08-09-2009, 10:37 AM | #1 |
Any 12 sec daily drivers
I know these trucks are heavy and to reach 12 sec territory is going to require a lot of power.
Is there anyone running in the 12 sec range with there daily driven truck? If so whats your set up? |
08-09-2009, 11:28 AM | #2 |
Re: Any 12 sec daily drivers
68 lwb with 6-71 on special vette lt1(92). switched from small chamber aluminum heads to big chamber iron heads and went faster, msd stuff out the ass, 12 lbs of bost and 3.73 with drag radials. fastest 12.08 @ 107 so far. its been down since april of 08 but almost done with it(pretty much rebuilt and modified everything) now has same block .030 over, stock crank and rods(flash ground), balanced, TRW forged flat tops, RHS aluminum 72cc heads(with some work by me), weiand blower manifold( built an adapter plate that bolted to torker manifold before but the bolts kept backin out so i needed a better way to fasten the blower down; i had 6 broken pistons when i tore it down and a smoked 350 trans that was built to the nuts about 10 years ago. now has a 400trans with all the good stuff. should be a good 11 sec ride now and yes it will be my daily driver again. missed 1st place for the season by 3 pts to my best friend in his first year racing, but still got to go to nationals in Medford Oregon back in 06. can't wait to get her on the streets again. also got a set of vette wheels for $100 from local swap meet with some 2.5" wide adapters off ebay(actually really nice) but i want them wider...(14" or so hehe)
here she is:http://viewmorepics.myspace.com/inde...lbumId=2794186
whoever thought of "i live my life a quater mile at a time"-vin diesel needs to be ***** slapped. i would have a pretty short life |
08-09-2009, 11:47 AM | #3 |
Nice truck!
Do you think 12 sec would be possible all motor and still be daily driven? |
08-09-2009, 11:47 AM | #4 |
Registered Truck Offender
Not so much a 'daily' driver but it's licensed, registered and insured and get's plenty of street time.
66 SWB, 3380 pounds, N/A pump gas 385 (4.040" x 3.75) w/ GM 5.7" rods, SRP flat tops, AFR rr210's flat milled to 70cc, SuperVictor intake, Prosystems 860cfm carb, Crane hydraulic roller (236 / 242@ 0.050, .56 / .58 lift) , 1-3/4" SUpercomps to 3" series 40's and 3" exhaust.,Midwest 4800 stall 9.5" convertor, Hughes TH350 w/ sprotsman brake, 9" with Dyneer locker, 5.43 gears, 33x22.50-15 Hoosier QT-pro's. Shift at 6000 it crosses at 6400. (hydraulic roller motors dont really like rpm's) best of 12.03 @ 108
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
08-09-2009, 11:56 AM | #5 |
Looks like you answered my question at the same time I was asking it Marv D
Does auto over manual tranny make a difference? I'm planning on running a TKO 600 tranny. I'm thinking big block but need to do more research before I settle on that choice. I know they add a lot of weight to the front end. Last edited by CB24; 08-09-2009 at 11:56 AM. |
08-09-2009, 02:38 PM | #6 | |
I wouldn't say they don't like RPM's.. Mine has no issue pulling to 7,400.. With the intake swap I bet it will like 7,600 better unless I retad the cam a bit. If my motor had a smaller cam in it, I'd say it would be fairly easy to daily drive for most people and be solid in the 12's. But I'll live with mid 11's (hopefully that's what it will run next time out) and a little less DD. It would not be a problem IMO DD'ing it with the over drive ect, but that's me.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
08-09-2009, 12:13 PM | #7 |
All the time your foot is on the clutch and your shifting gears,,, the truck is not pulling. It's lost ET. Multiply it time 3,4 or 5 gear changes.
The deep 1st and 2nd gear ratio is going to be counterproductive to a traction limited chassis to begin with. If this was a TRACK ONLY machine, I'd say go auto. But it's a driver. So build it the way you want to drive it.
08-09-2009, 12:56 PM | #8 |
my truck used to do 12seconds stock..................................................OK, that was 0-60
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
08-09-2009, 01:10 PM | #9 |
Not a daily driver, but will run 12's...
08-13-2009, 11:56 AM | #10 | |
Yes dead hooking a manual is very difficult and if you dead hook you have a higher probability of breaking something. Not that you want to DD with a pro-shifted or faceplated tranny but that would help cut down ETs. I must say: real cars/trucks have three pedals.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
08-13-2009, 10:19 PM | #11 | |
Oh,you can't buy that new
for the books. i read a long time ago to build your engine for torque not RPM if you plan to run 110 MPH or less. so i did. my truck, a laoded 81 SWB, silverado. had almost gotten into the 12's (13.2 with no tuning),with a nothing 350, 4.10's and Th-400 ,w/3000 stall. i wouldn't have thought twice about driving it on the street. the RWHP was only 275, but 410 Tq. 110 MPH will get you DEEP 12's
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone 73 Pinto, stock, w/CragarSS's-eww LOTS of Cummins trucks. Last edited by crossy; 08-13-2009 at 10:26 PM. |
08-13-2009, 11:03 PM | #12 | |
Some autos do have a lock up. I think it's pretty close as far as efficiantcy when locked. I've gone 12.0x with a 110mph trap speed.
08-09-2009, 05:52 PM | #13 |
In a standard Gen II 23° sbc head???
Look through the Comp, Crower or Lunati hydraulic rollers for the Gen II motors and find me one that lists anything over 6500 for effective rpm range. With all respect intended, Your LS1 is a very different animal. The 2.08 stainless intakes, Crane Gold 1.5 roller rockers and SpeedPro roller lifters,, are heavy. EVEN WITH the Hydra-rev kit doesn't like anyting over 6500 for beans, I can slow the truck down a tenth and a half by shifting at 6400 and it will drop over 2 tenths with a 6600 shift.
08-09-2009, 06:31 PM | #14 |
Sorry Marv, I took your comment as a general rule for all hyd lifters. Pair those lifters with a 1.94 valve head or 2.02 valve head and the right valves/valve springs and it might be different. To your point valvetrain dynamics is what will dictate the RPM the hyd lifter will work at.
We've played with a buddy's 1.94 valve head, right cam and springs and it works best at 6,800 on a hyd roller.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 08-09-2009 at 06:33 PM. |
08-11-2009, 11:28 PM | #15 |
Mean Green
'68 LWB street driven all summer long and to the coast to car shows.
Truck has ran as fast as a 12.0 12.2's all day long. 3500 stall, th400 w/ transbrake. 4:10 with a 28" tall tire. The Motor dynoed at just over 600HP Isky solid roller 106.5 640 lift @ 260 duration. average free way MPG 10. |
08-12-2009, 09:33 AM | #16 |
On a budget like Fred Sanford
'85 swb: 383sbc, vortec heads, 10.4:1 compression, 232/238 .544/.555 110lsa hyd roller cam, rpm air gap, 750cfm carb, 1 5/8" longtubes, M21 muncie 4spd, 3.42 rear, 28" tire. Shift at 6000rpm.
Dunno if it's in the 12's but if put a tire on it and hooked it'd be pretty close......I usually beat stock LS1 fbody's by about 1.5-2 truck lengths on the street. Drive it every day of the week all year round. Averages 15-16mpg too.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD Last edited by swb85; 08-12-2009 at 09:34 AM. |
08-12-2009, 09:56 AM | #17 | |
Honestly I just want a fast truck & to me 12 sec is fast! I'm sure 13's would be fine too. My DD right now is a scion xb auto. If its not the slowest car on the road I'm betting its damn close. |
08-12-2009, 11:54 AM | #18 |
Kinda.....it's really hard to get my truck to hook with any kind of radial street tire. Leaving very much above idle blows the tires away. Usually have to go from a 15-20mph roll and ease into the throttle. It'd really scoot with some et streets, but that's when parts start breaking (I'm on my 3rd muncie already).
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
08-13-2009, 12:04 PM | #19 |
Wild83,
I can agree with you to a point about real cars/truck having 3 pedals. I LOVE banging gears. It is much more fun than just clicking the shifter up to the next gear. BUT, for a street/track application, you can not get more consistant than a well set up auto. If your ok with running a class and being unconsistant in it, great. Or if you just like to runn your buddies and don't care if you win 1 out of 3 because your vehicle is iconsistant, great. I'll take consistancy for drag racing and keep the 3 pedals in the road race car
08-13-2009, 08:50 PM | #20 |
Super,
Can't argue much with you there. Although there are plenty of guys running and winning in their class with 3 pedals. Wasn't trying to argue which was better either, just thought MarvD's statement was a bit one-sided. I know Marv knows his stuff though . Being consistant with a stick definitely takes more practice, but if you are good you have the advantage. Register and check it out: UTMR Forums
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time Last edited by Wild83C10; 08-13-2009 at 08:53 PM. |
08-22-2009, 02:20 PM | #21 |
My truck was a daily driver when I ran 12.8 a while back. It was a 82 C10 with a stock 6.0L with a small cam. I had tons of problems with the truck at the time, so I'm sure it could have gone much faster.
There's guys running 12's in extended cab trucks with 5.3L engines...and still daily driving them. So you may want to check out these Gen3/4 motors.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs. Best time so far 11.8@XXXMPH Last edited by team39763; 08-22-2009 at 02:20 PM. |
08-29-2009, 06:52 PM | #22 |
At the body shop.
Guess i oughta go looking around more been hanging out on the 73 board 12.20s 1.67 60ft and driven 45 miles each way to the track
" That didnt make it any newer " " Dont antique the equipment " |
08-30-2009, 05:21 AM | #23 |
Dr. Frankenstein
jesus that looks like a tank?..... what gets it moving so nice?
I Wanna Go Fast!! |
08-30-2009, 02:54 PM | #24 |
At the body shop.
9.5:1 sb 400 th475 9inch cal trac bars and 325/50 drag radials
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 08-30-2009 at 02:56 PM. |
08-31-2009, 10:32 AM | #25 |
I saw a bb twin turbo,d,injected street rod that drives on the street and does the quater in 8 sec.was wild,I guess ther isn,t much power until the turbos wind up so he can drive it fairly normal
