Old 01-27-2010, 12:52 PM   #1
jgrisafi
Velocity Speed Shop
jgrisafi's Avatar
How can I tell what type of gears I have?
I need to make sure that the gears I have will hold up to 420hp and 400ftlbs of torque. Does anyone know the best way to tell which gears are which. I included a few pics of mine. Thank for the help guys.
My Build Thread ..... http://67-72chevytrucks.com/vboard/s...d.php?t=288143
My Garage ..... http://www.hubgarage.com/mygarage/OCD69
jgrisafi is offline   Reply With Quote
Old 01-27-2010, 01:01 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: How can I tell what type of gears I have?
I'm not sure what you mean by "which gears are which". You have a 12 bolt axle, with an open carrier. That means you do not have any kind of locker, or posi-trac.
I see that you have a GM carrier, and it appears that the ring gear is GM as well. I can't see the numbers on the rng gear well enough to determine what ratio you have.
What transmission will you be running? What rear tire height/width? This info will help give a better asnwer.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-29-2010, 07:30 PM   #3
jgrisafi
Velocity Speed Shop
jgrisafi's Avatar
If you could let me know where to look for the numbers you need please let me know. All I need to know is what gear set I have so I can either by the 3:73 I need or stick with what I have.
Old 01-29-2010, 07:33 PM   #4
jgrisafi
Velocity Speed Shop
jgrisafi's Avatar
I will be running a TH350, an sbc350 with about 400-420hp, 18x8front and 20x10rear.
Old 01-29-2010, 07:52 PM   #5
LONGHAIR
The numbers that are stamped onto the edge of the ring gear (in the 3rd pic you posted) will tell us the gear ratio.
As far as "changing them", I certainly wouldn't use the ones you posted in pic #4 as replacements. Not only are the obviously abused, installing "used" gears is even more complicated than new ones. This is best left to a professional and very few of them will touch used gears anyway. It's just not worth the risk of failure. New gears are only $150-$200
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 01-30-2010, 01:30 AM   #6
jgrisafi
Velocity Speed Shop
jgrisafi's Avatar
Thanks for the insight Longhair, I really do appreciate it. Asking this question really helped me out. As for the numbers on the ring gear, I will take a pic and get back with you. I'm just curious to know what the gears are. I guess I will just buy a new set of gears and be done with it. As for changing out the axles do you think it would be a wise decision to keep what I have, or buy new ones, depending on what shape there in of course? And Would it be a good idea to get a posi too?
