01-05-2009, 05:12 PM | #1 |
OD Auto Tranmission that can handle a load.
What is a good 4-speed auto transmission that can used in my 71 GMC C2500. I was researching the 700r4 but it doesn't seem like it is a sturdy transmission for towing with (camper and small boat). Does anyone have any recommendations? Thanks.
Buford - 1971 3/4 ton, Custom Camper, 350 Th, 350 SBC. |
01-05-2009, 05:32 PM | #2 |
Never Ending Projects
Re: OD Auto Tranmission that can handle a load.
If you got the $$$$ a 4L80E is they way to go. They are basically a TH400 that's a 4 speed with overdrive.
The other option which is $$$ is putting a Gear Vendors overdrive setup behind a TH400. Of the two, it's most likely the cheaper route but you're still looking at $2500+. I'm in the same boat, trying to find a reasonable solution and have yet to find one. I had a 700R4 in my last '68, which worked fine but I never did any hauling/towing with it.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
01-05-2009, 05:33 PM | #3 |
Find a late eighties 700r4 and rebuild it with a Turbo 700 kit. It will handle anything you're going to throw at it. I can't remember who offers that kit but it seems like the way to go. Also TCI has a replacement valve body that makes the 700r4 work like a TH350 for fluid pressure. Then the TV cable is used to adjust shift points only. That setup would also be a good choice.
01-05-2009, 07:18 PM | #4 |
Recovering 67-72 Addict
I have been running a 700R4 from BTO (not the band) for over 5 years now behind a fairly healthy big block. I have not had a single problem with it. I purchased their level 3. Here is a link:
http://www.bowtieoverdrives.com/cata...m.php?ITEMID=9
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
01-06-2009, 01:27 AM | #5 |
I'm a little hesitant to go with the gear vendor and TH400. I have a good friend of mine that runs that combo and the gear vendor keeps going out. I was looking at the 700R4 level three and that seems like a stout unit. Thanks for the options, I'll do some research.
01-06-2009, 01:37 AM | #6 |
Lemme show you something!!
If you have the $$$ and time- I'm sure Advanced Adapters could fab up some sort of conversion kit to shoehorn in the Allison-1000 6-speed out of a Duramax Silverado. I haven't seen or heard of it being done- yet....so I'm basicallly thinking outloud at this point.
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
