Cutting Springs?
Anyone have any advice on cutting springs. I kinda was thinkin bout cuttin my springs to lower my truck. im on a very limited budget and i drive this truck everyday. Any feedback or opinions would be appreciated.
68 swb 4x4 327 4 speed |
Rottenwood Garage Member
Re: Cutting Springs?
You can cut the fronts but you will have to replace or heat the rears.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
As 72Freak said you can cut the fronts although the naysayers will tell you not to. It has been since people started lowering coil spring rigs and the biggest rub will be that the truck might ride a bit harsher. You should have the alignment redone after you do it though. I'd use a cutoff wheel rather than a torch.
On the rears you are going to have to change the coils to do it right. Heating the coil is the way a lot of guys used to do it but they usually keep sagging and there is a great chance that they will break at some time or another. There are also lowering blocks to get a couple if inches of drop but I think that they come close to the price of new coils. |
why is it you cant cut the rears? just curious. i beleive you i am just wondering
The Older Generation
The rear coils are tapered on both ends. If you cut them you would have to have a way to re-bend them on the end. You can make some lowering blocks out of 2x2x 1/4" wall steel tubing but you would have to buy some new 2" longer "U" bolts. (about 30 bucks at a spring shop). I would not heat the springs... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-11-2009 at 01:21 PM. |
when you cut the springs in front, how much more harsh is the ride? i would have thought that the spring would have been softer this way, and that the truck just bottoms out a lot easier?
- Jason If you can turn, Youre not going fast enough. Favorite caption: first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around.. ..back when men were men. |
Cutting one full coil off really shouldn't change the ride all that much. One full coil should give you a 2" to 2 1/2" drop. I don't think I would cut more than one coil though. LockDoc
resident oilfield trash
I didnt think it was any harsher last time i did it
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() |
Out of the carpool lane.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
I hate being the naysayer...
Springs are designed with a predetermined rate of travel and cutting them changes that rate. Springs designed for lowering are not just simply shorter, they also have increased rate to provide the ability to carry the load with the shortened amount of travel. IMO cutting springs to lower is like removing 1" from your shins instead of buying longer pants. it just doesn't seem like a good idea. As for heating springs, you bring the possibility of continued spring sag AND it makes the metal more brittle and prone to snapping. You might save some cash by heating the springs but having one snap while doing 70+ mph would have been well worth the investment of proper springs. When trying to save on money, your suspension is not always the best place to skimp. |
Junior Member
![]() Join Date: Mar 2007
cut the fronts. The spring rate does go up a bit & it will ride rougher, but it is cheap. It is all in what you want to spend. 70's full size chevy cars have rear springs that will fit your truck & will lower it...
Heating them is a bad idea. They will break eventually... I have used the torch to cut springs many times. only the very end gets hot...
frontstreetcycle on Instagram |
I would not recommend it at all. I just replaced my springs, the fronts where cut and constantly made snapping noises when driving slowly in to holes.
The rears where heated to lower them, but they also didn't do it well. After putting the lowering springs on the burb, it is driving much nicer. It did cost 200 buck but it was well worth it.
Anybody can restore a classic, takes a man to cut one up..... http://www.arnoldscustoms.com |
![]() Join Date: Dec 2008
Heating your springs is like letting all the air out of your tires, It will make your truck lower, but it is a really bad idea if you want to drive it.
#15 |
its all about the +6 inches
chopping and heating has been done for 50+ years. If done right, there won't be miuch of an issue.
It isn't the best way, but it works. I would recomend chopping and cutting, (get someone who has done this before to help, otherwise some of the bad things could well happen) and never saying anything about it on here, many will shun you for it. Last edited by Longhorn Man; 03-11-2009 at 05:19 PM. |
#16 |
1970 Daily Driver
Cut them it works great and is not a safety issue if done right. I would not heat spring though as they seem to settle out over time and usually not evenly.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
#17 | |
72 Chevelle Club
![]() Quote:
I Have The Right To Remain Silent,But Lack The Ability 1972 Chevelle ... Mine 2006 Trailblazer... Hers 2002 Buick century ... Kids 2002 K1500 Z-71 EXT CAB ... Daily Driver 2005 Rockwood Roo ... For Camping 1974 Harley-Davidson XLH Sportster 84'' stroker |
#18 |
The odds of a brittle spring snapping and blowing out a tire causing the truck to careen out of control and burst into flames are slim to none. Fatalities (or accidents for that matter) caused by improperly lowered vehicles are probably about as common as lottery winners.
That being said, if there are players, somebody has to win. Having a spring crack or sag though regardless of any safety risk is going to put you right back in the boat of needing a new spring anyway. You can always sell the OE springs to get back a few bucks. Not here to shun anyone, my own father has cut the springs on every truck and hotrod he has built and never had a safety problem. They just ride like a hay wagon afterward. |
#19 |
1 coil=2in. lower stance, go from there. You might also want to trim your bump stop a little lower, to give that much more ride before it bottoms out.
68 c-10 1/2 ton swb fleetside, 79 GMC Sierra Grande 1/2 ton swb fleetside, 99 Dodge Durango 4x4(wifes ride ![]() ![]() 54 caddy 62 series 4 door(younger sons ride, aka 54caddy ![]() 70 caddy 2 door, 89 chevy silverado stepside(older sons rides ![]() |
#20 |
i cut 2 coils, been ridin for a year like that, not so great for weight transfer at the track, but i would do it again if i get another truck for sure
#21 |
I am a Referee of life.
I'm just going to say that you don't want to go with more than 2 in of drop with springs,unless you are replacing the control arms.Most with more than 2 in of lowering in the springs have had alignment problems due to needing more shim to align than is safe.
This is even with factory lowering springs.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 03-11-2009 at 07:27 PM. |
#22 | |
Eat My Rust
#23 |
Junior Member
anyone cut 3" lowered springs to get another 1" or 2"?
#24 |
Fabricate till you "puke"
I havent tryed that......but lower than 3" on a spring, you are really pushin the limits of the geometry on the front end. I wouldnt do it.....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
