Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 04-15-2011, 09:05 PM   #1
Newtz67
Newtz67's Avatar
Newtz '68 Burb
So we went ahead and picked this up today! Always wanted one, finally got one!
Newtz67 is offline   Reply With Quote
Old 04-15-2011, 09:15 PM   #2
dougo
dougo's Avatar
Re: Newtz '68 Burb
Nice burb and congrats! Any plans to make changes? Love the white walls.
Doug
'72 GMC K2500 Suburban 4x4
dougo is offline   Reply With Quote
Old 04-15-2011, 09:23 PM   #3
Newtz67
Newtz67's Avatar
Re: Newtz '68 Burb
For now leave as is. Except for the interior which needs a lot of clean up. Mostly we will just clean it up and cruise for now. And thanks btw!
Old 04-15-2011, 09:30 PM   #4
Newtz67
Newtz67's Avatar
Re: Newtz '68 Burb
I just dropped this thing in my driveway a couple hours ago. I haven't traced it out yet but there there is a handle below the dash just to the right of the steering wheel that says overdrive. Is this for real? It has the original 292 with the three on the tree. If so, how does this overdrive work with the tranny? Thanks.
Old 04-15-2011, 11:20 PM   #5
jbclassix
Junk Yartist
jbclassix's Avatar
Re: Newtz '68 Burb
When you do trace it out, TAKE PICTURES!!!! There have been after market overdrives available since fifties (maybe earlier?) I know that some 4x4s with the t-18 had an overdrive that bolted on
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 04-16-2011, 12:22 AM   #6
Newtz67
Newtz67's Avatar
Re: Newtz '68 Burb
Right on, I will! I'll take some pics tomorrow.
Old 04-16-2011, 12:09 PM   #7
71gmcburb
71gmcburb's Avatar
Re: Newtz '68 Burb
i' try a heatgun to try and release the adhesive if thet doesn't work then use a puddy knife, utility knife and elbow grease once the garpet is off use Goop off to get rid of the remaining glue
a wise man once said "There are only two real rules to life...
1 - Don't sweat the small stuff
2 - Everything is small stuff
71gmcburb is offline   Reply With Quote
Old 04-16-2011, 01:10 PM   #8
Newtz67
Newtz67's Avatar
Re: Newtz '68 Burb
Thanks guys!
Old 04-16-2011, 02:36 PM   #9
vectorit
What?
vectorit's Avatar
Re: Newtz '68 Burb
I have good luck using these on various stuck on stuff.
Gum Out carb cleaner, and Goof off bug n' tar remover.
I'd start out mild, such as hot water and soap. Then, step it up gradually with various brushes and scotch brite pads.
When you decide to go with the harsh stuff, start out on a spot that is out of site.
I've also removed dried up glue like that with a fine wire brush on a drill, just go along very lightly so as to not damage the paint.
All depends on how dried up it is, crustier the better since it will flake off. If it's still gummy, then you are in for more elbow grease.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 04-16-2011, 03:29 PM   #10
Newtz67
Newtz67's Avatar
Re: Newtz '68 Burb
Thanks Vectorit. Ya it's pretty dry. Hopefully it's not too bad.
Old 04-16-2011, 07:13 PM   #11
CG
BlahBlahBlah
Re: Newtz '68 Burb
Ive had a 67 with overdrive and I have a 69 right now with overdrive. The 67 handle was chrome and said overdrive across it and the 69 handle is black plastic and it says overdrive on it.
I dont remember for sure but I was thinking the spids on them both said overdrive.
Old 04-16-2011, 10:33 PM   #12
jbclassix
Junk Yartist
jbclassix's Avatar
Re: Newtz '68 Burb
I really want to see pictures of that OD!
-Jeremy
Rebuilding an NP205
Old 04-16-2011, 10:49 PM   #13
C/10 King
C/10 King's Avatar
Thumbs up Re: Newtz '68 Burb
Newt, I love the photos, if you want some stock hub caps give me a call.
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 04-16-2011, 11:37 PM   #14
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Re: Newtz '68 Burb
68??
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 04-17-2011, 01:21 AM   #15
C/10 King
C/10 King's Avatar
Re: Newtz '68 Burb
Originally Posted by KevsClassics View Post
68??
Okay Kevin, very funny.
C/10 Rene
1971 Short Fleet
Old 04-17-2011, 01:35 AM   #16
Newtz67
Newtz67's Avatar
Re: Newtz '68 Burb
I'm interested...
Old 04-17-2011, 01:34 AM   #17
Newtz67
Newtz67's Avatar
Re: Newtz '68 Burb
Sorry man, I've been busy all day. I did take some pics though. Not sure how clear they will be, if you want more from another angle let me know.
Old 04-16-2011, 11:36 PM   #18
KevsClassics
TILT COLUMN GURU
Re: Newtz '68 Burb
Very nice Newt. BB plans in the future?
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
RIP EL JAY
Old 04-17-2011, 01:36 AM   #19
Newtz67
Newtz67's Avatar
Re: Newtz '68 Burb
Haha, nope. Bone stock for a while anyway...
Old 04-17-2011, 02:29 AM   #20
bad_turbo
turbo enthusiast
bad_turbo's Avatar
Re: Newtz '68 Burb
Nice! Nice! Nice!
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 04-17-2011, 01:23 PM   #21
Newtz67
Newtz67's Avatar
Re: Newtz '68 Burb
Originally Posted by bad_turbo View Post
Nice! Nice! Nice!
Thanks! The po tried to start it and a couple valves stuck. Yesterday we pulled the head and cleaned it up then reassembled it. I have never seen old gas do something this bad. The valves were extremely stuck. Some of the chambers had varnish almost a 1/4 in. thick. Hope to get it fired up today!
Old 04-17-2011, 01:50 PM   #22
jbclassix
Junk Yartist
jbclassix's Avatar
Re: Newtz '68 Burb
That thing is AWESOME!!!!!! If I remember, you just use the OD like you're shifting into 4th. That thing would be SICK with that power train left in it!!!
-Jeremy
Rebuilding an NP205
Old 04-17-2011, 01:56 PM   #23
Newtz67
Newtz67's Avatar
Re: Newtz '68 Burb
Yes sir, that's my plan leave as is. It's exactly what I wanted, the overdrive is just a super cool added bonus!
Old 04-17-2011, 01:59 PM   #24
Newtz67
Newtz67's Avatar
Re: Newtz '68 Burb
And a couple pics of us bolting the head back on late last night.
Old 04-17-2011, 01:55 PM   #25
Newtz67
Newtz67's Avatar
Re: Newtz '68 Burb
Here's a couple pics of it. I wish I had gotten some close up pics of the gunk, but oh well. If you look closely you can see the valves with no rocker on them are stuck down. Also note the gunk build up on top of the pistons.
