09-30-2009, 10:07 PM | #1 |
HOW long until spring??
Bubba's recycling project
Found a bracket off a six cylinder Camaro which had been butchered to fit around a set of headers, I Did not have the rest of the pieces so I just built them. The bracket as found, And after repair
I already had the pulleys installed so I left the alternator on the inside pulleys and set the power steering pump to line up with the front pulleys
69 chevelle convertible 71-C-10 short-wide and low 64 C-10 custom shortbox "Bubba"s Recycling project" Last edited by bubba327; 09-30-2009 at 10:17 PM. Reason: Spelling --My bad |
09-30-2009, 10:09 PM | #2 |
Re: At Last- Power steering in a I-6
As mounted and finished
69 chevelle convertible 71-C-10 short-wide and low 64 C-10 custom shortbox "Bubba"s Recycling project" |
09-30-2009, 10:37 PM | #3 |
The lower alternator bracket which bolts to the block. It had been 'adjusted' in the past and was just about out of metal at the rear hole. The new bracket moved the alternator forward 1/4" which lined up the pulleys better
09-30-2009, 10:52 PM | #4 |
1 thing at a time is progress.
Nice work!!
Alan
Philippians 2:14-16 |
03-20-2010, 07:58 AM | #5 | |
03-20-2010, 11:22 PM | #6 | |
Daverod --this is MY lowering system... just remove the wedge and the coils collapse!!! think I need new rear coils. I wonder how much these have dropped naturally and which new coils I should get? Get 2 or 3 inch drop maybe??
03-20-2010, 11:50 PM | #7 |
SSN 706
Thats sweet looking. I have my stock springs if you want I'll send them to you. I put jeep ones on mine. Let me know and I'll make sure I still have them.Chrome in the Dome was lame. No bags, no frame dragers. Only one 63 and a couple 51's.
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 03-21-2010 at 12:42 AM. |
10-06-2009, 10:00 AM | #8 | |
Junior Member
I need to take a closer look at this. I had to add a two belt pulley to my alternator and didn't feel that was a good thing. Your's is much cleaner!
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! |
10-21-2009, 08:36 PM | #9 |
I went to double pulleys they seem to run smoothly with no trouble so far. I just love the power steering now only takes one finger. Here are some pic's of my set up, also my engine had the short water pump.---Vernski
10-21-2009, 11:28 PM | #10 |
SSN 706
Sweet engine. Makes you want a new carb and intake does'nt it Bubba.
10-01-2009, 12:42 AM | #11 |
nice work , funny I had to butcher mine to fit around my headers !!!
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
10-01-2009, 12:48 AM | #12 |
60-66 Nut
That turned out great Bruce. Have you driven it yet? Did you get the steering box bracket squared away?
10-01-2009, 11:29 AM | #13 | |
New gear box is in. Clearance is perfect with the 71 tie-rods New tilt auto column from a 77 Nova I had Recycled the 77 Nova brackets with some modifications. Working on a new bracket to hang the E-brake back under the column. Thinking about flipping the E- brake handle over and pointing it towards the passenger side. Would still be mounted flat under the column and right under the edge of the dash. .... still thinking about this ....Anybody have other ideas on E-brake options???
10-01-2009, 02:33 AM | #14 |
Whats the pump out of?
61 Apache 327 sb from a 63 vette |
10-01-2009, 07:41 AM | #15 |
Hollister, CA.
Great job man !!
I plan on coverting my truck to P/S as well...Got to keep my eyes open from some parts. Again, what was that pump off of ?
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
10-01-2009, 10:16 AM | #16 |
283 Drama Queen
Very clean work - well thought out, with clear pics.
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
10-01-2009, 10:50 AM | #17 |
Found the pump at a swap meet this last weekend. Cost me two dollars. Came with a power steering gear box which also cost me two dollars. The gear box has the same casting number as the new 71-72 gearbox I just bought. Oh well. I decided to go with a new gearbox just so reliability was not a question. I have a totally new front end and did not want the gearbox to be loose.
10-01-2009, 10:59 AM | #18 |
A shiny 71 crossmember
Installed with new rotors and calipers- Stayed 6 lug Used the 71 tie rods and remounted the 71 idler arm
10-01-2009, 01:45 PM | #19 | |
And if I did find a donor truck with disc brake calipers, could I just buy 6 lug rotors that would work with them? Thanks!
www.vancerutherford.com |
10-01-2009, 08:05 PM | #20 |
Bluesfella --CPP had a package on E-Bay which I bought for less than catalog price. It fit 71 & 72 spindles with 6 lug and used GM calipers. I have heard other guys have had trouble with CPP but I had no problems at all. 1971 was the first year front disc were standard issue. I also have a 71 so when I found a 1971 rolling chassis on craigslist I grabbed it. I can salvage the other stuff for my 71. Guys say 73 and up makes a better swap due to availability and rubber bushings .
10-02-2009, 02:02 PM | #21 |
Looks good bubba327. I got a 61 and I've been told I could use a 73 as a donor truck for the both the ps and pb. Whats your opinion since you do have a 63.
10-02-2009, 08:23 PM | #22 |
SSN 706
Nice progress.
10-05-2009, 04:41 PM | #23 |
E-Brake in basic position under Nova tilt column. Hanging where it clears and works well. More brackets need to be built
Removed the offsets from the brake pedal arm. This moved the pedal over away from the gas pedal. With out the clutch pedal the gas and brake were just too close. Welded on the larger foot pedal. Even says disc brakes on the foot pedal. New piece welded on the side is for the brake light switch to hit. Recycled a piece of the old 64 bracket. I left the brake pedal bump stop. Heated and bent the old tab back flat again (that held the old brake light switch) Welded on a new bracket facing out and welded on a new bracket on the arm so brake light switch is now accessible. . Original wiring reached the terminals
10-05-2009, 05:06 PM | #24 |
283 Drama Queen
Clean work.
12-01-2010, 08:06 PM | #25 | |
Ich möchte vroom vroom |
