Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 11-18-2011, 03:35 PM   #1
Curt's_72
Curt's_72's Avatar
Curt's '72 K20 Resto-mod
After 3 years in paint prison, our truck is finally home. The assembly process has offically began. I haven't been around a project of this size since the 1980's and I now remember why.
Our truck is an offical California 1972 K20 with just over 115,000 on the clock. A 700R4 and Vintage Air are items the previous owner(s) had installed. It was a solid daily driver for 3 years until 2007. About then, the previous bodywork was giving way from the typical Indiana winters, with standard rust spots in the rockers and roof area. It was still a great old truck from even from 5 feet, but was regulated to the garage and became our nice weather vehicle.
I've taken 3 years worth of in process pictures, all with the intent of sharing my journey with whomever might be interested in following. I'll not dwell much on the past, just touching on big changes that occured until we get to present day.
My wife didn't understand why I would tear apart a 'perfectly good truck' to redo it, but it happened nonetheless. Here is what we started with.
Soon after moving it to my friend's shop, the major destruction began. This uncovered the extent of rust damage along with a pretty major inpact on the cab, behind the door.
More to come as soon as I sort them out.
Curt
Curt's_72 is offline   Reply With Quote
Old 11-18-2011, 08:51 PM   #2
freakshow108
freakshow108's Avatar
Re: Curt's '72 K20 Resto-mod
Nice start! Does it have the 8 lug axel and if so could i get a close up pic of the front ralleys. Good luck with this project.
freakshow108 is offline   Reply With Quote
Old 11-19-2011, 11:18 AM   #3
Curt's_72
Curt's_72's Avatar
Well, Being a K20, it has 8 lug axles. Ralley wheels weren't ever offered for 8 luggers. It has the factory 16.5x8.25 steelies, which I'm a huge fan of. That is, until I really started wanting the 9.75 wide steelies. I've since squirreled away a few sets of them and even managed to find another set of the 8.25's at my local junk yard.
I'm in process of getting some of them blasted and powdercoated. I'm concerned, though about the amount of offset. None of the sets I have have the same. It will be a visual for me, as I don't want too much wheel hanging out of the fenders. More to come as that part of the process is worked on.
Old 11-22-2011, 09:38 AM   #4
Curt's_72
Curt's_72's Avatar
New rockers went on smoothly. We discovered cab supports would be needed so those went on too.
A new header panel was put in. We did it by laminating rather than cutting out the entire panel.
The passenger door was excellent. It just needed touched up.
The driver's door need a new skin.
I considered a new door, but the rest of it was in great shape. The new skin fit well. Some minor massaging of the key hole was necessary later.
I've got many more indepth pictures if there is something you'd like to see in more detail. The frame and bed are next.
Curt
Old 11-22-2011, 11:15 PM   #5
mjensen
mjensen's Avatar
Of course we're interested in more-in depth pictures! LOL
Very nice truck you got there.
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 11-28-2011, 11:33 AM   #6
Curt's_72
Curt's_72's Avatar
Body work is rockin' by now. Seeing huge changes at every visit. As you can tell, we're not doing the frame-off, but extensive, nonetheless. After taking the front end apart, we decided new fenders would be a good idea. Scored a couple of good ones from a board member. Huck is what he has been on here at. Got them from him at the swap meet in Indy. He's still around, into Honda mintrails and the such.
Fenders cleaned up nice. They also had the trim holes which was great because we're going back to that.
We had the bed sandblasted. It was super clean. It had a gas tank cover on the passenger side, which I wanted removed. I wasn't going to use it, so I wanted it gone. The old fender served as good patch. The inside of the bed didn't need anything. The bottom we just wire brushed and used POR-15 on it. Stuff works great.
We hit the frame next, since the bed was off. More on that.
Curt
Old 04-18-2012, 02:42 PM   #7
SunSoaked
SunSoaked's Avatar
Attachment 832030
Attachment 832032
Attachment 832034
Attachment 832037
Curt
Nice job Curt-I'm curious how difficult it was to remove the inner skin from the door. I'm considering having the inside of my doors "line X'd" and would need to open them up to do it right.
SunSoaked is offline   Reply With Quote
Old 04-19-2012, 03:06 PM   #8
Curt's_72
Curt's_72's Avatar
It really wasn't that hard. We used a grinder all around the perimeter to the window to separate the pinch. I don't exactly remember what holds the top, where the window rubber attaches. There's no other means of fastening the skin, other than that.
A chisel and hammer to remove the spot welds on the folded over edge that is still fastened to door will be needed.
What is "line X'd"?
Click below to see my build thread...lot's of stuff there
http://67-72chevytrucks.com/vboard/s...d.php?t=494493
Old 12-14-2011, 12:41 AM   #9
Maxxd07
Maxxd07's Avatar
Sweet!
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
Old 12-14-2011, 11:00 AM   #10
Curt's_72
Curt's_72's Avatar
I've been gathering lots of parts for the restoration. Most are the originals that have been blasted and powdercoated. The trim items are reproductions for the most part, or I've cleaned up the originals.
After this length of time, I hope I remember how this stuff goes back together!
I've not found any vendor that is one stop shopping. Each are good, and each have different prices depending on the part. I've done alot of research comparisons online. I very seldom actually bought the least expensive.
Alot of people don't care for Ebay, but I search it daily. I've landed many good scores on it and I've never been stiffed. Some items haven't been as good as I thought they might be, but I've never paid much for any one thing.
The best so far has been the NOS parchment door panels. I paid less than $75.00 for them because the listing was typo'ed. They still had the bin tag GM bin tag stuck to them.
I've just joined the the site as a paying member and I hope to utilize the classifieds soon. I'm having a hard time locating the upper radiator pipe.
We're completely changing the color sceme and the interior. It'll be parchment. The seat is done and I'm very happy with the quality of the cover and the installation.
Name:  finished seat1.jpg
Old 12-14-2011, 11:26 PM   #11
mjensen
mjensen's Avatar
I'm thinking that the amount of beer you have left does not equate to the amount of parts you need to put back on
Mike
Old 12-15-2011, 08:40 AM   #12
onebadbowtie
onebadbowtie's Avatar
agreed...
James
94' Chevy K1500 Extended Cab 4x4 5.7
72' Chevy LWB K10, 350, SM465, NP205 Project "Daily Driver"
onebadbowtie is offline   Reply With Quote
Old 12-15-2011, 09:29 AM   #13
no moa
no moa's Avatar
i would also agree!
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 12-15-2011, 11:44 AM   #14
Curt's_72
Curt's_72's Avatar
Laughing....
It was on sale, Memorial Day weekend and two races for 1100 miles. I did the math.
Glad you guys are noticing this stuff! As long I get feedback, I'll continue to update.
Remember, this was a 3 year period and I haven't gotten to present day yet.
Thanks for the replies!
Old 12-22-2011, 12:11 PM   #15
yfs200p
E.H.F.D Engine #2
yfs200p's Avatar
Keep the pics coming! That was an awesome looking truck to start with. These pictures are just a little ahead of where i'm at right now. The bodywork seems endless sometimes!
-NICK
'72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation
'89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205
'15 Chevy 2500HD CCSB High Country Duramax
'22 Tahoe Premier Duramax
yfs200p is offline   Reply With Quote
Old 12-22-2011, 02:01 PM   #16
Gene
Gene's Avatar
Very nice progress, you'll be happy when youre done!
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 01-03-2012, 11:25 AM   #17
Curt's_72
Curt's_72's Avatar
We're heading to the paint booth! I'm pretty stoked about it. Finally, light at the end of the tunnel.
I've been on the fence about color. I'm going two tone, with white as the center and cab roof. The primary will be....wait for it....yellow. Yeah. That's what wifey said. Yellow? Kinda like Jim Mora and his rant about the Colts a few years ago. Yellow? Are you kidding me? Yellow? Still cracks me up.
Anyway, the shade of yellow is the issue. Some yellows look orange to me. I want a more greenish yellow. Like a highlighter. Something with pop. My painter will use any color I want, but he says OEM colors are less expensive.
I'm leaning toward C5 or C6 Corvette yellow. Either Millenium or Velocity. I thought it would be Millenium, untill i saw it on a C5. Now I need to see the Velocity.
Old 01-03-2012, 10:54 PM   #18
mjensen
mjensen's Avatar
Well, that is exciting! That color combination sounds awesome to me.
Mike
Old 01-11-2012, 12:19 PM   #19
Curt's_72
Curt's_72's Avatar
We've got color!! Factory white basecoat. It looks gray in these pictures, but it's white, and it's color! White will be the center and cab, and serve as a base for the yellow. You paint guys knew that. I'm learning.
It won't be long now!
The frame detailing from before is really trashed. Got alot of rework there to do.
Old 01-12-2012, 02:53 PM   #20
patrickth
Very good thread. I am subscribing now.
patrickth is offline   Reply With Quote
Old 01-12-2012, 03:41 PM   #21
Curt's_72
Curt's_72's Avatar
I scored these 16.5x9.75 wheels recently. Finally found a set with the outer nubs.
Name:  9.75x16.5 outer hubcap nub1.jpg
Just took them to get blasted and powdercoated. Gloss white. I should have them back next week.
I think I need them rather than the 8.25's that are currently on the truck. We'll see once I get them.
The backspacing is different on all three sets that I have. Backspace is only .25" greater than the 8.25's. That concerns me, because I don't want them to stick out too far.
Old 09-28-2012, 11:48 PM   #22
blackhawkip
blackhawkip's Avatar
Great job on the truck! It turned out great.
Are you planning to keep the 8.25 wheels on your truck? I'd be interested in your 9.75 wheels if you are willing to sell them.
Let me know. Thanks
Attachment 855158
1972 Cheyenne Super K20 4wd
1972 Chevy Camaro Z28
1972 Cheyenne Super K30 (sold)
1972 Cheyenne Super Shortbed w/402bb (sold)
1972 Custom/Deluxe 2wd Suburban w/402bb (sold)
plus too many others.....
blackhawkip is offline   Reply With Quote
Old 01-16-2012, 10:54 AM   #23
Curt's_72
Curt's_72's Avatar
Velocity Yellow got the nod. Comparing paint chips isn't a good way to make a long term choice, but it worked out.
Getting ready to layout the lines for the two tone. Rather than measure using the documents in the assembly manual, we used the trim instead. The fenders had mounting holes so we had that reference point to start.
The paint divider trim on the cab uses studs adn they were still in place, so we didn't have to lay anything out there.
We'er looking at days now, rather than months. What a great feeling!
Old 01-12-2012, 03:52 PM   #24
patrickth
I know all areas are different, but do you mind telling me what the budget quote was for blast and powder coat? I have the same decision to make myself right now.
Old 01-12-2012, 05:52 PM   #25
jeremy zander
jeremy zander's Avatar
Nice..good progress...I paid $300 for blast and powdercoat on my 16.5 wheels
WTB 1972 CHEVY 3/4 4X4
1971 chevy c30 4x4 NAPCO (project)
1972 chevy 3/4 4x4 350/350 4spd, tach, tow hooks,radio delete,heat delete,hubcaps,lockers
1972 chevy 3/4 4x4 383/350 dads original farm truck tilt,tach,tow hooks,hubcaps,radio delete,heat delete
2006 chevy LBZ crew cab duramax,4 inch,beadlocks
2015 chevy tahoe Z71 my fifth one,love em
2016 chevy 2500HD Z71 LTZ duramax midnite
2018 chevy suburban Z71 midnite
jeremy zander is offline   Reply With Quote
