11-22-2010, 07:55 PM | #1 |
cummins or 6.0 lq4 which one is better?
Been noticing a lot of lq4 and cummins swaps on here. Just wondering which one has the most advantages as far as gas mileage, power, etc.. Do they cost about the same to do? Can you use a 4l80e with a cummins? Gonna get used a lot for my spray business, so I want it to be able to hold up either way. Thanks for the replies....
11-22-2010, 09:37 PM | #2 |
Re: cummins or 6.0 lq4 which one is better?
LQ4 needs a computer to run, early Cummins don't. That right there is a major selling point for me. LQ4 is crazy expensive to buy, I'm getting 3 $1800 or so.
If you have the adapter you can bolt up a 4l80, but will need a stand alone computer to shift it, or go manual valve body. I'm a diehard Gm guy, but can't beat a Cummins.....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
11-22-2010, 10:20 PM | #3 |
[QUOTE=b454rat;4308660]LQ4 needs a computer to run, early Cummins don't. That right there is a major selling point for me. LQ4 is crazy expensive to buy, I'm getting 3 $1800 or so.
If you have the adapter you can bolt up a 4l80, but will need a stand alone computer to shift it, or go manual valve body. I'm a diehard Gm guy, but can't beat a Cummins.....[QUOTE] I saw that you were planning on doing a cummins swap here pretty soon. Just a couple of questions... How much does a good used cummins cost? Where is a good place to get a deal on one? What all is involved in swaping from gas to diesel etc...? |
11-22-2010, 11:26 PM | #4 |
if its a two wheel drive lq4/9 all the way, if its a 4x4 do the cummins
the ls series engines arent that hard to swap in as long as you use a stand alone harness or a camaro harness, the truck and suv harnesses have an anti theft feature i havent figured out yet..
11-23-2010, 10:44 AM | #5 |
They all have the anti theft feature in the PCM/ECM ( not the harness)after I think 2000/2, it just needs to be programed out, pretty easy for a tuner or someone with the software available.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! Last edited by Clyde65; 11-23-2010 at 10:45 AM. |
11-23-2010, 12:23 PM | #6 |
GoatLube Experss
why do you say 2 wheel drive LQ4 ? I'm want'n to put the 12V Cummin's in my 2 wheel drive dually, is there width issues ? the only ones I've seen were in 4X4's , I noticed they notch'd the frame for the AC. is this the issue ?
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
11-23-2010, 05:54 PM | #7 | |
<< like that one
11-24-2010, 10:22 AM | #8 |
thanks for all the replies guys... I think I'm gonna go with the lq4/4l80. Good power, decent mileage, and they're good for at least 200k miles. Hopefully, I can find a low mileage one for a good price.
11-24-2010, 10:42 AM | #9 |
I have had pretty good luck with LKQ here in North Texas, you might want to give them a call.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
11-23-2010, 11:15 AM | #10 |
thanks clyde, my girlfreinds dad has a 6.0 swapped 64 panel wagon, asked him after i posted and he told me,
11-24-2010, 06:40 PM | #11 |
Search here for the engine. http://car-part.com/
a LQ4/9 WILL NOT even come close to TQ outputs of a Cummins. Mileage will also be better in Cummins. Cost is where the Cummins comes into play. That and if you want an automatic you will need to have one built that was made to go behind a cummins unless you want to spend lots of money fabbing up something else. You can always get a NV4500 5 speed to go behind them also but need a better clutch than stock if you plan on putting some power out...which you will once you drive it. I have a good friend who is finishing up putting an Allison behind a Cummins in a 99 Silverado. Its been a PITA to say the least. Cummins is alot more expensive than going gasser. LQ4/9 on other hand is what Im planning on doing next year. These motors are excellent motors for building power reliably. Stock bottom ends will hold more than you will likely throw at it. Throw a nice spec'ed cam and set of heads and your sitting pretty. Just a cam will net around 60 hp if tuned right. You DO NOT need to go fuel injection with this setup either. You can carb it also as both Edelbrock and MSD have kits to convert and still retain stock coil packs with preset ignition curves. Look here.... http://www.jegs.com/p/Edelbrock/Edel...55239/10002/-1 The best thing is with the LQ4/9 you can keep the TH400 trans if you want with minor changes. You can also use stock harness if going FI and build your own. OR you can goto multiple places and have them custom make you one but are usually around $400-$600+ to get. Another option you have is getting what I got in my HD which is an 8.1L (496ci) motor and mate it to an Allison or a TH400. Trust me with the tuning I got on here its nuts. You have not driven one of these until you get an EFI Live tune and no TM anywhere. I am in between the two motors and leaning towards the LQ4 for gas mileage since I plow in winter and mud in summers with it. |
11-24-2010, 08:29 PM | #12 |
umm LQ9 by far its a modern motor getting you better MPG and HP..
11-24-2010, 08:31 PM | #13 |
6>8 Plugless........
In a dually? I think not. I'd put my dinosaur 12v up against a LQ9 in a heavy truck any day. Then go hook up the trailer and go run some hills.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 11-24-2010 at 08:32 PM. |
11-24-2010, 08:30 PM | #14 |
I wouldn't even mess with a gas engine for a tow vehicle, or a hauler if I was considering doing a cummins swap. Reliable, fuel efficient, and cheap power, 12v that is. What more do you need?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
11-25-2010, 12:37 AM | #15 | |
As far as using a 4L80E behind a Cummins...I whould not recommend it, as strong as they are it whould not last, They may handle 1000hp but it cant handle 750 ft lbs at 1400 RPM. A 47RE or a 48RE Dodge can be built stronger. |
11-25-2010, 02:15 PM | #16 | |
So what are people doing about the transmission in a cummins swap? Definitely want an automatic. What are most people paying for a good used cummins engine? |
11-25-2010, 09:36 AM | #17 |
I thought the lq4 was the Duramax??
For any type of towing I wouldn't use a gasser. I never owned a diesel, towed a lot with gasser's , but like already said, can't beat a Cummins for power, upgrading, economy, durability, etc. I'm getting a Cummins that is rated at 175 horse. Doesn't sound like a lot, but torque is 450-ish. Get a #100 fuel plate, those numbers go to 250-ish horse and 620 ft/lb of torque. For about $200. http://www.puredieselpower.com/catal...ate-p-451.html
11-25-2010, 10:13 AM | #18 |
You're saying the truck will get used for your business, right? The diesel would be better for towing and / or hauling, but you gotta think it through in terms of how long it'll take to get enough use out of the truck to recoup the investment.
The buy-in on the diesel swap is a little cheaper, but most people who do Cummins swaps don't leave them stock ($$$) and the transmission / drivetrain mods to support 1000 - 1500 ft/lbs of torque ain't free either. I'm eying up an LSx swap for my dually, because the only towing I do is a tow dolly or 20' single-car trailer, and seldom haul anything heavy (still think sometimes I bought too much truck for my needs but too late now). |
11-25-2010, 11:33 AM | #19 | |
11-25-2010, 11:47 AM | #20 | |
I would go whichever route is the easiest to afford and put the money you would be saving back into your business. Trust me when I say you will need the capital. |
11-25-2010, 10:55 AM | #21 |
Happy to be here
Another thing to factor in is fuel costs. Around here diesel fuel is still much higher than gas. Besides, who wants to fuel up at those stinking diesel pumps.
11-25-2010, 11:43 AM | #22 | |
If your getting a 6BT Cummins complete and running for $200 thats a HELLUVA a deal. Provided the better mileage you get in a diesel you will still be saving money even paying slightly more in fuel. |
11-25-2010, 12:35 PM | #23 |
Happy to be here
Not from what I have been told by several diesel truck owners. It will depend on the price in your region, but here in South Texas you will pay a LOT more for fuel.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 11-25-2010 at 12:36 PM. |
11-25-2010, 08:06 PM | #24 | |
To the OP: As far as a good automatic transmission, there are a lot of options. Some are expensive and others are affordable. Look for a 47rh in a 1994 or 1995 dodge with a cummins. This is a 3 speed trans with over drive and lock up, and does not require a computer to run it. You can use toggle switches or pressure switches to shift it.
11-25-2010, 12:50 PM | #25 |
up here in the middle of Oklahoma diesel is @ 50 cents more a gallon.....
what are some real world MPG numbers for the 6BT? And the LQ4? I know a few guys with newer crew cab 4x4 3/4 ton trucks with the LQ4 stock, they are lucky to Get 14MPG. I also know a guy with a 2001 dodge SRW 1 ton extra cab long bed, with a tune getting 20+MPG. I'm not familiar with what year Cummins are what, but to compare those 2 numbers, the LQ4 with gas @ $2.50 a gallon is 18 cents per mile cost verses the Cummins fuel at $3.00 a gallon is 15 cents per mile....I'm not sure if this is a apples to apples comparison, and the wear and tear parts replacement for the Cummins are probably going to be more expensive also.
CHEVY ONLY Last edited by joe231; 11-25-2010 at 12:50 PM. |
