Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 09-08-2010, 01:15 PM   #1
66 4x4
S10/Blazer 4.3/T5 combos T5 question
I have a question, In the S10 and Blazers with the 4.3 and the T5 trans did any of the T5's have the Ford mounting bolt pattern? I know that the last few years for the T5 in the Camaro's and Trans am's with the 5.0 motor had a Ford mounting bolt pattern but looking for any info as to a 4.3,T5 bellhousing had this. I am putting a 4.3 in a Jeep CJ and want to keep the Jeep T5, But also want to keep the 168 tooth flywheel and the 5.0 bellhousing will only fit the 153 tooth. Thanks
66 4x4 is offline   Reply With Quote
Old 10-21-2010, 09:25 AM   #2
70BLAZERX2
Re: S10/Blazer 4.3/T5 combos T5 question
what you need i just sold one.. is a bellhousing out of a 80 AMC spirit or a CJ that had a manual trans with the old 2.5 iron duke 4 cyl.. This will let you run the 4.3 with the ford/jeep trans.
I sold it on ebay for $125 ...last month.
you can find one here http://car-part.com/
70BLAZERX2 is offline   Reply With Quote
Old 10-25-2010, 07:49 PM   #3
USSkoval
The Camaros and TA's never had a T5 with a Ford mounting pattern. They used the same bellhousing from '84-'92.
Was the T5 ever used behind the 4.3? My '91 4.3 doesn't have a T5, it's an NV3500, with the bellhousing incorporated in the tranny itself.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 10-25-2010, 08:19 PM   #4
70BLAZERX2
1993 thru 2002 V6 camaro's and firebirds have a T5 with a ford pattern on them..But its the 3400 / 3800 bellhousings..
The S10 used the T5 chevy pattern bellhousing up to 93 with the 2.8
all 4.3 has the nv3500 with intregal bellhousing.The 1st one is the jeep one
2nd is 93-95 camaro 3.4
Old 10-25-2010, 09:23 PM   #5
USSkoval
66 4x4 said 5.0 so that's the years I was responding to... but that's still very interesting. Why the heck would GM change the mounting pattern and bellhousing when they could just use the same parts as the older 2.8/3.1 cars?
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'88 K20 Suburban
Old 10-26-2010, 10:18 AM   #6
70BLAZERX2
well it was not really gm that changed that..Borg warner decided to make one main case after 93 -up..to save them a few million dollars as to not have to make more than 1 main case ...And they may have has so many ford left overs..that they told gm to change the bellhousings?
So if you get the jeep bellhousing like in my top pic..you can run a late 93-02 camaro V6 5 speed in about anything..with a V8 chevy. or 4.3
advance adapters want over 400 for the same bellhousing..find an amc origanal one fron the old 2.5 iron duke 4cyl.
Old 11-28-2010, 11:42 PM   #7
MalibuSSwagon
Then wouldn't the 1st gen S10 2.5 bells work just the same? I know those used the Ford style T5 as well.
MalibuSSwagon is offline   Reply With Quote
