Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > Engine and Drivetrain > LSx Related
Closed Thread
Old 03-28-2011, 01:54 AM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
6.0l LQ4 to old school tranny
I want to make sure I have this right:
2004 LQ4(not sure what trans was behind it, I forgot to ask) I am posting a pic so that maybe it will help with what I need to know:
I need to adapt my th350 to the 6.0 If it did in fact come with a 4l80e then I should be good as far as spacer and bolts correct? If not then I need to get the spacer and bolts correct? Then I need the flat flexplate and drill holes for the th350 TC? When I go to mark the holes in order to drill new ones, does it matter where on the flexpalte they are drilled? Should there be a certain distance from the factory holes?
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline
Old 03-28-2011, 03:56 AM   #2
softballnrd27
Re: 6.0l LQ4 to old school tranny
For the VSS will this one work with the stock computer? I am going to run Autometer procomp gauges and this is the recommended one for GM.
http://www.summitracing.com/parts/ATM-5291/
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 03-28-2011, 09:25 AM   #3
Shon
Need to determine what flexplate is on the motor. if it has a spacer already then you will just have to drill holes for the TC. If it doesnt have a spacer then you will want a crank spacer.
link to just the spacer pictured above
If you want all new stuff I ship these out:
TCI Flexplate and spacer
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline
Old 03-28-2011, 03:45 PM   #4
Shon
We use them on TH350/400s and I dont see why they would not work with a 700R4, the bolt pattern for the TC is the same.
Shon is offline
Old 03-29-2011, 10:53 AM   #5
jkade
jkade's Avatar
http://www.gmpartsdirect.com/
GM PART # 12621399 $44.42
That has the flexplate, spacer, and bolts. All you will have to do is do a little grinding with a die grinder on the new flexplate to match you converter. The bolt holes are close but you have to open them up a little. Working fine on my LQ9/th400 and you won't beat the price!!!
You can see here what I am talking about.
jkade is offline
Old 03-28-2011, 03:42 PM   #6
shortbed70
shortbed70's Avatar
Do these flexplates work with 700's and th 400's also?
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline
Old 03-29-2011, 02:43 PM   #7
67shortie
Green club
67shortie's Avatar
My engine came off of a 4L80 so the flexplate had the correct adapter already there so all I had to do is elongate the converter holes to mount the 700 to it.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline
Old 03-29-2011, 03:08 PM   #8
clinebarger
You should not have to mess with the converter bolt holes on a "4L80E" flexplate
Is that what you got from GM parts direct? If so, Its wrong, Looks like a 4L60E flexplate. It should look like this, Notice the 6 converter bolt holes.
clinebarger is offline
Old 04-01-2011, 03:49 PM   #9
clinebarger
I was wrong, You do have to open up the holes a little, I dont know why GM would change that on the 4L80E from the early ones.
Old 04-04-2011, 11:06 AM   #10
jkade
jkade's Avatar
The 6 bolt converter for the 6.2 matched the holes perfect.
jkade is offline
Old 04-04-2011, 11:04 AM   #11
jkade
jkade's Avatar
That was a flexplate I had laying around just to see how far the holes were off. I used the one in the kit. The one in the pic will work as it was a dished plate as well but I did not have the spacer.
jkade is offline
Closed Thread
