Old 10-04-2010, 09:41 PM   #1
63chevyll
gets board easy.......
63chevyll's Avatar
07 Avalanche, Aluminum Lower A Control arms to Steel arms?
Anyone know the compatability of the newer GM trucks and lower control arms?
I have a 07 Avalanche with bad lower ball joints, which requires a complete new lower control arm to get the new ball joint
Do the 08 and up chevy 4x4's has cast or aluminum lower A Arms?
I was wondering if i could swap them out for a set of cast iron Lower arms, or some sort of lower control arm with a replacable ball joint. maybe aftermarket???
the Avalanche has struts and coil springs.
thanks if you have done this before
63chevyll is offline   Reply With Quote
Old 10-04-2010, 11:06 PM   #2
bwood
bwood's Avatar
Re: 07 Avalanche, Aluminum Lower A Control arms to Steel arms?
Do your originals have grease fittings? Usually the Moog replacements will have a grease fitting which will greatly extend the life. I was looking at Oreilly's site and they list an aluminum and a steel lower arm.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Old 10-04-2010, 11:56 PM   #3
63chevyll
63chevyll's Avatar
no grease zerk,
ill check out the Orelliy site
Old 10-06-2010, 09:54 PM   #4
63chevyll
63chevyll's Avatar
well Orelliy offers ball joints for both iron and steel arms, they list an arm but cant get the arm from a store. WTF
Old 10-08-2010, 11:26 PM   #5
63chevyll
63chevyll's Avatar
I cant believe nobody has been through this before.
Im gonna remove the alum arm and see whats the difference from that to steel
Old 10-12-2010, 12:53 AM   #6
63chevyll
63chevyll's Avatar
for anyones info, the steel arms are cheaper than the aluminum arms and they are direct fit into anything with an aluminum arm
