Old 04-14-2011, 04:59 PM   #1
skip99
skip99's Avatar
fiberglass headliner build 51 chevy
OK, can't find one anywhere that will work, so, gonna attempt to make one, I already started ordering stuff, got some mold release on the way and glass stuff,
my roof is about 2 inches wider and longer than stock, so, gonna make a mold on the outside of the roof, and then cut it so it fits inside, cut where it overlaps and reglass to make one piece. I might even do the back or the roof down to bottom of window, so I have glass curved corner panels to cover.
I KNOW this is gonna be a mess, so I'll offer to make a couple extras if anyone with a larger than original roof, for a 47 - what ever fits. wants one. you pay material and shipping. PM me.
this is assuming it turns out ok !!lol!
Tami's 51 build
http://67-72chevytrucks.com/vboard/s...d.php?t=428878
skip99 is offline   Reply With Quote
Old 04-14-2011, 10:21 PM   #2
FFredo
Re: fiberglass headliner build 51 chevy
This is going to be easier then you think. You can control the mess by making a small dam around the outside perimiter of the roof. Use card board and tape to hold any run off. Work from the center out in all 4 directions to help the mold follow the curve of the roof.
I've made many a motorcycle seat pan using glass. Best advice I can give you is make sure to use parts A and B, not parts A and A.
Don't ask....
FFredo is offline   Reply With Quote
Old 04-15-2011, 04:42 AM   #3
55dude
55dude's Avatar
i would find a rusty cab and cut the roof off for a mold so it could be flipped upside down to make headliner, that seems much easier.
55dude is offline   Reply With Quote
Old 04-15-2011, 12:54 PM   #4
cajundragger
I tried to glass one.
I made a whole headliner out of tape and cardstock, glassed it, and about 15 minutes later it all fell out on the floor. So good luck. It was a PITA and I never got it to work. So now I have a roddoors one.
cajundragger is offline   Reply With Quote
Old 04-15-2011, 01:37 PM   #5
MrDude_1
sounds like it may work.
however, you're making a mold on the outside, when what you want is the shape on the inside.
instead of doing it like that, why not just glass the inside?
you would do it just like the "custom car" guys do for their subwoofer enclosures.
first cover everything in the cab you dont want resin on with plastic sheet.
then cover the area on the roof with several layers of tape.
apply some resin directly to the roof, and with it a bit tacky, put some lightweight mat up. do one small area at a time until you have a whole layer across the roof.
now you can add on to any weak areas there, but once thats done, carefully take it off the roof.. in general, one layer is plenty strong to hold its shape.
with it now on the ground, you can flip it over and glass the inside up... then you can cut/sand/etc....
this should work out alot better then making a larger copy of the outside shape, then trying to fit it inside the sheetmetal.
MrDude_1 is offline   Reply With Quote
Old 04-15-2011, 04:10 PM   #6
cajundragger
thats what I tried to do. the weight of the glass pulls itsself off.
Old 04-15-2011, 04:50 PM   #7
MrDude_1
hmm. instead of glass, perhaps use something lighter first, like fabric?
personally i have only done it on vertical surfaces or small out hangings( like "bumps" in a wall).. never something so large upside down.
Old 04-15-2011, 05:16 PM   #8
All59
All59's Avatar
Skip,should of done it when you had the top off then you could of made a mold then a part and it would be a perfect fix.Give Dan a call at www.smart-parts.ca 250 769 9198 they use to make one.His a pic of the one I make for 55-59.
All59 is offline   Reply With Quote
Old 07-17-2020, 11:37 AM   #9
slammed57
slammed57's Avatar
sorry I know its a old post,does anyone know if they are still making these headliner ?
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 07-18-2020, 10:52 AM   #10
MARTINSR
MARTINSR's Avatar
Damn that looks cool!
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 07-25-2020, 09:11 AM   #11
Atommik
Atommik's Avatar
I used the outside of the roof to make my fiberglass head liner. After fitting I added some 3/16 metal rods on the back side to help it hold its shape. I used 2 layers of glass. Should have used maybe 3-4. Maybe wouldn't have needed the reinforcement if it was thicker. I covered it with thin foam and headliner fabric. I have some pics of it on my build page on this site. Starting at post #164
Atommik is offline   Reply With Quote
Old 07-25-2020, 05:33 PM   #12
slammed57
slammed57's Avatar
thanks bud, I'll check it out
My 57 current build
Old 07-26-2020, 02:48 AM   #13
b-mac
b-mac's Avatar
I've personally seen one of these on the showroom floor at Bowtie bits.
https://www.bowtiebits.com/store/sto...Category_ID=27
For the time, and the cost of fiberglass materials, and the itchy forearms, I'd say it's probably worth the money. But I guess I don't have to ship it.
The old split headliner is cool in my opinion.
b-mac is offline   Reply With Quote
Old 07-17-2020, 12:42 PM   #14
_Ogre
_Ogre's Avatar
did you click on link or try to call them?
shop air compressor timer
Old 07-17-2020, 01:36 PM   #15
slammed57
slammed57's Avatar
I did, but no response, was hoping maybe he sold the molds to someones else or maybe someone came up with something similar
My 57 current build
