Old 03-08-2009, 07:19 PM   #1
Funeral
Funeral's Avatar
Quick question about tires.
Ok so I got some new tires today. I got the same size that was on it.
They are 215 /70 /15 the problem is they are rubbing at the tire rod end connection.
So my question is for an original front end setup what size trire and wheel should I have. I looked in the shop manual and it says 6.00-16 to like 8.25-18 so not real sure what to do here.
thx in advance.
Funeral is offline   Reply With Quote
Old 03-08-2009, 09:15 PM   #2
Funeral
Funeral's Avatar
Re: Quick question about tires.
I guess it couldn't hurt to add that I am talking about a 1947 Chev Pickup 1/2 ton Thriftmaster.
Old 03-09-2009, 07:55 AM   #3
Funeral
Funeral's Avatar
I hope someone see's this soon, not sure how long I have to return these tires if need be.
Old 03-09-2009, 10:23 AM   #4
sgtusmc
sgtusmc's Avatar
I did a quick google search and 215-70 R16 seams to be as close as you can get to the 6.00-16. I would think the 15" size would be close also (I guess not they rub). Would you be able to run a 1/4" spacer up front? Are you rubbing all the time or only at full lock?
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 03-09-2009, 07:41 PM   #5
heyjoe
Have you asked over at the Stovebolt forum? The place is dedicated to old Chevy trucks up to '73. Mostly geared to '30s, '40, '50s iron.
http://www.stovebolt.com/ubbthreads/
heyjoe is offline   Reply With Quote
