heavy duty ft sway bar & brackets off of a 73 3/4 chevy f/s
![]() but will also fit the 1/2 trucks it's in good shape but i would replace the bushings while it's off they cost about 25 to $30. i will take $80.00 shipped for it .please reply in tread if interested .
i have 67/72 chevy truck parts f/s. |
Re: heavy duty ft sway bar & brackets off of a 73 3/4 chevy f/s
do you know if it will fit a 71 model 1/2 ton that has been dropped 5" in front?
'71 LWB c10-"WORK" in progress ![]() 385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall 2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better) 2013 best 7.39 2014 best-7.38 New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage |
i am not sure you may check with someone else that has did the same thing to there truck . and see if they are useing a stock swaybar.
billsbowtie, is that an 1 1/4 sway bar? just trying to see how much exactly what the bushings would cost me. if so ill take it zip 37184, just pm me later and we will work out the details.
thanks skeeterbug
![]() Join Date: Sep 2007
1 got 1 1/4 bushings from o reillies so theyre pretty readily available, I asked for a 78 chevy 3/4 ton 2wd. but the 3/4 tons came with 1 1/16th, 1 1/8 and 1 1/4 so measure carefully
1967custom Last edited by michael bustamante; 05-11-2010 at 03:29 PM. |
skeeterbug i just notice i put the wrong year in the title it came off of a 72 3/4 ton it will still fit but i just wanted to let you know. i will measure it and pm you in a few mins. bill
cool thanks
Real Projects never die
Skeeter, at one time i read about people not using the frame bracket, and mounting the bushing directly to the frame, thus taking like 2-3 inches out of the measurement on extremely dropped trucks, just a headsup on making it bolt up to a lowered truck.
Ill put it this way, ive got a few lawn ornaments ![]() ![]() My name tag says Ryan KansasTwister On other forums
walts, yeah ive heard of people doing that as well and since my truck has 5" of static drop in the front thats what i figured i will have to do.
thanks skeeterbug
