![]() Join Date: Mar 2010
body mount kits... should I use polyurethane or rubber???
Getting ready to replace my worn out mounts and was wondering if there were any drawbacks on using polyurethane kits?
I Love Rusty Chevys
Re: body mount kits... should I use polyurethane or rubber???
Quote from VTblazer
The stock rubber style is going to ride a bit softer but will flex more when wheeling. Thread where I found it: http://67-72chevytrucks.com/vboard/s...y+mount+rubber
1969 K5 Blazer 1997 1500 Silverado Ext Cab Z71 2010 1500 Silverado Ext Cab Z71 |
Got the new poly kit sitting here ready to go in myself.
SKINNY TIRES RULE!
I'd go rubber, but I don't wheel my truck so I want it as smooth as I can get. If I were building something to go off-road, I'd probably go poly. I have heard that if you don't lube the poly mounts properly, they can squeak.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
![]() Join Date: Jan 2007
poly are also smaller than the rubber mounts so you will likely need to shim to get everything lined up again...
