Old 07-07-2011, 09:14 AM   #1
scot 6 feet eleven
scot 6 feet eleven's Avatar
60chevy 4.6 police interceptor chassis
60 chevy cab
66 chevy front
50 gmc box
1997 crown vic 4.6 police interceptor drive train
its in mock up ,in these pics -- its now apart cleaining up the fire wall and patching the floor up
scot 6 feet eleven is offline   Reply With Quote
Old 07-07-2011, 01:07 PM   #2
KroAutomotiveInc
KroAutomotiveInc's Avatar
Re: 60chevy 4.6 police interceptor chassis
that things pretty sick looking cant wait to see more done!
KroAutomotiveInc is offline   Reply With Quote
Old 07-07-2011, 10:48 PM   #3
scot 6 feet eleven
sand blasted floor - welded some metal in --- brused on some rust killer then undercoated--
i had to modify the frame so the 24's no longer rub
Old 07-09-2011, 09:03 PM   #4
vgnope
vgnope's Avatar
thats a bad ass idea u have goin.. i had a 97 crn vic p71 packaged too.. prob w ur hood cut out, u can fab some metal in like th 4x4 guys do.. kinda hump th wheel well look..man this is sick..
vgnope is offline   Reply With Quote
Old 07-09-2011, 09:40 PM   #5
Woogeroo
crazy... reminds me of the never ending FrizzleFry C5 vette/c10 truck hybrid project.
-W
Woogeroo is offline   Reply With Quote
Old 07-11-2011, 08:52 AM   #6
scot 6 feet eleven
the 4.6 isnt anything pretty to look at so the cut out hood was a after thought... originally i was gonna have the grille with 6 inches of hood and fenders mounted out front and have the motor all open. so that i could see all of the 24's
im going to take prob 4-5 inches of metal and trim the edges to make it look more finished---
it was too dang hot this last weekend didtn get alot done-- im welding up the holes in the firewall right now-- i guess ill just make new holes where i need em to run the 40lbs of wire that needs to go back in it for the computer and fuel injection etc
Old 07-11-2011, 10:38 AM   #7
Pop's C-10
Pop's C-10's Avatar
This is cool...you running back fenders of any kind...it would look cool if you rasied tha box alil & used something like a trailer fender ..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 07-11-2011, 11:06 AM   #8
scot 6 feet eleven
heres what has inspired this build the open wheel look , but since im 6'11" i need to fit and i want my wife and daughter to be able to ride too ..
im leaving it open wheels in the back too and will piece it in so that it forms to the frame--- right behind the cab i prob will build a step or something to make it look more finished.
Old 07-11-2011, 11:09 AM   #9
scot 6 feet eleven
heres my open wheeled rat rod i just finished and sold
model a 454--9 inch --air ride chassis---
Old 07-11-2011, 02:47 PM   #10
Pop's C-10
Pop's C-10's Avatar
that is sick...
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Old 07-11-2011, 11:10 AM   #11
scot 6 feet eleven
heres the pics
Old 07-11-2011, 03:05 PM   #12
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Cool project, and another cool one you just sold. What was that coming off the engine into the body through the roof? Just an old sickle for looks?
Ryan
1969 Chevy milk truck
Old 07-11-2011, 03:25 PM   #13
scot 6 feet eleven
You know how rat rodders use skulls etc ? For the shifter
i thought a scythe would be meaner and badder than the normall skull shift knob , so i used a scythe, was to heavy for the shifter so i used it for a e brake handle check out the tlamp i used old street sign i filled with 12v leds and had trhe brake light hooked to the hand , when i parked it i turned on the green guy... Ok i need to focus now on chevys lol this is a chevy forum
this rat rod was built ford tough with chevy stuff --if i use a ford motor in a chevy whats the slogan there? Built a chevy with some other stuff?
Old 08-18-2011, 11:12 PM   #14
scot 6 feet eleven
Name:  60CHEVY 4.6 POLICE INTERCEPTOR 009.JPG
Name:  60CHEVY 4.6 POLICE INTERCEPTOR 012.JPG
firewall cleaned up smoothed out , jambed blue , column mounted in , . wire hareness plugged in , wow lots of wire time to do a wire tuck. mounting the booster an d pedal next , trying to make this look nice!!
Old 08-20-2011, 09:47 AM   #15
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
more! more!
Old 01-05-2012, 11:04 AM   #16
scot 6 feet eleven
i drove it out of the shed on its own power, ive kinda been slacken on working on it. i coach my daughters basketball team that takes up alot of my free time
Old 01-05-2012, 12:47 PM   #17
E911manager
Man this looks way to familar!!! How did you get it to sit so low? Channel the cab? I dont see your cab mounts either.. Curious how you did that too.. Oh and did you use the Ford wiring harness?
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice
http://67-72chevytrucks.com/vboard/s...d.php?t=492640
E911manager is offline   Reply With Quote
Old 01-05-2012, 01:05 PM   #18
scot 6 feet eleven
I used the chassis 97 crown vic , i used all the wiring clipped off all that was not needed and tucked it under the dash , its not channelled , i took out the coil springs, im bagging it --- so its sitting dropped postion --its pretty darn low considering i have 24's on it
Old 01-05-2012, 01:08 PM   #19
E911manager
Ok, that explains it. I am about to start a similar wiring nightmare. Its amazing how the caprice and crown vic chassis are similar..
Old 01-05-2012, 01:24 PM   #20
scot 6 feet eleven
It wasnt to bad -- i had the wire all laying loose cut the whole body off left just the cowl and dash --started it up one more time before i unplugged it all -- then plugged all back in and started looking at things like power windows ahhh chop that etc and kept cleaning it up shrink tubing the ends i cut, will be funny if i ever have a check engine light and have some one plug into the obdii connector and tell em to punch in a 97 vic police car lol
Old 01-05-2012, 01:27 PM   #21
E911manager
Yep, I thought the same thing with my project.... You might get stranger looks then I will... Especially from die hard Chevy and/or Ford fans that cringe at the site of a Ford engine in a Chevy...
Old 01-05-2012, 01:39 PM   #22
scot 6 feet eleven
Last year i bought 2 crowns one was 1400.00 the other was 350.00 one was a car one was a tooth , the tooth was 1400 oww. Im making something cool looking and im not gonna have 20k into it
crown vic 350.00
cab free
1950 chevy box 50.00
misch front body parts 200.00
24inch wheels and tires 500.00
wheel adapters to make em fit this chassis 120.00
mixing ford and chevy priceless
all american motors!!!
Old 01-05-2012, 04:39 PM   #23
E911manager
OK, I give up what is a tooth??
Old 01-05-2012, 05:26 PM   #24
scot 6 feet eleven
a crown for my tooth in my mouth was 1400 you would think a car would cost 1400 and the tooth 350, thats just wrong!!!
Old 01-05-2012, 05:32 PM   #25
E911manager
Sorry I am slow... Well it is gonna be a sick ride.. Love the roadster approach...
