Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 11-05-2008, 09:24 PM   #1
k5kev
New Member
Project: 1972 502 HO 4x4 Suburban
Well I actually started this project a couple years ago, but I thought I'd go ahead and start a project thread for it. I'll get you all up to speed where it is now and then start posting as I make more progress.
Started out with a 1972 3/4 ton 2wd Suburban. This is what it looked like just before I drove it to the body shop. I stripped it down about as far as I could and still be able to legally drive it down to the shop.
Name:  burb before paint 110207 021.jpg
Name:  burb before paint 110207 002.jpg
Name:  burb before paint 110207 008.jpg
Name:  burb before paint 110207 034.jpg
Instead of converting the 2wd chassis to 4wd, I bought a 4x4 truck frame and started building a 4x4 suburban chassis from there. This is the way to go when coverting to 4x4, especially since I was pulling the body off anyway. I put on 4" Tuff Country springs, a Dana 60 front, and a 14 bolt detroit locked rear.
More to follow........
k5kev is offline   Reply With Quote
Old 11-05-2008, 10:22 PM   #2
1956cameo
1956cameo's Avatar
Re: Project: 1972 502 HO 4x4 Suburban
Looks like an awesome project. Glad you got a good foundation to begin with. Definately keep us posted on this build. Not enough blazer and suburban builds on here for my taste.
Also I noticed all of the patch panels in the back of the suburban. Your project doesnt seem rusty; it really needs all of those panels replaced?
1956cameo is offline   Reply With Quote
Old 11-07-2008, 11:51 AM   #3
k5kev
New Member
Angry Re: Project: 1972 502 HO 4x4 Suburban
Yep, those are the patch panels I knew I needed before sandblasting it. It needed the normal 72 Chevy stuff: rockers, floors, front pillar, and kick panel patches,..... on both pass and driver side. Otherwise the rest of the body looked great.
As you'll see later I ended up needing even more patch panels after sandblasting!
Old 11-07-2008, 12:09 PM   #4
k5kev
New Member
So then I drove the Burb to the body shop, were the pulled the body off the frame and took the front end off and apart.
Also had them build a tube steel dolly so the could move the body around and trailer it down to the sand blaster.
Here is the 2wd rolling chassis I've since parted out and/or scrapped.
Old 11-12-2008, 09:58 PM   #5
k5kev
New Member
I'll continue on with the body,....
So the body went of to the sandblaster, and here is what she looked like when she came back,...along with some self-etching primer.
Firewall and interior looked pretty good, except the rockers and floors of course!
Passenger side looked awesome.
Roof looked real good.
And last but not least the drivers side was a mess!
By the way those are new door skins on both doors.
Old 11-13-2008, 10:08 AM   #6
1956cameo
1956cameo's Avatar
Don't you hate it when you find more body damage after the paint comes off? Still; from what I can see that is a great looking project suburban. Can't wait to see more progress of it. Quick question, when you took the upper chrome moulding off of the suburban. How did you get it off of the upper tailgate hatch. I cant see where it bolts in. Was it a glue on piece? Thanks.
Old 11-05-2008, 11:36 PM   #7
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Nice project!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 11-13-2008, 09:33 PM   #8
Hart_Rod
Hart_Rod's Avatar
Burbs rock!!!!!
Hart_Rod is offline   Reply With Quote
Old 11-14-2008, 12:29 PM   #9
k5kev
New Member
A few more pics of the Burb at this point of the project:
Old 11-14-2008, 03:40 PM   #10
ChaseDale3and8
ChaseDale3and8's Avatar
Great looking project! I really like that shade of blue on these trucks! ...Joe
I'm not speedin'! I'm qualifyin'!
ChaseDale3and8 is offline   Reply With Quote
Old 11-14-2008, 07:25 PM   #11
k5kev
New Member
So now for the difficult body work. Here is the damage again on the driver's side,....pretty nasty. You may also see some of the layout lines for the patch panels. We are attempting to "Frankenstien" this side together with 4 patch panels. A long bed lower front quarter, a shortbed bedside, a lower rear Suburban quarter, and a Suburban tail light section.
Old 11-14-2008, 07:30 PM   #12
k5kev
New Member
We wanted to get the body bolted to the frame before we started cutting sheet metal. Probably a good idea just so the body doesn't twist up or loose its shape. If we tried cutting it up on the dolly who knows what may have happened. So with the body bolted up he started cutting:
Old 11-14-2008, 07:38 PM   #13
k5kev
New Member
Before I could get back to the body shop my guy already had the bedside patched welded up. I think it turned out pretty good.
Old 11-14-2008, 07:47 PM   #14
k5kev
New Member
Then he buttoned up the lower rear quarter and tail light section:
Name:  burb quarter panel 003.jpg
Name:  burb quarter panel 004.jpg
Name:  burb quarter panel 001.jpg
and that's where its at right now. I dropped this thing off at the body shop a year ago. Its been a slow go, but hopefully six more months and I get it back with all the paint done. We'll see
Name:  burb quarter panel 006.jpg
Old 11-16-2008, 12:18 PM   #15
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Cool build, I am subscribed.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 12-05-2008, 11:09 PM   #16
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Just a thought, but have you test fit your fuel tank yet?
Also you might consider having your body man install the gas door out of a 88-98 pickup, it will look way cleaner.
Old 12-06-2008, 12:47 AM   #17
k5kev
New Member
Since you mentioned gas tank let me share what I did. I know the stock gas tank capacity isn't going to cut it with a 502.
I decided to try and install a Northwest Metal Products 37 gallon tank for a 69-72 Blazer. As you can probably guess from my screen name I've got a K5 Blazer too, and its also a 72. I figured since the truck and suburban frames are close to the same, the Blazer should be too, and I didn't see why a "Blazer" tank wouldn't fit. As it turns out it does fit. I'll confess its slightly off center between the frame rails, and I sorta ditched the directions provided and figured out how to mount it myself. I don't know if this was due to it going into a Suburban, or just manufacturing variances from Northwest Metal Products. Again I think it turned out allright.
Old 12-06-2008, 12:57 AM   #18
LEEVON
LEEVON's Avatar
Better fill that puppy up while gas prices are low Love the build!
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 12-06-2008, 01:19 AM   #19
k5kev
New Member
I know what you mean! Heck, by the time I get this thing on the road gas could be $10 bucks a gallon!
Old 12-05-2008, 11:17 PM   #20
msgross
msgross's Avatar
cool build..
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 12-06-2008, 01:01 AM   #21
nuke1
nuke1's Avatar
looking real nice and clean, job well done so far, what rims and tires do you plan on running?
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 12-06-2008, 01:31 AM   #22
k5kev
New Member
Thanks for the complements and ecouragement.
I guess I'm kinda going with a semi-stock/resto-mod/sleeper look. Just drivetrain upgrades and mild lift. Also going with a stock interior,....3 rows of bench seats,....stock door panels etc. So with that in mind I'm leaning towards some stock steel wheels and chrome 3/4-1 ton hup caps, along with some Goodyear MTR's,.... 33's or 35's. Not sure if this thing is going to fit thru my 7' garage with 35's and a 4" lift, so that'll determine the tire size. Can't be leaving this baby parked outside with all that's invested.
Old 12-06-2008, 01:22 AM   #23
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Cool, and the upside is, that tank is a good ways forward, so if you should go through the very unfortunate experience of being ass ended, there is a much smaller chance of bursting into flames.
Old 12-06-2008, 11:15 AM   #24
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Nice job job far..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 12-09-2008, 08:31 PM   #25
k5kev
New Member
So finding a set of headers was a serious challenge,...BBC in a 4x4 frame with a SBC crossmemeber. GM Performance Parts tells you to use 2" primary and 3" collector headers for the 502HO. Not to many header companies make 2" primary headers, and I definately didn't want to choke down the motor with some 1-3/4", which everbody makes. I think just Hedman and Hooker make 2" BBC headers. I ended up going with Hedman. It still wasn't simple, I tried 4 or 5 different sets, and the only way I was able to make it work was by combining 2 sets. I used a 67 chevelle driver side and a 72 Chevy 2wd truck for the passenger side. Since Hedman sells a drivers side only for the 67 Chevelle, so I only actually paid for a set and a half of headers. I still also had to do some grinding to the frame to squeeze them in, and I shortened (cut and re-welded the flange) the driver side collector by about 4",...it was too long and too close to the trans crossmember,...not enought room to bend the exhaust pipe over the transfer case.
[img]
