Old 12-10-2008, 06:34 PM   #1
mobileortho
mobileortho's Avatar
Centering the rear end
I mentioned in a previous thead that I needed to center the rear end of my truck. I was going to do this by reversing the springs. Although this seems pretty straight forward, I've found out that what sounds simple rarely is. Is there anything I need to be prepared for or is it as simple as it seems?
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 12-10-2008, 06:49 PM   #2
larry may
Re: Centering the rear end
Reversing the springs? How does that work to center the rearend. Just curious! Thanks for any information how that works to center a rear-end.
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 12-10-2008, 11:04 PM   #3
solidaxel
solidaxel's Avatar
iT MOVES THE TIRE TO THE REAR, to center it in the wheel well (fender opening)
Now you are going to lengthen your driveshaft right!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-10-2008, 11:20 PM   #4
Houston54
I did this flip on my 54 and it does help get the rear wheels lined up in the fenderwells better but it will not get them all the way there. You still need to move them 3/4 further rearward to center them up.
The best solution is to spend the $550 on a rear leaf spring kit and be done with it. You will get a better ride and it will not be kluged together.
If you are lowering the truck also you may need to notch the frame rails depending on how far back you moved the axle. Your frame has higher kickups than my 54 so this may not be an issue.
Houston54 is offline   Reply With Quote
Old 12-11-2008, 02:09 AM   #5
mobileortho
I just stumbled across a kit that Brothers sells that will move the rear back 1 1/2". Retails for $50.00. I might give it a try.
Robert C.
1950 3600
Old 12-11-2008, 08:52 PM   #6
50adrod
50adrod's Avatar
I also used the TCI rear leaf kit, like said above remember your driveshaft
1971 Corvette convertible 454@ 525 hp
1936 Chevy Truck street rod
1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up
1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html
1950 custom Chevy Truck
50adrod is offline   Reply With Quote
Old 12-14-2008, 05:44 PM   #7
mobileortho
Just found out that CPP has the same item for $20 cheaper.
Robert C.
1950 3600
Old 12-16-2008, 07:45 PM   #8
mobileortho
I was talking to the owner of a hotrod shop about this and he said that all I have to do is drill the centering hole in the main leaf to center the rearend! Thats it!! No kit required!! Can't get any more simple than that!
Robert C.
1950 3600
Old 12-16-2008, 10:21 PM   #9
JML55
JML55's Avatar
Good luck trying to drill a leaf srping, that is realy hard stuff.
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
http://67-72chevytrucks.com/vboard/s...d.php?t=316140
http://67-72chevytrucks.com/vboard/s...d.php?t=806011
JML55 is offline   Reply With Quote
Old 12-17-2008, 10:10 AM   #10
Houston54
Drilling a spring is never a good idea. Another solution is to flip the spring then use a spring perch that has three holes in it. Open the front hole to permit the head of the spring bolt to pass and position the axle on the springs using that front hole. This will get the wheels centered correctly. You will have to fabricate new lower plates which is simple enough. The lower plate will need to have the center hole located to match the upper spring perch hole. Use good u-bolts and re-do your drive shaft and you are there.
Might seem to be a bit shade tree but it works and saves you $$ over the leaf spring kits. As long as you are not planning to run a high power/torque motor this should work fine for you depending on the condition of your original springs.
If you have not already done so you should replace the front spring hanger for the rear leafs with the rear spring hanger from the front springs. This, in conjunction with flipping the axle on top of the springs will get you a good ride height for that truck provided the front end is lowered to match.
Old 12-17-2008, 08:32 PM   #11
50adrod
50adrod's Avatar
sounds like a lot of work. then you need to address the shocks. the spring kit with new springs and shock relocation, with new shocks is around $500 from TCI and it bolts to the original frame holes, it centers the axle and lowers the rear about 4 inches. to me not bad for the price
Old 12-18-2008, 12:38 AM   #12
PDW HOTRODS
PDW HOTRODS's Avatar
What rear end are yuo using? If the pad is long enough drill a new hole in the pad and leave the pin in the springs where it is. I am using a Nova rear end, and the pad was plenty long.
PDW HOTRODS is offline   Reply With Quote
Old 12-18-2008, 03:34 PM   #13
mobileortho
It's a Chevy II rear end.
Robert C.
1950 3600
Old 03-24-2019, 12:38 AM   #14
sickytwisted
sickytwisted's Avatar
I made a block with a machine screw and a hole in the opposite side to Center mine. The hole clears the bolt through the leaf springs and the machine screw goes into the hole in the perch about 1.75" back. Cost me 6 bucks. If I remembered how to post pictures here, I would.
"Until you can acquire a suitable replacement, stay off of the freeway." -50's Tim
sickytwisted is offline   Reply With Quote
