Old 11-03-2011, 08:24 PM   #1
xpickup
xpickup's Avatar
1948 Chevy / S10
As promised here is the new truck thread. Instead of a 54 it is now a 48 on a S10 frame. It is my buddy Billy's truck. He put a c4 corvette IRS with bags and bagged the front too. He put a 5.3 and a 4L60 in also. The first picture is at ride height and the second picture is aired out. I did the sheet metal in it a while ago. I also made the body mounts. Now it is getting a custom floor, toe board, fire wall and a removable tranny tunnel. I am going to recess the brake booster and do the steering column install too. Sometime I will build a bed with mini tubs to clear the tires. Here are some pictures. As you can see I had my helper too. He loves to air it out!
xpickup is offline   Reply With Quote
Old 11-03-2011, 10:17 PM   #2
Fat Mike
Fat Mike's Avatar
Re: 1948 Chevy / S10
Nice start you have going on. Look forward to see what your are going to do with this one.
Fat Mike is offline   Reply With Quote
Old 11-07-2011, 08:47 AM   #3
AUSSIE54
AUSSIE54's Avatar
Updates?
AUSSIE54 is offline   Reply With Quote
Old 11-07-2011, 09:22 AM   #4
xpickup
xpickup's Avatar
AUSSIE54, Yes, getting 2 pieces of sheet metal tonight, a piece of 3/4 x 3/4 box tube and the seat pan to put back in. I should be making panels by the middle of the week.
Shannon
Old 11-09-2011, 09:31 PM   #5
xpickup
xpickup's Avatar
Started on the trans tunnel tonight. I bent 3/4" box and welded it in, now I have to cut some 1" box and put between the back 2 cross supports. Then I can cut out the cross braces. The drive shaft does not move up and down because of the corvette rear. Next is to sheet metal the tunnel and the start on the floor. The floor will have the recessed panels like the floor on the 54 I did. It makes them a lot stronger. The front of the tunnel will be removable. I am also working on some belt line pieces also. Here are some pictures
Shannon
Old 11-10-2011, 10:09 AM   #6
AUSSIE54
AUSSIE54's Avatar
Looks good, Shannon! There's no messing around in your shop is there?
Old 11-13-2011, 12:49 PM   #7
dubdtahoe
Shannon its dwayne can you give me a call I have a question for you I broke my phone so I don't have your number anymore
dubdtahoe is offline   Reply With Quote
Old 11-13-2011, 10:24 PM   #8
xpickup
xpickup's Avatar
Did not get much done this weekend. Spent part of the day working on some belt line pieces and looking for my male bead die. Some how I misplaced it. I was going to start working on the sheet metal part of the tranny tunnel but wanted to bead it. So tomorrow night I will be cutting the sheet metal for the floor and tunnel and if I can not find the die make a new one. So should have pictures of the floor this week.
Old 11-13-2011, 11:00 PM   #9
Tuned55
Tuned55's Avatar
Nice clean work. Be keeping an eye on your build
Bruce
So.Utah
Build Pics http://www.picturetrail.com/tuned55
Tuned55 is offline   Reply With Quote
Old 11-14-2011, 07:31 AM   #10
xpickup
xpickup's Avatar
Tuned55, Thank you. Your truck is really coming along too.
Shannon
Old 11-14-2011, 07:55 AM   #11
AUSSIE54
AUSSIE54's Avatar
G'day Shannon,
Beautiful work there mate. Although it appears that you've made a mistake, cause when I zoom in I see you've marked one of the pieces as pass which I'm assuming is for passenger side where as it really should be drivers side… or it would be on this side of the world.
Great work as usual buddy. Reckon you've earnt yourself a nice bottle of coke after all that fab work this week!
Regards,
Trently
Old 11-14-2011, 08:43 AM   #12
xpickup
xpickup's Avatar
Trently, Yes, for you it would be the drivers side. I would be all screwed up if I had to drive over there. I would be the idiot driving on the wrong side of the road with everyone blowing the horn and flashing the lights at me. HAHA
Shannon
Old 11-17-2011, 10:10 PM   #13
xpickup
xpickup's Avatar
Here are the finished belt line pieces that I made. I ended up losing one of my bead roller dies so I had to make a replacement. Now back to the tunnel next week now that it is made. I must have looked for 4 hours. After the 4 hours of looking I decided rather than look any longer it would be quicker to make a new one. It was my dumb fault that I looked for that long. After the first hour I should have just stopped looking. It was driving me nuts though! And yes Trently they are backwards for you.HaHa
Shannon
Old 11-17-2011, 11:28 PM   #14
Fat Mike
Fat Mike's Avatar
Looks very good! Can you take a measurement for me? I need a measurement at the very rear portion of the s-10 frame where the bumper attaches. I need a width across the frame. Trying to square up frame and welding in a rear crossmember.
Old 11-18-2011, 09:12 AM   #15
xpickup
xpickup's Avatar
Fat Mike. No problem. When I get home from work I will give it to you.
Shannon
Old 11-27-2011, 10:35 PM   #16
britnjc
britnjc's Avatar
Amazing what some shiny parts can do.... Looks great... Oh yeah it looks like someone is ready to take it for a ride...
britnjc is offline   Reply With Quote
Old 11-27-2011, 10:48 PM   #17
xpickup
xpickup's Avatar
britnjc, you are right. Thank You. And yes Garrett helped me and was driving it for a while. When ever I get it out he is always dressed and ready to be in it. I am hoping the 54 will be a father son project. When he is bad I always tell him I am going to take his bed and use it ( he sleeps in a full size 48 chevy bed with fenders, wheels, roll pan and working tail lights). I think he is already bitten by the bug!
Shannon
Old 11-28-2011, 10:18 PM   #18
xpickup
xpickup's Avatar
I got some tubing cut and welded in tonight. I should be ready to start cutting sheet metal tomorrow night. Then be able to start paneling the floor like on the 54 I did. I will start by making the inner cab corners then work forward.
Shannon
Old 11-28-2011, 10:34 PM   #19
britnjc
britnjc's Avatar
lookin good. Those pictures help alot. What cab bushings are you using?
Old 11-28-2011, 10:51 PM   #20
xpickup
xpickup's Avatar
britnjc, Thank you. If you need any more views let me know. I have a large piece of 3/8" thick rubber sheet that I use. I cut it about 4" x 4" rather than using the factory S10 rubber mounts.
Shannon
Old 11-29-2011, 05:32 PM   #21
reaper71
reaper71's Avatar
As i said Shannon great work look's real nice very clean..
Mark
reaper71 is offline   Reply With Quote
Old 11-29-2011, 07:01 PM   #22
xpickup
xpickup's Avatar
Mark, Thank you. I will be watching your build also. I am going to start a build thread on the panel soon.
Shannon
Old 12-01-2011, 12:00 AM   #23
oldman3
oldman3's Avatar
Shannon, just caught your new build thread today. Don't know how I missed it earlier. Everything is looking good. I love the body pieces you make for the cab line, super job. Will be watching this one real close. Will also be waiting for the panel thread....Jim
oldman3 is offline   Reply With Quote
Old 12-01-2011, 07:35 AM   #24
xpickup
xpickup's Avatar
Atommik, I think it is like 4". Mine are based off of Jeff's 51 but I used 3" x 3" 3/16 wall tubing. I have used 16 gauge for the stake pockets. I made a template and cut them out with my plasma cutter. I put the bend on the inside to smooth them out. I plug weld them. I have also used 2" x 4" box too. I like the box the best. After they are welded on I cap the outside on. I use 1 1/2 box for the frame work. I then use aluminium angle for the board hold downs. I drill them all and weld a nut on in the inside if the stake pockets , that is way I cap them last.
oldman3, Thank you. The panel thread will be coming soon. It was good seeing your son on here now. I really like his truck too. I will be watching his build. You guys do great work.
Shannon
Old 12-01-2011, 01:40 PM   #25
BBEEP
Junior Member
BBEEP's Avatar
Wait a second, is it the pic, or is the panel grill wider . . .?
BBEEP is offline   Reply With Quote
