Front ds vibration
Looking for ideas,
2WD, hubs unlocked - no vibration 4WD, hubs locked - no vibration 2WD, hubs locked - vibration. and it phases in and out. I'm fairly certain it's coming from the front. anyone got any ideas? THX
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
Re: Front ds vibration
Slip joint would be where I'd look first, then front u-joints, then...everything else.
i had a similar problem then i grenaded the right front axle and repleced it with another one and presto! no more vibration. not sure the reason behine the grenading axle but it could've been a bad u-joint since the new axle has a new u-joint in it
(Only) Member of the CPNE Fan Club ![]() ![]() 67 C-10 350 with 3-speed tranny and 308 gears swb step ![]() 82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine) 72 Chevy K20 Suburban (future project) 70 Chevy K20 now 68 GMC K2500 2003 Chevy 2500hd ccsb 4X4 (daily driver) |
thanks for the replies! I've noticed no vibration at slower speeds, then around 50 it starts to pick up... I'm starting to wonder if the DS is out of balance. I picked it up from a junkyard when I did my T-221 to NP205 conversion...
In that mode your wheel are turning you shafts freely,as in unengaged to the t-case.Wteh it in 4wd it`s enough to put tension on the worn joint.So,it would be either in the axle "u"s or driveshaft.Put t-case in neutral and unlock hubs to check for play in joints.You`ll be able to turn everything into whatever position.Once in position you can hold one side of the joint or lock the hubs.Stick a big screwdriver through the joint and check for slop.You should notice slop by losking hubs,grabbing the d-shaft and twisting back and forth,too.
