Old 12-16-2010, 01:55 PM   #1
pope
pope's Avatar
Talking My Detroit Diesel powered 61 K20 project!!
This is my 61 k20 Chev project. I wanted something different from the rest of them out there and to keep it all GM, so I fit a turbo charged 4-53 Detroit Diesel under the hood
pope is offline   Reply With Quote
Old 12-16-2010, 05:15 PM   #2
Mechanic77
Re: My Detroit Diesel powered 61 K20 project!!
Way too cool!
Pro Touring 1964 C10-Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=441627
Project '65 Short Step Daily Driver http://67-72chevytrucks.com/vboard/s...d.php?t=661948
Mechanic77 is offline   Reply With Quote
Old 12-16-2010, 05:32 PM   #3
rambler
MOVE OVER
rambler's Avatar
wow!
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 12-16-2010, 05:39 PM   #4
onequickchevy
onequickchevy's Avatar
Nice fit! Is the radiator big enough to keep it cool? ( I know jack about diesels, but I thought with the high compression they would run hotter?)
Slowly but surely getting it done.
onequickchevy is offline   Reply With Quote
Old 12-17-2010, 11:35 AM   #5
pope
pope's Avatar
The radiator (63-66) type is plenty big enough for, in fact the electric fan didnt run too much this past summer!
Old 12-16-2010, 05:39 PM   #6
Altec
Getcha Pull
Altec's Avatar
Very nice. A 4-92 swap is something I want to build. Something I can use to drag cummins truck around with, while making a noise that scares small children.
Gotta love that 2-stroke sound.
My uncle has a 3-53 I want to swipe one of these days. Stuff it in a mini truck.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 12-16-2010, 06:44 PM   #7
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
2 stroke diesels can make decent horse power, but not so great torque. They are noisy and have their own sound for sure.
Ryan
1969 Chevy milk truck
Old 12-17-2010, 12:05 AM   #8
Altec
Getcha Pull
Altec's Avatar
I don't know about that man. I always noticed that the ratio of horsepower, to torque to be pretty impressive on the 2-strokes. Better then the 2:1(-Ish) on most 4-strokes. I just haven't seen much in the way of tuned up ones. Do they fall on their face when really cranked?
No doubt on the sound! After seeing Convoy Duck, and Maximum Overdrive I knew I had to know more about these mills!
Although a Twin-Six peaks my interests too.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Old 12-17-2010, 12:16 AM   #9
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Very cool and unique. You gonna leave it a flatbed? I really like the look of the truck originally, I'd had a really hard time changing that if it were mine.
fryer1979 is offline   Reply With Quote
Old 12-17-2010, 11:39 AM   #10
pope
pope's Avatar
they only went as big as the 71 series with the 2 ,3, & 4 cylinder engines. I have seen the 4-71 and even 6v53 twin turbos in pickups now!
Old 12-16-2010, 06:41 PM   #11
Dieselwrencher
Very cool build! The 4-53's are very reliable. We have one in a push back at work that gets used 6 times a day to push 160,000lbs+ 727's up a slight grade on the ramp. Poor thing sure is under powered, but gets the job done.
Ryan
Old 12-17-2010, 11:45 AM   #12
pope
pope's Avatar
They are in fact reliable if taken care of, and really easy to work on. Theyre not torque monsters at low rev, but it definately pushes the truck around good! I really enjoy driving the truck, and people sure take notice when it goes by! I don't have jakes yet, but that definately is on the list!
Old 06-13-2011, 09:18 PM   #13
Monty
we have a locomotive tug where i work powered by a 4-53 and that poor thing has to move 400,000+ # locomotives day in, day out. it'll move more than it can reliably stop...
one place i worked had twin Mountain Logger skidders with 4-53 power but one had a turbo/blower and one just had the blower. it was kinda interesting running them side by side. the one without the turbo was kinda handy on the landing because it made power a lot faster, but the turbo powered one would walk away from it on the longer pulls.
the only issue i've had with any of them was when one of the skidders got some ice or frost build-up in the blower at sub-zero temps and broke the blower drive shaft when we tried to start it.
Monty is offline   Reply With Quote
Old 06-13-2011, 11:45 PM   #14
56taskforce
56taskforce's Avatar
Ah yes my first memories of the sounds of Detroit were of Garrett skidders echoing through the woods only to be sounds of the past memories echoing in my head as I pull wood to the landing with a Cat or a Deere.
No need to say turbo/blower as all the two cycle detroits had blowers, being two cycle the only way to clear the cylinder is to push new air in with a blower. turbo or non turbo need be all you say.
56taskforce is offline   Reply With Quote
Old 12-17-2010, 12:44 AM   #15
Maxxd07
Maxxd07's Avatar
Does it sound like this but with one more cylinder? As in do you have jake brakes on it?
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
Old 12-17-2010, 03:49 AM   #16
Dieselwrencher
Jake brakes would be sweet! It doesn't look like his has them. Usually there is an aluminum spacer in between the head and the valve cover, that is the Jake Brake housing. His engine doesn't look like it has it. I could be wrong though. I really like how the cab and front clip are so nice for the age. Not severly rusted, or beat to death. It is a very cool truck!
Ryan
Old 12-17-2010, 04:04 AM   #17
padresag
I drove my 64 4 x 4 panel for 18 years with a 453 in it. I didn't drive it far enough any more to get it warmed up properly and that is a problem for these. for 18 years I never turned the radio on.
they require the right gearing to get the best performance out of them.It was the most dependable and economical eng that I believe that i have had save for my old 911t years ago
ron
padresag is offline   Reply With Quote
Old 12-17-2010, 11:55 AM   #18
padresag
now what do you want a jake for, just to be noticed?. mine did have one on it once upon a time
if you really have to work that truck, you will notice the heat rise pretty quick if you don't understand it. the heads don't like high heat
ron
Old 12-17-2010, 12:14 PM   #19
pope
pope's Avatar
I am well aware of what the heat can do to the head on these engines and how these engines like to run! I have seen many cracked heads from over exertion! I live in Montana, the jakes are nice for the terrain that surrounds me. I climb over a 6,500 foot mountain pass daily to get to work. The engine might as well slow me down as well as speed me up.
Old 12-17-2010, 01:47 PM   #20
padresag
how many ft. alt are you starting at. with the compression that these engs have and the light duty truck it should hold it back pretty decently descending without a jake.
what are you running for a trans.. I did have a np 5 spd. od. in mine along with a 205 t/c(ind). the 3-4 split had to great of an rpm range which made it more difficult pulling a good load uphill. there were times pulling 16,000 lbs thru the fraser canyon that at the bottom of the hill that I would just put it in second and put it on the pin at 2950 and just let her go-no temp difference, but let them lug a little and that temp climbs pretty quick. these little motors can only do so much, but used wisely will pretty well do whatever that you ask of them.
I also did have a 4core rad with eng fan and an electric backup, which worked when required
in 18 years the only thing that I had to replace was an oil cooler that leaked into the rad.
dropped the pan once to replace the pan gskt and it was the cleanest eng that I have looked into
ron
Old 12-17-2010, 02:34 PM   #21
pope
pope's Avatar
My house is at around 5200 feet, and where I work is around 4800 feet. I have a np542 transmission with the T221 t-case and 4.57 gears in the eaton rear.... I definately need an overdrive and have a 3 speed brownie, but run out of space for it. I have been looking for an O.D. medium duty trans to run, I just haven't found any that are close to me yet. That 64 panel of yours must have been something! How did you come to own it?
Where the hell did my coffee cup go?!!
Old 12-17-2010, 02:51 PM   #22
padresag
By rondavid at 2008-10-09
looks like mine sat in there a little higher than yours, but just thinking about it, you must have a body lift as you have a later chassis
I ran 3:73 and 33" tires on mine and at 55-60 mph on the highway it was nice, right in the range; good for passing, good acceleration. you are never the first one off at the traffic light unless you have your boot in it, but one catches up fairly easy.
yours will run quieter than mine due to the turbo. they say mine sounded like one of those early greyhound buses going down the road. Everybody knew though who was coming down the road, they didn't have to look
ron
mine was a 1/2t, I also put 3/4 axles under it
when I pulled the detroit the frame went up 2 3/4" and when the 283 went in it only went down 1/4".
Old 12-17-2010, 04:48 PM   #23
Dieselwrencher
Very cool! Do you have any pics of the whole truck?
Ryan
Old 12-17-2010, 05:04 PM   #24
padresag
he does. right at the top in his first frame. just click on the thumbnail
ron
Old 12-17-2010, 10:03 PM   #25
Dieselwrencher
ron
Ron, I was asking you.
Ryan
