10-05-2011, 07:09 AM | #1 |
Anyone seen these control arms yet
http://michiganmetalworks.com/store/...&product_id=78 Works with a dropmember says it will lay out 33.5 od tire.
10-05-2011, 08:00 AM | #2 |
Just a car guy
Re: Anyone seen these control arms yet
Oh, ah.
Very nice. and pricey!
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
10-05-2011, 08:02 AM | #3 |
67-72 parts collector,…
Actually cheaper than alot of tubular a-arms.
10-05-2011, 08:11 AM | #4 |
I have seen his s10 ones in person they are heavy and his special upper ball joint he calls a jeebus joint does out flex any ball joint i have seen.Ridetechs a arms are a grand kp links are over a grand so its not that pricey next to what is out there.
10-05-2011, 10:06 AM | #5 |
Just a car guy
What material is used?
10-05-2011, 11:03 AM | #6 |
I'm just glad to be here!
Those are from Jeebus. He is a member on here. Looks cool.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
10-05-2011, 12:52 PM | #7 |
needs more $$$
So, if they work with a DM, does that mean they won't with a stock x-mbr?
1970 2wd Blazer |
10-05-2011, 01:54 PM | #8 |
The upper would but the lower uses a different cross shaft. The stock cross shaft bolts to stock crossmember with u-bolts. The PB member uses something different.
10-05-2011, 02:32 PM | #9 |
needs more $$$
Makes sense why the pic doesn't have one on the lower
1970 2wd Blazer |
10-05-2011, 02:12 PM | #10 |
Here's a complete listing of the Chevy a-arms available.
http://michiganmetalworks.com/store/...ory&path=60_65
10-05-2011, 02:23 PM | #11 |
Just a car guy
Any idea on materials?
I'm guessing these are for the frame dragger and not the corner carver?
10-05-2011, 10:23 PM | #12 |
They look neat but I would worry about those things folding up. Is there some form of triangulation I'm not seeing?
-Michael |
10-06-2011, 12:33 AM | #13 | |
'69 Chevy SWB
I could be wrong, and I'm sure I am, but they look like they use a 1/2" to 3/4" plate. If you can fold those up, you're beating the crap out of them.
Matt '69 Chevy SWB Fleet, Primer Black; Project No Name '06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold '08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!! '99 Dodge Dakota R/T, Intense Blue; DD, Sold Quote:
10-06-2011, 05:08 AM | #14 |
HAH! I was wondering if that was a chunk of plate steel. Unsprung weight.. whats that?
-Michael |
10-05-2011, 10:58 PM | #15 |
The black ones look bedazzled.
Never wrenched a day in my life and now... Im doing a frame off restoration on a 1968 C10 with a Porterbuilt Dropmember, Acuair E-Level kit, Boyd Welds Gas tank and mild c-notch. Click here to view my build |
10-06-2011, 12:51 AM | #16 |
These are steel plate your frame would bend before this will.
10-06-2011, 08:41 AM | #17 |
10-06-2011, 04:10 PM | #18 |
10-06-2011, 04:31 PM | #19 |
those are pretty bold numbers considering you don't know the tensile strength or the type of steel used.
p.s it's a press brake, not break |
10-06-2011, 05:21 PM | #20 |
Please excuse my spelling error.
That was just a general value based on mild steel with a 60,000 psi tensile strength. The uppers he produces are 1/2" steel plate which is more than adequate as the upper arms are locating devices for the spindle and most all of the forces are tension and compression type forces. I believe his lowers are made out of 3/4" plate, and while I do not know the exact material he is using I would still commit to saying that they are adequate for the job. It will take a considerable amount of force to bend a 3/4" plate that is roughly 10" wide and 18" long. |
10-06-2011, 05:46 PM | #21 |
even at 60,000 psi tensile strength, 1/2" plate can be bent with as little as 10 tons under the right conditions (angle & width of bend, etc).
10 tons is really NOT a lot of force when it comes to the dynamics encountered in a suspension system with 3,500 lbs. plus riding on it. I'm not saying they aren't quality components, but if their design is truly "better" then I think the OEM's (not to mention the applications in motorsports) would have been making a-arms out of flat plate long before now due to the big decrease in costs to manufacture and shortened lead-times. No flame meant, just stating the obvious from my perspective: 1/2" flat plate with NO supporting gussets? No thanks, my safety along with my passengers and everyone else on the road is not worth the chance. |
10-06-2011, 06:33 PM | #22 |
I will disagree, but now the OP has an opinion from both sides with which to make his decision.
Flat plate arms are not a new idea and I believe have been used in the off road market for some time now. |
10-06-2011, 08:56 PM | #23 | |
Even if the steel was stiff enough to resist bending at the airbag mount, I highly doubt those two little bushing arms can resist any bending. I would be concerned about cracks forming at the welds and on those arms. Steel is a strong material, and you can design an arm to be lightweight and have infinite strength for a given application, but these arms look to have a finite lifespan on a heavy truck. I wouldn't want to do a chuckhole test with those arms.
-Michael |
10-06-2011, 09:27 PM | #24 |
With regards to the offroad aspect I don't know first hand. I have seen it discussed previously. I debated about even mentioning it and probably shouldn't have.
At any rate, I stand by my opinion that these arms would be more than adequate on a day to day basis. There is always a scenario where something will fail and that can't always be predicted. I plan to run these same arms on my truck and have no concerns in doing so. |
10-06-2011, 09:40 PM | #25 |
I like the flat plate my 2 cents I was going to get mine from this place http://www.dallashotrodparts.com/
big old burb in primer.lot of work to do. |
