Old 09-04-2011, 11:15 AM   #1
tazattitude
tazattitude's Avatar
Widened wheel tubs
Anyone have pics of their stock looking widened wheel tubs for a 66 Fleetside?
Looks like I'm going to have to widen mine. From what I can tell, they at least have to be widened so the inside edge lands on the wood and not a bed strip.
Anyone make widened fiberglass (or metal) stock style tubs (wheel house)?
Thanks again!
By the way, I did a thread on this about a year ago, but didn't know if anything new has come up.
TAZ
BUILDS
1966 GMC Suburban
1963 GMC Suburban Patina frame-on FOR Sale
1966 C10 Short Bed (2010-11)
Monthly Updates
2015 C10 Pics with my '72 Montego GT 429/521 build
1963 Pro Street C10 back halved. Frame off I did back in 1990
Pics / Video
tazattitude is offline   Reply With Quote
Old 09-04-2011, 04:03 PM   #2
shrunken66stroker
shrunken66stroker's Avatar
Re: Widened wheel tubs
You don't have much wood between the stock wheel tub and the next bed stip. If I remember right it's only about an inch, but if that's all you need it will be worth it. I widened mine by 2 1/4" but I also made a raised bed floor that's probably not going to be topped by the original style wood kit, so I wasn't worried about where the inside edge of the tub was going to fall. I just measured for some 12" wide tires and put the support where I wanted then measured how much to widen the tub. I'll figure out the bed wood when the time comes. Check my build thread about 4 pages from the end and let me know if you have any questions.
shrunken66stroker is offline   Reply With Quote
Old 09-04-2011, 05:33 PM   #3
PGSigns
PGSigns's Avatar
I am doing a set now that we are making 2 inches wider by using 2 tubs. Mine were thin and a little beat up on the inside but the side that met the bed were good. I got a pare from Top Banana and cut the first inch off of them and then cut three inches off the old ones. The fit was almost perfect, the stampings are very close.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-05-2011, 06:15 PM   #4
blackmopar
Jimmy
i looked at top banana site and couldnt find tubs - im needing to widen mine too but was thinking of running a 2" strip down middle - twice the welding and smoothing though so Ive been stalling big time - i like your idea better taking 2 making one!
blackmopar is offline   Reply With Quote
Old 09-06-2011, 09:27 AM   #5
vin63
It's Better With Nitro
vin63's Avatar
I used two sets of inner fleetside wheel wells to do mine. Just in case, here's a couple of photos of mine right after I finished widening them.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 09-06-2011, 10:02 AM   #6
tazattitude
Looks great Vin. Looks like you didn't line up the areas where the hole lines up with the bed strips. Any problems? Or did you just smooth that out?
@blackmopar
I just ordered a set from TB about an hour ago.
I did a search for 'house' on their website and it brought them up.
TAZ
BUILDS
1966 GMC Suburban
Monthly Updates
Pics / Video
Old 09-06-2011, 02:46 PM   #7
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: Widened wheel tubs
Give me a couple weeks or months!
I'll post mine!
http://67-72chevytrucks.com/vboard/s...d.php?t=321173
Then:
And now:
These tubs and floor less the NOS bottle, fuel cell, and bowtie emblem:
Or this floor with the tubs:
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 09-06-2011, 06:50 PM   #8
vin63
vin63's Avatar
I was trying to avoid landing the edge of the tub on the mounting strip because I have to notch the bed wood further inboard of that strip to clear the width of the tire. Let us know how you like the tubs you purchased.
Old 09-04-2011, 07:15 PM   #9
dthela
dthela's Avatar
are suburbans wider?
dthela is offline   Reply With Quote
Old 09-04-2011, 07:47 PM   #10
Slow Build
Slow Build's Avatar
Just found this one on ebay. Hope it helps.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 09-05-2011, 01:21 PM   #11
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
I am a big fan of the extra wide stock looking tubs.....It gives a real leathal look i think . My Pro street truck tubs are probaly a little wider then your thinking but I took out my rolled tubs and built a more wide factory look as well by doubling out two wheel tubs.
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 09-05-2011, 05:46 PM   #12
tazattitude
Thanks Guys!
I like the look of the tubs on the yellow truck. Pretty much what I was looking for. I was thinking that the holes on the front and rear were supposed to line up with the bed strips. On that one, it does not. Looks great though.
Thanks again!
TAZ
BUILDS
1966 GMC Suburban
Monthly Updates
Pics / Video
Old 09-07-2011, 05:50 AM   #13
tazattitude
AH, okay. understand.
tubs are on the way. I'll take part of my old tubs (probably the nearest to the bedside) and use a majority of the new tubs I'm getting.
@1Bad62Pro/Street
I had something like that polished alum bed in my truck I did 15 years ago.
Going more for a stock style look this time.
TAZ
BUILDS
1966 GMC Suburban
Monthly Updates
Pics / Video
Old 09-07-2011, 11:37 AM   #14
Slow Build
Slow Build's Avatar
Found another one in my archives.
Past GM Trucks:
Old 09-07-2011, 02:41 PM   #15
1Bad62Pro/Street
@1Bad62Pro/Street
I actually like that! Any more pictures?
Where did you get the aluminium?
Make the roll beads your self? Pre-formed?
Pops keeps saing that if I line the sides and head board with aluminium it will draw in moisture between the aluminium and metal causing rust. Did you experience this?
Just a few questions!
Old 09-07-2011, 03:16 PM   #16
tazattitude
That's exactly what I'm looking for slowbuild!!! Thanks for the pic.
1Bad62Pro/Street
Here are some other pics of that truck
Back right before purple was the 'bomb'
Did the build in 94 or so. Sold it in 2001.
Never had any problems with any moisture.
TAZ
BUILDS
1966 GMC Suburban
Monthly Updates
Pics / Video
Old 09-07-2011, 03:22 PM   #17
1Bad62Pro/Street
Thumbs up Re: Widened wheel tubs
1Bad62Pro/Street
Thanks Bud!
Old 09-18-2011, 12:55 PM   #18
Slow Build
Slow Build's Avatar
A little better detail on this one.
Past GM Trucks:
Old 09-18-2011, 02:14 PM   #19
tazattitude
I ended up widening my tubs on Th. Got them in primer on Friday.
I widened them 3.5 inches. I decide not to 'double' them like the white one just posted and the red one. I didn't want to go as wide as them (I think I ended up about 3" narrower than the white and red one). I will have to re-arrange the wood, but I think it will work out though.
I used this black tub as an example to go by.
TAZ
BUILDS
1966 GMC Suburban
Monthly Updates
Pics / Video
Old 09-21-2011, 04:02 PM   #20
vin63
vin63's Avatar
Great job!
Old 02-08-2012, 07:27 AM   #21
tazattitude
I know this thread was referenced from another thread so I'll add to the outcome of my tubs.
See pics...
This was October of last year (wow how time flies). Since then I've added a Gaylord hard cover which keeps that bed clean. Of course the tailgate is on as well
@chad64chevy
Sorry I missed your question. I believe you had pm'd me on this though.
I used 3/8" bolts I did not shave the bolt heads
TAZ
BUILDS
1966 GMC Suburban
Monthly Updates
Pics / Video
Old 09-18-2011, 02:16 PM   #22
tazattitude
I do like the way they rounded the corners on the white tubs. Nice clean look!
TAZ
BUILDS
1966 GMC Suburban
Monthly Updates
Pics / Video
Old 09-18-2011, 02:50 PM   #23
Slow Build
Slow Build's Avatar
Did you flatten out these areas? I can't tell from the picture of them in primer.
Past GM Trucks:
Old 09-18-2011, 03:15 PM   #24
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Not completely finished, but wider is better.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-18-2011, 03:46 PM   #25
tazattitude
By the way, your tubs look good!!
TAZ
BUILDS
1966 GMC Suburban
Monthly Updates
Pics / Video
