03-07-2010, 12:00 AM | #1 |
Future TOTM Winner
Specific 14 bolt disc brake/hub question???
Does anyone have any experience putting one of the many 14 bolt full floater disc brake kits on a newer style corporate 14 bolt axle? By newer I mean one that came out from under the 88-98 type body style (it's sort of a grey area on the exact year). This axle would have the SLIDE-ON style brake drum as opposed to the pressed on behind the hub style like the 87 and earlier. I have been told that the back side of these newer hubs are not machined flat and therefor don't accept the disc rotor swap as easily. Can anybody confirm or deny this?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
03-07-2010, 10:14 PM | #2 |
Re: Specific 14 bolt disc brake/hub question???
I did one on a 93,I used the weld on brackets from Rough stuff.GM used so many diferent venders for the brakes it is hard to get the bolt on brackets to line up,If you use the weld on ones you can put them right where you need them!!Goood luck!!
03-08-2010, 12:36 AM | #3 |
Future TOTM Winner
So did you just put the disc to the back of the hub like is normally done to the 87 and down? Did you clean up the mounting surface or have it machined or anything??? Thanks!
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 03-09-2010 at 09:47 AM. |
03-08-2010, 07:24 PM | #4 |
That just doesn't look right,Looks like a duelly rear or maby from a stake body?Looks realy wide.If it's from a single rear wheel truck,It should measure about 65" wheel flange to wheel.
03-08-2010, 08:57 PM | #5 |
Future TOTM Winner
I agree with you, probably a van or panel etc. To me the hubs don't look like dually hubs but I have been wrong before. Either way I like the width. It is about 68.5 inches from wms to wms which is real close to what my dana 44 will be with 8 lugs. Any info on the inner disc/drum mounting surface? Did you machine it or prep it at all on the one you mentioned???
03-08-2010, 10:28 PM | #6 |
Just cleaned it up real good with a die grinder with a 60 grit 3m disc and got it as flat and clean as I could.Then put on the rotor,centerd the caliper and welded it up!Good Luck!Hope this helped!!
03-08-2010, 12:35 AM | #7 |
Future TOTM Winner
I planned to use a weld on bracket anyway, the factory 4 hole bracket that the drum bolted to is about 5 inchs inset from the hub for some reason. Here are a couple pics for the heck of it.
03-08-2010, 11:35 PM | #8 |
Future TOTM Winner
Good to know, THANKS!
03-13-2010, 08:49 PM | #9 |
Beer Drink'n Knuckle Dragger
you seen these?
http://diy4x.com/cart/index.php?rout...&product_id=35
GOD BLESS MY BROTHERS & SISTERS THAT SERVE WITH US - 67 GMC Long-Wide 350/SM420 My BACON Wrapped Meatloaf Recipe |
03-13-2010, 08:53 PM | #10 |
oh and here's a writeup on how to install weld ons...but that link above is a bolt on kit
http://www.pirate4x4.com/tech/billav...b_disc_brakes/
03-15-2010, 12:08 AM | #11 | ||
Future TOTM Winner
03-15-2010, 01:42 AM | #12 | |
Glad the link helped out
03-18-2010, 11:36 PM | #13 |
It can be done. We make a kit for it..
Support The Board |
03-20-2010, 11:11 PM | #14 |
Future TOTM Winner
Awesome! I been on your website quite a bit, didn't realize that drink2many = Blackbird Customs though.
Your kit is on my short list of ones I would like to buy. Could you please give me a little more detail on what you do different between the pressed on and slide on styles. Is it just the cutout in the bracket to allow it to slide onto the axle tube? Is there something else???
03-21-2010, 12:33 PM | #15 | |
Support The Board |
03-22-2010, 09:25 PM | #16 |
Future TOTM Winner
Will do, Thanks!
