02-12-2009, 09:57 AM | #1 |
99+up common problems
Ok let's list them---
1- Steering column vibration mostly noticed going slow --off road or in parking ---the column intermediate shaft is fluted with grease taking up the shock---it gets squeezed out. There is a factory bulletin to either repack or to "stroke!" the unit---what a BS fix this is but it works for a while. 2- Windshield noise pass side---from a bug shield changing the air flow!! Tape, caulk windshield to molding or take of the bug shield. 3- Premature front brake wear---factory bulletin for "northern states!!" ie the antilock sensor looses it's ground path due to salt-rust getting under it's mount to the spindal housing. factory bulletin recall---get them to replace the pads if you can. 4- Brake drag noise from the drivers side rear---the parking brake "horse shoe" unit is dragging on the drum and wearing out. Factory bulletin replaces the spring holder and possibly the horse shoe assembly but only on manual shift trucks!!!! how is that for another BS fix from GM? OK guys, add some more as these trucks are full of BS GM issues~~~~ 5- |
02-12-2009, 09:17 PM | #2 |
Re: 99+up common problems
Fuel gauge (sending unit)
Speedometer Water pumps Front bumper brackets cracking out Im sure theres more.... |
02-12-2009, 11:53 PM | #3 |
loose driver seat...
factory security system... leaking from somewhere and I can"t find out where from!..
GROUND ZERO IS R LIMIT |
05-23-2009, 07:28 AM | #4 |
Rottenwood Garage Member
Welcome to GM trucks and SUV's from 1995 and up. My last 3 drove me crazy with leaks of every type.I finally solved my "newer" GM leaking problem by not buying anymore!
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
05-26-2009, 12:49 PM | #5 |
After reading through this thread I'm only more disappointed with my 2000 4.8/4l60E Silverado 4x4. It has the "towing package" with 3.73 gears and whatever else that entails. This thing can't climb up a slight grade without downshifting every 30 sec even with my small utility trailer loaded down with a Murray riding mower. I know only its a 4.8 but they claim 285 horse or something? It has no torque whatsoever. I miss my 95 Z71 5.7 TBI, it had nothing above 4000 rpm but had lots of grunt down low and could pull my boat up a hill easily. Not to mention the annoying column clunking, piston slap, burnt out radio buttons, $1000 abs pump repair, overdrive shift solenoid, blower motor resistor, noisy ac compressor etc. This truck is a weak, cheap built POS. Now I hear you guys saying the 07 ups are worse?? I've always had Chevy trucks but am ready to throw in the towel on these newer ones. Lots of you say you won't buy another but tell me what new truck out there is worth buying? I'm tempted to cross the line and go with a F150. At least the 5.4 has low end torque, that is what a truck motor is supposed to have right? I know the Chevy LS series engines are screamers which is great for a Vette or camaro,but what good is that in a truck?
05-26-2009, 02:54 PM | #6 |
before switching to the dark (ford) side let me fill you guys in on some common problems for f-150,and up along with suv`s
ball joints constantly go bad trannys slip rear ends go out and need rebuild v8`s pop the spark plugs out of the head due to threads stripping. (head replacement) deisels. the egr cooler leaks window motor/regulators go out in all 4 door windows. these are the ones I can just think of off the top of my head.
1967custom Last edited by michael bustamante; 05-26-2009 at 02:55 PM. |
02-12-2009, 11:54 PM | #7 |
rear mains leaking
i've seen them at work with 3k mile ont eh trucks with rearmains leaking
02-13-2009, 03:34 AM | #8 |
4x4 dash switch
CSK
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
02-13-2009, 05:37 PM | #9 |
I had an 07 sierra classic and it was flawless for the 17k miles I had it. It was too big for the wife to drive so we traded it off on a car.
02-13-2009, 07:28 PM | #10 |
Forgot about the stupid faulty 4x4 switch.
The tow-haul switch in the shift stalk fails due to inadequate wiring into the column. And the worst---and I have had 3 99+ trucks=5.3V8s and every one had the engine ratteling within the first 30k miles--sounds really bad in the cold butttt---they do run forever! Strong engines but one would think they could fix the stupid ratteling~~~. |
02-13-2009, 09:10 PM | #11 |
hvac blend door servo motor.....
02-14-2009, 08:06 PM | #12 |
Explain this a little more please.
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
02-17-2009, 02:05 PM | #13 |
Progress = 0%
Based on my truck....
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
02-25-2009, 11:06 AM | #14 |
This is the only problem Ive seen on my 04. Other then that its VERY solid. My dad had a 02 and never had any trouble with it... put 110k on it. Did have the "bug shield" noise after installing a bug shield, but I wouldnt call that a problem lol. Now he has a new style 07 and no issues with it either.
Never heard of any chevy truck with bad rear mains... or water pumps.
2004 Chevy 2500HD Duramax 1978 K5 Chevy Blazer (in process of tranny and floor pans) 1970 C10 LWB (Rat Rod Project) Those are the only vehicles that fit in here lol |
02-25-2009, 08:51 PM | #15 |
Can you explain what the symptoms of your problem was/were? And what the solution was??
On my '06 it seems I have been having a beech of a time regulating the temperature; if I have it at, say, 3/4 the way up and it I push the switch down slightly, after a few minutes it starts blowing cold. This is still way up in the red (hot) area of the control. If I then nudge it up ever so slightly, after a few minutes it is cooking me out again???
02-26-2009, 09:21 AM | #16 |
The flap that directs the air flow to either the defrost vents/dash vents or floor vents is controlled by a servo which goes out. Happened on my 03 Z71 but the dealer covered it. I believe they mentioned it would have cost me about $250 to repair.
Other problems are the fuel pump. If you have trouble getting the engine to start when you have less than a 1/4 tank of gas it is a symptom of the fuel pump darn close to giving up the ghost. Found a whole bunch of mud and debris in the gas tank when it was dropped to replace the pump. The dashboard ABS light and parking brake light coming on and staying on with no codes is also a common problem. From my own experience regarding electrical issues I would check all the ground connections especially the one on the top rear passenger side of the engine block. |
02-14-2009, 01:34 AM | #17 |
I've fixed the tow haul switch on mine. Easy fix. I need a new 4x4 switch. Just haven't changed it. It has a slight CSK but Mobil One just about kills it and it's not noticable in spring/summer/fall. I've put over 50K on my truck, had 66K when I got it, it has new tires (last set lasted 40K+) and new Bilsteins, still has the factory pads and rotors, but need to be replaced soon.
I'd buy another one of these trucks in a heartbeat.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 02-14-2009 at 01:36 AM. |
02-18-2009, 09:29 PM | #18 |
My 99 had a coolent leak somewhere in the back--couldn't find it but did put some radiator stop leak into the system @ 140,000 miles. Sold it without a leak @ 188,000 miles.
Oh yea, there is that issue of cold air coming into the pass floor heater --that coating the foam rubber seal around the air box is supposed to fix---. I certainly would not pay $25,000. plus for another new chevy truck. Especially when they wouldn't even sell you one with a 5 or 6 speed manual!!!! They can go chapter 11. |
02-21-2009, 09:11 PM | #19 |
So far the only one I have noticed on my 02 is the steering column clunk. But I have the el cheapo model, so no fancy stuff on it to break. Seems like all the GMs have the clunk since about 2000 year. Mine wife's Bonneville had the same issue.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 02-25-2009 at 01:35 PM. |
02-26-2009, 03:02 PM | #20 |
2 pc driveshaft failure/vib at low miles.
General rattles Window regulators water pump #7 injector plugging
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
02-26-2009, 09:07 PM | #21 |
The Early Chevy Van Man
Mine had the common problem of the odometer/drive position indication going dark... intermittent problem. I found a guy on ebay who sells the repair service for $100 + shipping. I'm currently driving around with no gauges at all because he is fixing them and will send them back soon. He has 100% positive feedback and instrument clusters is all he does it seems. I've got my fingers crossed!
Also: -Problem with power windows only go to the right, but not left or up or down. I replaced the switch, but that was not the problem... so now what? I'm not sure. -The driver's door seal is noisy. It lets the wind in at speed. On my list to replace the seal. -The rear passenger side pop-out window no longer closes properly. Very noisy above 45-50 mph. Very annoying. I understand there is a fix for this by putting a sheetmetal screw through the hinge into the metal of the body. -Rattle from the glovebox latch -Rattle from the center console above the CD player. -Keyless entry is 'lazy' you need to press the button on the key fob multiple times to get it to unlock... this is with a brand new battery in the fob. -Seatbelts are twisted up and I don't know how to untwist them. All minor issues... other than that its a great truck and I got a pretty good deal on it. I like the 6.0 engine and 4L80e trans. Its got alot of power and I also like the lines of the silverado bodystyle. Its spacious and very comfortable inside. For a 3/4 ton, it rides alot better than my old f250. I have the LT package with power heated leather seats and they are not loose and work great. I have only owned it for a couple months. It has 111k on it.
64 Chevy Van 65 GMC Handi-Van 99 2500 silverado 4x4 ext cab Last edited by kookykrispy; 02-26-2009 at 09:25 PM. |
03-02-2009, 09:46 PM | #22 |
Huck, On your cold air coming in, how did you say you fixed it? We just did a trip and my wife really felt a draft on that side. I did too for that matter when she was driving. Is it an easy fix? Thanks in advance..
03-10-2009, 01:52 PM | #23 |
99% of the time the cabin air filters (2 of them) are very dirty and need to be replaced. the fan is on the up stream side and forces air thought them. when the filter is dirty the air bypass (due to the plastic and the seals letting the cool outside air into the inside on the pass foot well area. replace the 2 filters and you will haved fixed the cold air issue.
Trueman |
03-10-2009, 02:10 PM | #24 | |
Tasty Cakes!
My ABS module died a long time ago. I just pulled the fuse meaning to fix it, but it's been like 4 years now LOL. Fuel pressure reg died. And I think the water pump gasket is leaking. These trucks are notorious for that one. Not bad considering I drive it like my momma stole it and I don't do much more than change the fluids in it. And it's almost got 100k of 98% stoplight to stoplight driving! (Of course, now that I said something she will die.)
I'm a little and a lot Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado Last edited by Riveted1; 03-10-2009 at 02:11 PM. |
03-03-2009, 10:21 PM | #25 |
Piston slap especially on cold start--I bought the truck from my Dad--who bought it brand new
2000 Chevy 2500HD 4x4 6.0 litre He took it to dealer, they said "it is normal"--GREAT Last edited by cheyenne402; 03-03-2009 at 10:21 PM. |
