09-17-2008, 08:47 PM | #1 |
help bleeding hydrolic clutch
hey guys, i need help bleeding out my clutch on my 87 1 ton, i can get fluid to get to the slave and when pumping the clutch, fluid squirts out the breather for holding the fluid, do i have a bad master? hope this makes since, thanks!!
Matt
1971 k5 blazer 80k mike survivor 1972 3/4 ton 4wd Cummins 12v 1967 swb 2wd 427bbc 1968 4wd shortbox 1971 Cheyenne swb k10 unrestored 1971 Cheyenne super 40k 402bb survivor 1967 Chevy k10 (first truck) 1968 L78 camaro survivor 18k miles 1969 z28 survivor 60k miles 1969 z28 survivor 39k miles 1969 z28 rs survivor 80k miles |
09-17-2008, 09:06 PM | #2 |
Next!
Re: help bleeding hydrolic clutch
Check to make sure there's no dirt in the line, the slave cylinder's are easy to replace and not that expensive. Easier to bleed with two people. Glad my 83 is mechanical, the 88 R30 1 ton I had was like your's, couldn't bleed it either because of it sitting for so long before I got it (must of gotten rust and dirt in the line from swapping engine/trans or something) Good Luck
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
09-17-2008, 10:11 PM | #3 |
the truck has been sitting 2 years, the only thing i thought was it was pretty much gravity bleeding it self, but when you pumped it up it was squirting back up the breather hole in the brake fluid holder. making me think the seals or somthing are bad in the master
