GM ONLY BABY!!!
Which way do the engine stands go in?
I have had my Ls in and out so many times with so many combinations, I don't remember which way the original stands are suppose to go. Pointed part forward or back? Use the most forward holes or the rear most holes on the frame?
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
![]() Join Date: Aug 2004
Re: Which way do the engine stands go in?
which ones you got? stock? Aftermarket? What year truck?
OK, duh! Stock ones you said, I tried to use my stock perches on my lsx install but could not install the manifolds and headers with them in. I used some POL perches and they set the engine up about an inch, this doesnt make clearance up top any kind of issue.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! Last edited by Clyde65; 08-17-2010 at 04:06 PM. Reason: bad english again |
GM ONLY BABY!!!
I have a 72 GMC 1500 2wd, I am trying to use the original engine stands with Prothane mounts and TPI parts adapter plates. Cant remember which way the original engine stands go in and which position. I had a 350 sbc in it.
on my 65 I used the rear holes, I needed more room up front for the Rad and cooling fans. It is still a good 1.5" from the firewall even in the last holes.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
GM ONLY BABY!!!
You know how the one side of the engine stand is at a 90* and the other is slightly pointed, I have the point facing forward, is that correct? Thanks!! I guess I'll go pull it again.
does this shot help you?
GM ONLY BABY!!!
Not really, I need a pic looking down across the front crossmember. The factory assembly manual and service manual doesnt have any good pics either. thanks!
well, I am pretty sure they can only fit one way, however your wanting to know also which one goes to which side correct?
GM ONLY BABY!!!
Yes. I'm pretty sure they're in the right way but want to verify before going further because bolts won't go in the mounts thru stands.
THe more I think about it, the more I start remembering they bow a little right? not rediculously but they bow.
if this is correct, the bow goes toward the front of the truck, I guess pointing kinda toward the front.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! Last edited by Clyde65; 08-17-2010 at 05:03 PM. |
does this shot help?
GM ONLY BABY!!!
Currently mine are bowing back and mounted in front holes. Probably wrong.
from my searches here in the forum, they should be in rear and pointer forward for I6 and V8's.
GM ONLY BABY!!!
Heres what mine look like right now and the bolts will not go thru the stands and into the mounts. I might have the wrong stands?
#15 |
I think you need to move them back to the rear hole, then they should line up.
#16 |
GM ONLY BABY!!!
If I move them back to the rear hole then the single hole at the bottom does not mount in the crossmember, it hangs off the back of it about 1/2". Thanks again for your time and help Clyde65.
#17 |
hmmm, I will look at my dads truck tonight, he has those perches with a 350, I will let you know in the AM unless someone else can chime in.
#18 |
GM ONLY BABY!!!
#19 |
Old and crusty
![]() Join Date: Jan 2009
This is a trial effort on uploading pictures. If it works I'll come back with an explanation.
Dean Hey not bad for a rookie. These are the only pictures I have of the bare engine bay on my '64' Chevy. I removed a 230 inch 6 banger and this is where the perches were bolted. Hope this helps. Dean Last edited by dean jendro; 08-17-2010 at 09:28 PM. Reason: Additional info |
#20 |
Old and crusty
Here's another shot of the perch in the same holes as original picture excetp from a better view. It does hang off the back side of the cross member a little bit, but that's how they were. The second picture is side by side with the mounts I just got for my LS motor. Driver side looking down, right side toward tranny. Any other shots you need while I've got my camera out?
Dean |
#21 |
60-66 Nut
With the '63-'66 trucks, all the motor mount brackets (V8 and I6's) except for the 292, are located in the rear most holes from the factory. In the '67-'72 model years, the small block motor miount brackets are located in the forward holes, and the 230/250 I6 motor mount brackets are located in the rear holes. These are the factory locations.
chevydog66, by looking at your pics, I would say you need to switch sides on those motor mount brackets. They just don't look right to me.
#22 |
GM ONLY BABY!!!
I have a 72. There's no holes in crossmember for bottom holes of stands to bolt to if I switch them around. I'm so confused and tired of this. But thanks guys. What to do?
#23 |
60-66 Nut
Aside from trying to explain to Clyde65 the differences in motor mounts between the '63-'66's and the '67-'72's. All I was saying is you need to just switch sides....take the one on the left side and put it on the right side and vice-versa. I think that would have solved your problem.
#24 |
GM ONLY BABY!!!
I got it in the way the stands are in my pic but had to slot everything.
#25 |
GM ONLY BABY!!!
Dean, those are the mounts you purchased from me, correct?
