12-14-2010, 12:05 AM | #1 |
Green club
Shreck's 6.0 build
Shreck, that is what my wife calls the truck, green but lovable
Never did any kind of build thread, many posts on this site but this project that I am undertaking with the truck I feel will help others considering this kind of swap and hope follows interest and involved in my adventure converting my pride and joy from a 350 to a 2005 LQ4 6.0 engine from scratch. I always considered swapping this engine in the truck, but an adventure into the unknown always kept me at bay, until now. The 15K mile 350 in the truck gave up, main bearing failure. Don't know why, but a suspected bad line bore in the block wore the bearings down prematurely. The plan I picked up a 2005 LQ4 from a friend with 317 heads and going the stock route maybe headers. It is at the machine shop now, getting fresh cam bearings, and a bore hone, and checking the block out for anything out of place. Going to use the stock truck cam, manifold, pan, aftermarket wireing harness, and tuned computer. Plan on going with a truck thermal fan, and accessory mounting. The trans, I have a stout TH700R4 in there now, giving a call to Bowtie OD for thier cable throttlebody LS1 brackets to run the non computer contorolled trans. All 3 main bearings looked like this, engine sitting on the stand after the teardown, and the sad part the truck in the driveway with an empty engine bay.... I will post pics as I go along, hope to have it done by end of Jan/early Feb....wish me luck
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
12-14-2010, 12:09 AM | #2 |
69' Chevy Stepside
Re: Shreck's 6.0 build
Sounds like a great build start! Too bad your 350 wore out only after 15,000 miles that sucks. The 6.0L will be a much better replacement!
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver |
12-15-2010, 12:25 AM | #3 |
Green club
The shortblock is at the machine shop today still, just doing prep work getting ready for it to come back so I can do the assembly and get the engine mocked up in the frame....
I will post pics when it comes back, I am going with the chevy orange block, valley tray and valvecovers, keeping the aluminum heads natural.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln Last edited by 67shortie; 12-15-2010 at 12:25 AM. |
01-13-2011, 07:18 PM | #4 |
Green club
Gees finally got a computer back up, the one in the family room went down mid December
Anyhoo, the engine is back from the machine shop, cam bearings installed and honed with new rings. I also make my own mount adapter plates from steel bought at Lowes ($10). I drilled the 4 holes for the LS block bolted them on, dropped the block in the frame and bolted it to the trans. I did however had to move the stands back to the 6cyl spot to make it work. I kept the trans in the stock location so I don't have to move my shift linkage and keep the driveshaft the same legnth, and all looks great I am so happy. I still have to mock up the truck pan, water pump and fan. I am going the clutch fan route instead of electric, it's cheaper for me that way. On a side note, a friend called me the other day and he scored a pullout '03 LQ4 with everything including the harness, computer, every mount/bracket, alt, starter, power steering pump, water pump/fan, truck pan, intake etc for about 1200, he is selling me all of the externals for $400. I did not hesitate when he asked to say yes.... I will get all of this on Saturday after work, and as soon as I get my photo program loaded on this I will post all of my pics I have taken as well.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln Last edited by 67shortie; 01-13-2011 at 07:19 PM. |
01-13-2011, 09:35 PM | #5 |
VA72C10
Looking forward to another LS in our trucks! Going to take a nice truck up another notch!
Looking for a 67-72 swb or blazer project in or around VA. |
01-19-2011, 11:03 PM | #6 |
Green club
Alright, a bit of an update to my progress here this last week or so. Got some pictures to share, spare block is in, placed the position of the block for keeping my trans in the stock location. This keeps me from having to modify my driveshaft, linkage, cooling lines etc so I can avoid complications and cost. I put the heads, intake, alt mount, and water pump/fan on just to see if everything looked good. Now after I get a new reluctor ring (mine is bent, dropped by previous owner) I can assemble the longblock and get this in the truck finally and start the harness conversion. Which I am not looking forward to, first timer here
The plates are quite long right now, I will cut them down when I get my final adjustments in place but I still have the front mount bolt sharing with the plate so it looks like that some of the aftermarket plates may have worked with what I have here. But doing it myself I am saving a few bucks and of course bragging rights
01-20-2011, 04:40 PM | #7 |
67cheby
looking good
01-20-2011, 06:07 PM | #8 |
Green club
Thanks, it's been easy so far but I probably just cursed myself. Man, I did not realize how dirty the engine compartment is, I have some detailing to do.
Early in the week I should have my new reluctor ring so i can have the machine shop do the install. then off to shortblock assembley, I hope to have this done by the end of the month I miss my truck
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln Last edited by 67shortie; 01-20-2011 at 06:09 PM. |
01-25-2011, 10:29 PM | #9 |
Green club
Started pre assembley on the 6.0 with verifying ring gap, everything checked out great. Also painted the Chevy orange on the new style valve covers I think it looks great myself.
Took the new reluctor ring to the machine shop to have it installed. Should be back tomorrow so I can get my bearing clearances checked on the rods and mains. Then off to final assembley, looking forward to dropping this in the engine compartment finally and getting the wireing harness modded for a stand alone.
02-01-2011, 06:43 PM | #10 |
Still Learning
Nice project! I'm interested in seeing how you do the 700r4 tranny.
Mike "69 Short Wide" My Project 86 Silverado Landen's Project Instagram: @mcbassin My Website C/10 Club Oklahoma Facebook Group Last edited by mcbassin; 02-01-2011 at 06:43 PM. |
02-01-2011, 08:43 PM | #11 |
Green club
For the 700R4 I have a flexplate from a LQ/4L80 trans that is hubcentric to the 700 converter, all I have to do is elongate the bolt holes to fit the older style converter and it has been said it will work with no issues. We will see, GM has a conversion flexplate that exists for about $50 that has the same part number mine has so I would imagine this is a production item already on a large scale to keep it inexpensive.
The TV cable, bowtieoverdrives sells a LS1 bracket assembley that will work with the cable operated throttle body, I still need to call them about adapting it to the truck intake. It does have an existing bracket bolted to it for the throttle cable and has another slot for I am assuming the cruise control. I am going to keep the harness hookups to the 4L60 in case one day the 700 gives up or I decide to just go that route. Just going to have the tuner remove the trans functions in the computer for now. I have a brake pedal lockup switch already existing with the truck.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln Last edited by 67shortie; 02-01-2011 at 08:45 PM. |
02-01-2011, 09:53 PM | #12 |
Green club
Here are a couple of pics from what I have done so far with the harness. 1st is the whole harness out on the floor and the 2nd is what I have done to the bulkheads and pins to make a standalone work. I know you can't see the lables I made but so far I have 12volts constant, 12volts keyed, engine speed, vehicle speed sensor, TCC brake switch (not going to use) serial dataport, fuel pump relay, MIL function (check engine light).
Tonight I am working on elimiating the fuse panel bulkhead C2, going aftermarket, want to keep from using the large factory panel. No pics yet of new fuse panel, just ordered them today from moser and allelectronics for relays/connectors and LED indicator lights.
02-01-2011, 11:10 PM | #13 | |
Still Learning
Your harness is looking very good too. I am not looking forward to that part of the money savings thing. |
02-02-2011, 02:19 AM | #14 |
Green club
Your welcome Mike, little more progress tonight.
Spent about 4 hours modifying my harness, what a mess of spaghetti but if you keep it organized you should have no issues. I do however have a couple of concerns with this harness. One is the person who took it out cut a couple of connections. One is from what I believe is the rear tank connections, the colors the wires are say rear fuel sensors and secondary pump relays. I think I am safe here, and the others say HO2SsignalB1S1 O2 sensors which I think are the rear O2 sensors that I will not be using. BUT these are what I am reading off of the website I mentioned above and may not be true to the harness I am using. One way to get this all sorted out is to install this on my engine and if one of the sensors don't jive I am in trouble No sweat though, nothing that can't be fixed. Anyhoo here are a couple of pics of the harness and what I was able to trash, and as I mentioned I am not using the electronic trans but will keep all of the connections in case I want to run with it in the future. That big greasy thing is the neutral safety switch and gear selector sensors? Anyway, it's being disconnected for the time being.
02-02-2011, 10:48 PM | #15 |
Green club
Well today I figured out at least what the harness lead that the person removing the engine cut from the truck did that I mentioned in a prior post, it was the front and rear O2 sensor plugs bank 2. SO I now need a front O2 plug and leads to complete this. Rear is none of my concern because those will be programmed out.
I have my intake with the harness tonight, plugging in everything to make sure it is complete and nothing is missing and so far so good minus the bank 2 O2 plug. Now off to online hunting
02-01-2011, 09:45 PM | #16 |
Hey, it looks like you're making good progress. I've been thinking that the 6.0 would make a great engine for my '69 GMC, but it's going to be a while before I need to worry about that.
02-06-2011, 01:27 AM | #17 |
VA72C10
nice job...and cool shop!
02-07-2011, 12:46 AM | #18 |
Green club
Thanks guys, and yes his shop is pretty awesome I must say myself. Pretty much everything we hobbiests and restorers need to start and finish a project plus more. I am just a little envious, the tools and space he has is something I only dream of...
A little more progress, wireing stuff. I was able to get one thing I ordered in this weekend a simple 4 fuse block so I can start eliminating the bulky factory setup. I need full battery power for orange wires and the pink get key on 12 volt. I labled the needed wires and followed guidelines from the LT1 website and got it to the point of the last step before hard wireing it to the truck for power. I still need a front O2 plug but i am one step closer. The intake on the floor looks like a monster of some sort, kids don't know what it is and think I am crazy
02-07-2011, 01:07 AM | #19 |
Truck and auto performance nut
Another 6.0 build!
I'll be watching.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
02-08-2011, 12:59 AM | #20 |
Green club
Yup, getting excited because it's all starting to come together finally. Tomorrow I am off to the local dealer and picking up some new head bolts, a pan gasket and off to engine assembley.
Meanwhile I wait for the rest of the harness odds and ends to be delivered by the big brown truck so I can finish the wireing and then start organizing the engine compartment. I am sending the PCM to the guy who runs the LT1swap site and have him plug in the things I need and get it back here. I still do need to do a bit of cleaning up and spraying some black on the frame just to make it look a bit better, ya know I need to look pimp . Need to buy a Walbro 255 and use the regulator on the truck manifold with a return line. If that is not an option I will run the Vette regulator, still do not know what's best so any guidance on this is very welcome. Also still trying to figure out what exhaust to run. I am tempted to run the thorley headers but they are pretty pricey so I may look for some trailblazer SS manifolds. I don't think they have O2 bungs in them so I would have to have the muffler shop cut and weld those in for me. Either way if all goes well I will get the long block in this week and start hooking things up.
02-09-2011, 12:57 AM | #21 |
Green club
Lots of progress today, started out at the local parts place picking up new head bolts and a few odds and ends. I also picked up a nice 4" bore ring bowl style comressor. I love this thing it is so easy to install pistons, even my mother can swing this task
Got the shortblock assembled. Went smooth and without problems, but the cam and chain are not in yet that's tomorrow. I took a few pics, a couple are of the main bolts, the stretch guage and the book that is giving me guidance because this new gen engine is a new experience for me. One is of the new way GM seperates the rod halves, breaks them instead of machining. This makes each rod extremely specific to one another. One is the endplay, very tight .002 which is on the small end of tolorance but passable. Anyhoo, more pics tomorrow, this is what got done today...
02-24-2011, 12:57 AM | #22 |
very nice truck!!
1970 Chevy K20 Custom Camper 1996 Chevy Impala SS 2008 Chevy Avalanche LT3 2003 Honda Accord EX 2001 Hewes Redfisher 16 Fighting Lady Yellow Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=324118 |
02-09-2011, 01:09 AM | #23 |
VA72C10
nice progress! Keep at it and you'll be driving in no time
02-09-2011, 01:11 AM | #24 |
Still Learning
Looking good man! I would like to try my hand at building one of these ls engines some day. I't still very intimidated by the changes since the old school sbc days.
02-09-2011, 02:00 PM | #25 |
Green club
Thanks guys for the props, I feel I am moving at a snails pace on this project
The LS engine was pretty intimidating to me too at first, but if anyone has had thier hands in a GEN 1 family this engine with a couple of exceptions will be very familiar and easier in some aspects. The only thing one has to do is read and read some more then on to hands on which that's what side of my brain likes so once I do it once I can do it again if that made sense Today, more shortblock assembley, cam, chain, windage tray, pickup, pan valley tray etc so off I go....I will post pics later.
