C35 Crew Dually
Blazer/burban rear bumper
i know i need one of the truck brackets but what one is it inner or outer?
i got the outer ones from an 84 85 gmc like mine but i think i got the wrong ones ![]() ![]()
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 |
Re: Blazer/burban rear bumper
you will need the inner brackets
Badass
You don't need the inner. They are like 50$ each new. Just bolt it in with the outers and put the inner bolts in the bumper for show.
I did this . It is plenty strong Posted via Mobile Device
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
C35 Crew Dually
ok? maby i have them on backwards because they dont seem to line up....
Badass
yea maby you got them wrong.
heres mine with just the outers. (its tucked in about a 1.5inchs) ![]() ![]()
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() Last edited by 3r!c84; 11-19-2010 at 04:51 PM. |
C35 Crew Dually
see in your second pic your hand...where you finger is. that is roughly where my bracket bolt holes are. they wont line up with the outer bumper holes at all....... seems way off :S?
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 Last edited by 1tonchevy; 11-19-2010 at 05:02 PM. |
Badass
it should be that in. i drilled holes 1.5 inchs back from the origanl ones
#8 | |
C35 Crew Dually
![]() truck looks Great BTW
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 Last edited by 1tonchevy; 11-19-2010 at 05:05 PM. |
you just need the outers.i ran a burb bumper for a few year's.i switched to a sport and only have outers.it's fine for look's.but,i wouldn't stand on it.the last pic is older showing the burb bumper...my 79 is just for look's.all it haul's is "a$$".
" Never look up a dead dogs butt." ![]() |
C35 Crew Dually
see my bracket sticks way over by the bed side almost.grrr lol i don't understand what im doing wrong :S Jimmy bumper and 84 truck outters hmmmm
C35 Crew Dually
I have to have the wrong bracket or something mine looks WAY longer than yours
Badass
Go back and get the brackets. Or find them off a bother truck
C35 Crew Dually
off the jimmy/burban or a 81-87 truck?
Badass
What ever u find that has the same bumper as yours. Don't matter truck or burb or Jimmy
#15 | |
C35 Crew Dually
#16 |
Badass
Lol lmc has them . The outers are like 20$ each. The inners are like 50$ !!!! Each
#17 | |
C35 Crew Dually
#18 |
TruckincrazY
Hmm, only the outers? I may have to take a trip to the junkyard to see what I can find!
#19 |
I love the way the tucked rear bumper looks, but if you get hit in the back by even a bicycle, it's gonna drive the bumper into the rear end of the bedsides, especially if you use only outer or inner brackets alone.
Basically whatever happens, if anything taps that bumper, its time for paint. Last edited by 78 Chevyrado; 11-20-2010 at 11:18 PM. |
#20 | |
Badass
#21 |
6.0 powered square
I'm using the inner burb brackets bolted to flat stock
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
#22 |
GoatLube Experss
![]() Join Date: Oct 2009
I only have the outer brackets on mine as well, most any thing that hits it from rear will probably be higher than my bumper any way so ,,,,,,,,,,,
no differance than have'n a roll pan like I have on my '88 S10 . also all three of my trucks need paint any way so hopefully they decent insurance .
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
#23 |
C35 Crew Dually
![]() other than a good clean up lol and some paint the truck i like it's look ![]()
#24 |
im assuming its the same for my 88 1 ton ? i was told that brackets from a blazer would fit but a suburban wont , is that right ? im needing all the brackets to fit a bumper like 3r!c84's truck
#25 |
Badass
Blazer and burb ones both fit. Only the outer brackets from them fit. You will need to find a truck with a sport bumper to get the inners. ( good luck with that) or order new inners. Or like me only run the outer brackets.
