10-19-2010, 12:41 PM | #1 |
67 C10 Wiper Motor
Hi All.
New here. I have a 67' C10 short box with a seized wiper motor. I'm looking at changing it. Question is how do you get at the linkage under the cowl ? Does the cowl have to be removed ? Thanks. randy. |
10-20-2010, 10:09 AM | #2 |
Re: 67 C10 Wiper Motor
Anyone ???
10-20-2010, 12:04 PM | #3 |
Yes, carefully pull off the wiper blades, remove the cowl and you will see the linkage is held on with a snap fastener. You lift the end of the fastener and slide it up and the linkage can come off the wiper motor.
10-20-2010, 12:08 PM | #4 |
Old Skool Club
There are three nuts that hold the motor onto the cowl, and you gotta get them from underneath the cowl. It's up and behind the radio. Gonna have to get limber and flexible. You'll need 'em both.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
10-20-2010, 12:14 PM | #5 |
That's great, Thanks. I was hoping not to have to remove the cowl. Afraid of breaking the paint around the screws and bolts, oh well. Limber and flexible ?? It's been a long time since I've had to hang upside down on the seat to get under the dash...
Randy. |
10-20-2010, 08:43 PM | #6 |
The Older Generation
I have removed a couple of them without removing the cowl. I just put some masking tape around the openings above the motor arm and pry the clip off with a screwdriver. Have a magnet handy and when it starts coming off hold the magnet against it so it doesn't go flying. Lift the arms off with a stiff wire with an angle bent on one end. Remove the motor, install the new one and replace the arms and clip. The easiest way to replace the clip is to hold it in place with the magnet and push it on with the screwdriver... Works for me. LockDoc
10-21-2010, 09:36 AM | #7 |
Thanks Lockdoc
I'll give that a try tomorrow. Randy. |
10-21-2010, 11:31 AM | #8 | |
Your UncleBen
68 C10 shortbed -- Street/Strip |
