04-28-2010, 10:45 AM | #1 |
disc brake swap
i am changing from 67 drums up front to 73-87 drop spindles and disc brakes. i have the spindles and ball joints on and now i need to do the tie rods. i guess i use 73-87 outers and 67 inners? which tie rod adjusting sleeves? there are so many to pick from. what is the best combo?
04-28-2010, 11:05 AM | #2 |
Under Construction
Re: disc brake swap
call Jeff at Classic performance parts. I believe they have conversion tie rods.
Jeff 888-522-8303 ext 118
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
04-28-2010, 11:07 AM | #3 |
Re: disc brake swap
thanks for the info!
04-28-2010, 11:41 AM | #4 |
67-72 parts collector,…
Re: disc brake swap
You need:
'73-'87 outers, and '67-70 outers (to use in the place of the inners so the threads will be opposite LH and RH),... and some adjusting sleeves that have 11/16" threads on one end (the 73-87 tie rod end),... and 5/8" threads on the other end, (67-70 tie rod end). Www.PerformaneOnLine.com sells the "conversion" adjusting sleeves. This is how I know,... (my '69 disc brake swap)
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 04-28-2010 at 11:47 AM. |
04-28-2010, 11:49 AM | #5 |
Re: disc brake swap
thanks lolife99, thats exactly what i was looking for. love your blz by the way.
04-28-2010, 11:53 AM | #6 |
Re: disc brake swap
is that a cut lowering spring? looks really short. i have bags and i think that your lower control arm is sitting as low as my bag and drop spindle on a 29" tire
04-28-2010, 11:56 AM | #7 |
Re: disc brake swap
could a 73-87 sleeve be welded to the 67 5/8 side? thanks for your help
04-28-2010, 03:55 PM | #8 |
Still plays with trucks
Re: disc brake swap
Not a wise idea to weld together steering components. Spend a few bucks and get the conversion sleeve so you know the piece won't come apart on you when you are driving down the road.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
04-28-2010, 06:10 PM | #9 | |
Re: disc brake swap
They are actually Ground Force springs in a Summit Racing box.
04-28-2010, 05:56 PM | #10 |
Re: disc brake swap
Any Kragen/O'Reillys will have a good supply of flared brake tubing with the nuts on them. Just bend it yourself. If you need to, you can one end off, add a different size nut and re-flare it.
04-28-2010, 06:11 PM | #11 |
Re: disc brake swap
thanks mclairmo, i will give that a try
04-28-2010, 06:13 PM | #12 |
Re: disc brake swap
lolife99, that is one sweet blazer, it has the perfect stance
04-28-2010, 07:59 PM | #13 |
Re: disc brake swap
im about to be doing this to my 67 and thought id chime in to clear some stuff up im not sure about. can i use stock uppers with 73 87 ball joints? 73 87 lowers or can i use stock lowers with the 73 87 balljoints? thanks
04-28-2010, 08:15 PM | #14 | |
Re: disc brake swap
No need to swap the entire arm,... unless you just want to.
04-28-2010, 09:15 PM | #15 |
Re: disc brake swap
really. thats awesome. so bolt in 73 87 balljoints up top and press in 73 87 balljoints below? add in some 73 87 drop spindles and im set with exception of tie rod conversion and 73-87 master cylinder? thanks again. also is this what you did? (stock arms)
04-28-2010, 09:33 PM | #16 | |
Re: disc brake swap
It's cheaper to just buy the drop spindles for the correct year of truck you are putting them on. Then there is no need to change balljoints OR tie rod ends. I wish I would have done that. It would have been much cheaper in the long run. (just the tie rod adjusters are $50/pair)
04-28-2010, 10:09 PM | #17 |
Re: disc brake swap
but considerin my 67 has drums id have to do some swappin around as discussed right? also i couldnt find the adjusting sleeves, could you link them to me? the ones i found said nothing about converting. do i just tell them what i need when i call to order or are they on the site somewhere?
04-29-2010, 06:49 PM | #18 |
Re: disc brake swap
also should i get the spindles for 1 inch rotors or 1.25 inch
04-29-2010, 07:20 PM | #19 |
Re: disc brake swap
04-29-2010, 07:40 PM | #20 | |
Re: disc brake swap
http://www.performanceonline.com/sto...cat=787&page=1 Part #HPAS6370
04-29-2010, 11:06 PM | #21 |
Re: disc brake swap
thanks fellas. i think im about to order some 3 inch spindles for the 1.25 rotors right now. probably the adjusting sleeves too. ill get the balljoints, calipers, and rotors local.
