03-11-2010, 02:47 PM | #1 |
Criwn vic suspension idea!
I do not know about you guys, but lately I have been helping EASTNINEMOTO with a project, We are working on a 68 F@rd truck. I KNOW, I KNOW, it is a ford. Anyways, we used a 2003 - 2007 crown vic front suspension, it unbolts right off of the frame and basically bolts right on to the truck frame, i believe the outside frame rail measurements are 34". With this application, we used a police interceptor P71, it has the heavier springs in it, 700lb, versus the normal which is 400lb. comes standard with 12" brakes dual piston calipers, 5x4.5 bolt pattern, track width is 67.5.... aluminum crossmember and can be had for cheap, we bought a complete car running for 800 with 130000kms on it, ex cop car 2005. This is a very nice cheap alternative suspension for someone, I will post pics later.
James
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 Last edited by nuke1; 03-11-2010 at 08:44 PM. |
03-11-2010, 03:32 PM | #2 |
Re: Criwn vic suspension idea!
My front suspension is finished, but I would still like to see some GOOD pics of the setup/install.
Jeff |
03-11-2010, 04:14 PM | #3 |
and a few others
Interesting idea. I'd like to see some pics too.
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
03-11-2010, 04:22 PM | #4 |
I have seen this somewhere else and it is amazing. The guy was also putting a twin turbo 4 cyl diesel in, supposed to have V8 power and 30mpg.
03-11-2010, 04:31 PM | #5 | |
You Bet!, F@rd truck forums, carcrafter is his name, twin turbo isuzu 4bt1 motor, 400hp and 1000tq. crown vic front with a gm 14 bolt rear, 32.2 mpg. this is not where i got the idea but I have read his whole tid bit.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
03-11-2010, 05:49 PM | #6 |
James
thanks for posting this. i just ordered a crown vic front form the junkyard $300 including brakes and sway bar. the crown vic frame is 34" out side and the 55.5-59 is 34" out side. this looks like the perfect swap for front suspension |
03-11-2010, 06:34 PM | #7 |
Re: Crown vic suspension idea!
How does the 47-54 compare width wise ? Hmmmmmmm !
"I feel the need for speed!"... as soon as I am done with my nap. |
03-12-2010, 10:45 PM | #8 |
Cancer Survivor in the making.
The AD frames taper inward through the area that matters. That complicates adapting the suspension from anything that has parallel frame rails and even more so from anything that tapers differently.
Someone here said 28, another said 29.5 at the axle center line. On my suspension swap I ended up with a number that is between those two. While I don't think the margin of error could be 1.5 inches, production tolerances were not so tight that I'd expect mine to exactly match yours.
'55 1st GMC Suburban - '54 GMC 1-ton trailer puller (in process) - '54 GMC 1-ton Hydra-Matic - '47 Chevy AD COE and lots more rusty old iron. Steve@OldSub.com OldSub.com . MaxwellGarage.com . OldGasTowRigs.com |
03-13-2010, 12:03 AM | #9 | |
This Crown vic set up is still very cool. I'll be watching just for fun !
03-11-2010, 06:09 PM | #10 |
Hollister Road Co.
Is the ford frame 34 or 43 as the first post states?
03-11-2010, 06:14 PM | #11 |
ford frame is 34" on the trucks and the crown vic
03-11-2010, 06:18 PM | #12 |
Hollister Road Co.
Then it may well be a good alternative swap.
03-11-2010, 06:40 PM | #13 |
i belive the 37-54 is 28"
right now i am researching the crap out of this and have to many numbers in my head right now so i might be wrong |
03-11-2010, 06:53 PM | #14 |
This could be very interesting. With the recent Cash for Clunkers promotion, there are lots of these cars in the wrecking yards right now.
03-11-2010, 06:54 PM | #15 |
Hollister Road Co.
AD's are 29.5 at the CL of the front axle.
I don't know if this will help you but I did a C10 on a 58 frame http://www.thehollisterroadcompany.com/C10ifs.html It has a lot of measurements I had to do to get it to work Last edited by dwcsr; 03-11-2010 at 06:54 PM. |
03-11-2010, 07:11 PM | #16 | |
03-11-2010, 07:26 PM | #17 |
right now the only issue i see si the track width and the hub to hub width
i need to hit the junk yard and measure the hub to hub then i will know |
03-11-2010, 07:38 PM | #18 | |
Sudscribing
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
03-16-2010, 08:38 AM | #19 |
03-11-2010, 08:19 PM | #20 |
I'd like to see some pics too to see how the steering lays out.
03-11-2010, 08:48 PM | #21 |
Hey guys, the track width is 67.5. the distance between the rails is 34" sorry, my blunder. Remember these key words, CHEAP FOR THE PERFORMANCEm here is a few pics, the first on is lukes, the others I borrowed from another forum, carcrafter22 at the othe dark side of things. Thanks.I will see if I can get Luke to do a build in the alternative tinkerings forum, the only down side is he has snail speed internet, out in the boonies, we will see.
03-11-2010, 08:52 PM | #22 |
the track with is the to the out side of the tires or to the center of the tires?
03-11-2010, 08:56 PM | #23 |
I do believ that the track width is to the face of the rotor where the rims bolt on, correct me if I am wrong, but this seems right.
03-13-2010, 07:10 PM | #24 |
What was the other forum were the swap info came from? I have a wrecked crown vic. and this could be some good info for a future project.
03-13-2010, 07:35 PM | #25 |
Hollister Road Co.
What other years work for this or is it only 03 up
