04-03-2011, 12:25 PM | #1 |
Vintage 4x4s
Making a trailer from a Pickup
This is a rustfree slightly dented good box on a C20 heavy spring optioned leaf truck so I might as well do it right.
Has anyone made use of the brake system with a surge coupler? The main question is do surge couplers like this have good pressures for the brakes? http://www.tiedown.com/aactuator.html Also has anyone seen a V mount surge coupler? Most seem to be designed for a 3" single square tube like a boat trailer tongue. Backup relief solenoid needed? Just leave the pinion in the rear and let it spin?? PS, this is how you move a nonrunning truck without having to have someone steer it around
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
04-03-2011, 01:44 PM | #2 |
Re: Making a trailer from a Pickup
You don't need any solenoid with most surge brake mfg's or anything attached to the truck. if building a trailer out of new stock i would also consider using the new single unit axles that bolt or weld to the side rails. they come complete. they eliminate the axle. Pretty cool. they are made by Timbren. they are avaiible to 3500 lbs per side. from 400 lbs. We sell them but they availble most places
http://www.timbren.com/aeon-rubber-springs.htm Last edited by mbgmike; 04-03-2011 at 01:47 PM. |
04-04-2011, 09:23 AM | #3 |
Vintage 4x4s
Thanks for the response, I will keep that in mind for future trailers. I plan on using the dana 60 and factory suspension in this trailer.
Still looking for other input...
04-04-2011, 09:55 AM | #4 |
Seems like a waste of a good truck. Find a 73 up to do that with and sell this one.
04-04-2011, 10:55 AM | #5 | ||
Vintage 4x4s
04-04-2011, 10:03 AM | #6 |
Usually brakes are only required over about 3000 lbs. I'll assume that the trailer will weight 1000 or less. The rear axle and springs on a 3/4 ton was probably only rated for about 2000. How much are you thinking of hauling with it and do you really need brakes?
Also it's pretty easy to weld a piece of square tubing in when you pinch the frame at the front. Bridge the A frame with another piece of tubing and attach the inboard end of the square tongue extension to it. You are adding a T shaped assembly to the middle existing pinched frame rails.
Saskatoon, Saskatchewan Canada Last edited by StingRay; 04-04-2011 at 10:21 AM. |
04-04-2011, 11:26 AM | #7 |
True you can't be too safe but frankly I've hauled plenty of trailers and never had a problem with the light ones with no brakes. I built a trailer like you want to from a bunch of crap I had for a buddy of mine. They work great. I've used it lots of times behind my own 72 and never felt I needed trailer brakes. FYI I did the tongue as I descibed and it worked great. Like you said you get that extra bit of tongue length.
Saskatoon, Saskatchewan Canada Last edited by StingRay; 04-04-2011 at 11:27 AM. |
04-04-2011, 01:18 PM | #8 |
I had a long bed trailer a few years ago, loaded it just like my truck and never had brakes on it, didnt need them, my 3/4ton truck had plenty of brakes for both.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
04-04-2011, 02:08 PM | #9 |
Vintage 4x4s
So just check/change the diff fluid and call it good? Let the pinion spin?
04-04-2011, 02:48 PM | #10 |
Hasn't been a problem for the one I built 15 years ago.
Saskatoon, Saskatchewan Canada |
04-04-2011, 03:36 PM | #11 |
I removed the brake stuff, but other than that nothing.
06-24-2011, 08:34 PM | #12 |
Vintage 4x4s
I might do this to a coil spring truck sometime also. I've heard they don't make as good of trailers, is that true?
06-24-2011, 10:04 PM | #13 |
Cruzin
i built a trailer with a 86 short bed. I cut a small pie cut in both sides of the frame and bent the frame in toward each other, i bought an A frame coupler from tsc and welded/bolted it to the frame. I used the factory wiring and lights, works great.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
06-24-2011, 10:11 PM | #14 |
I hear they sway a lot and shouldn't be used... Leaf spring is more stable...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
06-25-2011, 12:07 AM | #15 |
I have a radical idea!
I've got one with coils and helpers, and it does great, but they may sway without helpers (I bought mine this way).
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 06-25-2011 at 12:12 AM. |
06-25-2011, 12:33 AM | #16 |
Everytime I see one of those I get a little choked up. Yet another truck that didn't get to be somebody's hot rod.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
06-25-2011, 09:03 AM | #17 |
BlahBlahBlah
I bought a 69 Chev C10 with the optional leafs in the rear for the sole purpose of making a trailer with it. I had heard leafs were better for a box made in to a trailer. The rest of the truck is totally shot.
Nother one of my "someday projects"
06-25-2011, 09:17 AM | #18 |
i dont see a need for brakes on such a small trailer, just another possible problem on the road
you could hookup an altenator to the pinion of the rear and run a refrigerator for longer road trips
06-25-2011, 11:03 AM | #19 |
neat idea. I would of never thought of somthing like that.
Doug Looking for a 67-72 short bed driver..... |
06-25-2011, 12:56 PM | #20 |
Cruzin
the possibility's are endless
08-19-2011, 09:17 PM | #21 |
Vintage 4x4s
Wondering now if I should remove the axles from the Dana 60 so it doesn't have to spin them?
08-20-2011, 09:43 AM | #22 |
If you're still thinking about surge brakes, look at this setup:
http://www.ufpnet.com/Actuators/tabid/54/Default.aspx The surge brakes were hanging up on my now 10 year old bass boat. I finally figured out it was the brake rod in the actuator that was rusty and hanging up in the master cylinder. Long story short I orded a whole new A-60 actuator. I couldn't believe how easy it was to install. The surge brakes are over-ridden by the back-up light. Instead of a 4-pin straight trailer connector you use a 5-pin with the 5th pin connected to the back-up lights. When you put your truck in reverse the back-up lights turn on and powers a solenoid on the back of the surge master cylinder which opens up a path for the brake fluid to flow back into the reservoir. Pretty simple really. I couldn't believe how easy it was to install. The online place I got it from sells a weld-on mount for the A-60. With that in place it is two pins, a brake line connection, then bleed the system with a screwdriver. 10 years after buying the bass boat I read the surge brakes manual. You're supposed to push up a lever when you park your trailer so the brake rod doesn't get corroded and hang up.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
10-04-2011, 08:06 PM | #23 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=43855069 LWB Fleet 1994 Buick Roadmaster 1994 GMC Sonoma |
08-20-2011, 11:04 AM | #24 |
Vintage 4x4s
^ thanks for the link. Looks like a good product, how much $$ do they run?
08-20-2011, 03:50 PM | #25 |
I think it was $180 plus shipping for the actuator assembly
