06-22-2008, 06:19 PM   #10
BarryB
BarryB's Avatar
Yeah I was able to make them bigger, your working with something newer than mine. Mine is a 91 so it is TBI and just a regular round style air filter.I bet I could still make it work though.
Two rules in life.
Old 06-22-2008, 08:50 PM   #11
gchemist
gchemist's Avatar
If you need an idea, checkout www.ramairbox.com The site has kit available for TBI trucks.
Old 06-25-2008, 07:14 AM   #12
70c10
67-72 Addict!
70c10's Avatar
I wonder if using smooth pipe would help flow with all the bends required? Did this mod trip the check engine light?
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 06-28-2008, 09:08 PM   #13
gchemist
gchemist's Avatar
A smooth pipe would be better. No the SES light has not turned on. I'm not halfway through the first tank since the modificaton. I can tell it has picked up a little milage.
Any modification that can lower air temperature helps.
Checkout this modification. Less work.
Simplest install with smooth pipe.
Here is a true extreme air induction modification.
Smooth hoses.
My city driving average speed is 35-45. A lot of freeway hopping on the interstate to reach some places. No block to block lights unless I go downtown.
