Old 06-11-2011, 12:57 PM   #1
chevy_layin_frame
layin pinch on a 65
whats up guys im new to the forum i have i 65 that im building rite now i want it to lay pinch weld on 22s. i came across this thread yesterday and i have a few questions. http://67-72chevytrucks.com/vboard/s...d.php?t=269019 it says all he did was a 4 inch z and lowered the body mounts an inch and he is lower than the pinch how is that possible cause ive been reading u have to cut an inch off the frame to hit the body and it dosnt look like he touched the frame at all??
chevy_layin_frame is offline   Reply With Quote
Old 06-11-2011, 01:53 PM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: layin pinch on a 65
I think it is because the body mount rubber is at least an inch tall, so in theory you could solid mount the cab, and the rocker would be level w/ the frame rail.
if you have the cash you could go with a porterbuilt dropmember, and would not have to do the z
Old 06-11-2011, 01:56 PM   #3
roconet
he brought the body line down an inch with the body drop,instead of bringin the frame up an inch by cuting it.my guess.im runnin the porter dropmember front n 3 drop spindles on 22s with 35 series tire n im bout 1/4" from pinch fully aired out.close enough for me. (for now)
roconet is offline   Reply With Quote
Old 06-11-2011, 03:13 PM   #4
broey
Square
broey's Avatar
how did you get to 1/4 inch? did you install nylon body mounts that are thinner or something?
Squarebody Syndicate
broey is offline   Reply With Quote
Old 06-11-2011, 03:20 PM   #5
sams60gmc
sams60gmc's Avatar
My set up is 3'' Z with 2'' stock floor body drop. Lays rocker.
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline   Reply With Quote
Old 06-11-2011, 04:47 PM   #6
chevy_layin_frame
do u have any pics of your frame or your build??
Old 06-12-2011, 02:06 AM   #7
64shortc10
64shortc10's Avatar
What's up guys! Here is my input on this situation. I have a 64 short bed fleet Porterbuilt Streetrods dropmember. 3 inch spindles. Slam bags. I lowered my cab mounts 3/4 of an inch. My pinch weld is still on the cab and is holding my frame rails from touching the ground by a 1/2 of an inch. See my build thread to see! http://67-72chevytrucks.com/vboard/s...d.php?t=225314
Tony from Norcal
64shortc10 is offline   Reply With Quote
Old 06-11-2011, 03:12 PM   #8
broey
Square
broey's Avatar
you can lower the cab mounts an inch to lay pinch, you are just gonna have problems with transmission clearance in the cab. and also, your motor is going to be really high up and make hit the hood. I haven't seen a picture of that truck with a hood on yet.
Old 06-11-2011, 04:44 PM   #9
chevy_layin_frame
ya my original plan was to z it 3 1/2 inches and run 2x4 tubing under the cab but i saw that he didnt even touch his frame rails and hes hittin body so i was just wondering how he did it but looks like im just gonna run the tubing that way i can just lay rocker. im not really worried about the trans in the cab cause im gonna have to do somethin with that either way but i dont want any probs putting my hood on
