Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 06-01-2011, 09:41 PM   #1
trusty72
trusty72's Avatar
70 Suburb build.. my first documented build
ok i got the body for 500 bucks, its pretty nice , needs seats and rockers replaced. I had the lwb frame with 350/350 so i am gonna try to have a solid dependable driver in a couple weeks..
1972 super cheyenne
1970 Suburb
trusty72 is offline   Reply With Quote
Old 06-01-2011, 09:43 PM   #2
trusty72
trusty72's Avatar
Re: 70 Suburb build.. my first documented build
the cab pic is my 72 super cheyenne ive put on hold for the suburb. And please someone tell me how to make the pics bigger..
1972 super cheyenne
1970 Suburb
Old 06-12-2011, 09:41 AM   #3
1956cameo
1956cameo's Avatar
Looks like a nice project. If you are using an image host site you will need to edit the picture and resize it to a larger size. If you uploaded the pictures directly to the truck site then I am not sure what to do.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
Old 06-13-2011, 12:01 AM   #4
trusty72
trusty72's Avatar
Thank you. I used photobucket and this is the best i could do, sorry. If anyone needs to know exactly what is required to put a 67-72 suburban on a 67-72 lwb frame, these pics show step by step from front to back. Picture #1 is the front body mount, lines up perfectly. Picture #2 is an actual suburban frame mount that i was lucky enough to get with the body. Just drill 4 holes per side after the body is located with the other mounts. Picture #3 is the middle bed mount , just drill hole over about an inch from the original. Also note the front and second bed mount on the lwb frame must be removed along with the rear cab mount before you set the body on. Picture #4 is as simple as drilling a hole in the frame when the body is centered. This will be the rear most mount for now until i graft in the suburban rear frame stub. This is not necessary, but will provide mounting for the rear bumper, and give more frame for that last body mount to sit on. See picture #5 to see where this will be.
1972 super cheyenne
1970 Suburb
Old 06-13-2011, 12:03 AM   #5
trusty72
trusty72's Avatar
On a side note i resized the pics to 260% on photo bucket and it didnt help a thing. im lost.
1972 super cheyenne
1970 Suburb
Old 06-13-2011, 12:18 AM   #6
BlackTopMotors
Check your cameras setting. Most can be set to a finer resolution...fine...super fine... upload a pic directly here...I think that may work. Just a thought (not a photo expert)
BlackTopMotors is offline   Reply With Quote
Old 06-13-2011, 07:03 PM   #7
1956cameo
1956cameo's Avatar
Not sure what the deal is with the pictures either. I use photobucket and have never had that issue. Great information on the truck to burb frame conversion.
Old 06-14-2011, 09:22 PM   #8
trusty72
trusty72's Avatar
Thank you, i thought it might help the next guy that tries to tackle the swap.
1972 super cheyenne
1970 Suburb
Old 06-14-2011, 10:40 PM   #9
Monty
about the pics...i think if you copy and paste the [IMG]pic url[/IMG] tags directly into your post, you will get the larger pics. hover your mouse over the picture in PB and a drop down box should pop. select the [IMG] one and click on it. it should say 'copied'. then just paste it in your reply.
Monty is offline   Reply With Quote
Old 06-15-2011, 08:11 PM   #10
trusty72
trusty72's Avatar
ok i will try that thank you.
1972 super cheyenne
1970 Suburb
Old 06-20-2011, 03:25 PM   #11
trusty72
trusty72's Avatar
Well I took it on its maydem voyage today it ran good. Ill post pics when I can
1972 super cheyenne
1970 Suburb
Old 06-20-2011, 04:00 PM   #12
trusty72
trusty72's Avatar
<a href=http://s1221.photobucket.com/albums/dd461/drag791/?action=view&current=2011-06-03_22-28-22_85.jpg target=_blank><img src=http://i1221.photobucket.com/albums/dd461/drag791/2011-06-03_22-28-22_85.jpg border=0 alt=></a>
1972 super cheyenne
1970 Suburb
Old 06-20-2011, 04:04 PM   #13
trusty72
trusty72's Avatar
1972 super cheyenne
1970 Suburb
Old 06-20-2011, 04:01 PM   #14
trusty72
trusty72's Avatar
http://i1221.photobucket.com/albums/...2-28-22_85.jpg
1972 super cheyenne
1970 Suburb
Old 06-20-2011, 04:02 PM   #15
trusty72
trusty72's Avatar
1972 super cheyenne
1970 Suburb
Old 06-20-2011, 04:06 PM   #16
trusty72
trusty72's Avatar
1972 super cheyenne
1970 Suburb
Old 06-20-2011, 04:07 PM   #17
trusty72
trusty72's Avatar
1972 super cheyenne
1970 Suburb
Old 06-20-2011, 04:08 PM   #18
trusty72
trusty72's Avatar
1972 super cheyenne
1970 Suburb
Old 06-20-2011, 04:10 PM   #19
trusty72
trusty72's Avatar
1972 super cheyenne
1970 Suburb
Old 06-20-2011, 04:11 PM   #20
trusty72
trusty72's Avatar
1972 super cheyenne
1970 Suburb
Old 06-20-2011, 04:16 PM   #21
trusty72
trusty72's Avatar
Well I got the pics figured out. The ole thing still needs a lot of work, but everything under that old body is new or rebuilt. Not bad for an empty shell of a body a couple weeks ago if I do say so myself
1972 super cheyenne
1970 Suburb
Old 06-20-2011, 06:07 PM   #22
trusty72
trusty72's Avatar
Helper #1
1972 super cheyenne
1970 Suburb
Old 06-20-2011, 06:08 PM   #23
trusty72
trusty72's Avatar
Helper#2
1972 super cheyenne
1970 Suburb
Old 06-20-2011, 06:09 PM   #24
trusty72
trusty72's Avatar
Helper #3
1972 super cheyenne
1970 Suburb
Old 06-23-2011, 11:14 AM   #25
trusty72
trusty72's Avatar
Does anyone know what color wire goes to the coolant temp sending unit and does it come from main fuse box harness or somewhere else?
1972 super cheyenne
1970 Suburb
