Resistance is Futile
TOO HOT; staying inside............................
![]() Sorry, it's not a truck, but if it goes well I will resurrect a truck and do that on this thread too. The Camaro has been lowered with real springs, all lines plumbed, and wired as if it had a fuel injected smallblock. 1/12th scale stuff is hard to find so I used 1/10th scale wheels which give it the 'on 22's' look. The trans has real metal shift rods, the rearend has brake hardlines and u-bolts bent from metal. I used some photoetch pieces for details and added stereo components. I built my fictional injection on top of the real intake manifold and added linkage, sensors, and rubber booted injection plugs. I fabbed a cooling shroud with electric fans and a fan controller. The ignition is wired just as a real car would be from this era. Anyway, this gives you the background and now some pics for you to catch up on. Many of the details are hard to capture.......
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
Re: TOO HOT; staying inside............................
Here are some pics of the paint process and the wheels. This was one of the 20 mock-ups I've done to see how everything fits.......I'm still modifying parts.
I source parts from anywhere.....hardware store, Home Depot, kit-bashing, and scratch building.
I'll try to update soon.
Truck and auto performance nut
nice detail work!
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
Thanx '68......that's why it's been a 9 year project.
I have test fit all my sub-assemblies and I have the core support fit in the body now. I 'boxed' the frame to make it look realistic and lost my reference points for the core location.
At this point I am trying to come up with a final assembly process so I dont screw myself and not be able to put some things together. It's getting close!!
can't wait to see the "completed" pics!
Redneck Hillbilly
Man that is one crazy detailed build. Awesome job so far.
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Very cool I am also into building models just not with as much detail as yours..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#10 | |
