![]() Join Date: Apr 2011
What kind of axles and tcase should i replace my Dana 44s with?
I am looking at beefing up my axles and replacing my np203. I have a 72 blazer with Dana 44 front and rear. I have a 350ci/350hp motor with a th350. I will more than likely be running 35's. Mainly around town driving, but a few trips a year to the mountains of colorado for weeklong camping/offroad trips with my jeep buddies.
Should i just stick with Dana 60s front and back and an np 205? Or should i be looking for a newer model chevy truck 2500 to rob the running gear from? What are the axle names i should be looking for? What transfer case should i look for? What year models of trucks/tahoes/suburbans should i be searching for? Sound off on your experiences/preferences please. Thanks. |
![]() Join Date: May 2007
Re: What kind of axles and tcase should i replace my Dana 44s with?
The 72 Blazer should already have a no205 from the factory.
Unless you are upgrading to a high horse power engine or plan on rock crawling you can use what you have unless you have left over money you need to spend then here's a list D60 front air or e-locker chrome molly axles 52" springs nv4500 with a twin stick np205 or a np203,np205 doubler 14b with a air or e-locker 63" springs
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
Grease Monkey
I agree with duallyjams. You should have a NP205 and Dana 44s are perfect for 35s and rolling around town. Upgrade to a D60F and 14Bolt Rear, ONLY IF you are going to do some hard wheeling.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
I am not very familiar with the nv4500 transmissions. Is the nv4500 only available in standard? if so, is there an alternative to the nv4500 that is comparably as tough but in an automatic version?
agree with chev1ton dana 60 front with crossover steer, gm dana 60's came in the 1tons around late 80's early 90's(anyone, correct me if i'm wrong) and 14BFF rear (chevy 3/4 70's -90)!
1970 C/20 4x4, 350, sm465, np205(She tipped over... total rebuild from the frame up!) ![]() ya gotta keep on keepin' on, Life's a garden, dig it! |
You need to find out what you have first, and then decide how much $ you want to throw at it.
'67 trucks had Dana 44 in the rear, and maybe some '68. 12 bolt should be in the back of yours. If you are only doing light trails/mud your stock setup should be more than sufficient for 35" tires and auto trans. As mentioned already, the factory t-case in a '72 should be a 205. The TH350 can be built more strongly and that is the most cost effective way to go. The next upgrade would be a TH400/205 combo. Dana 60 was in the front of K30 trucks from '77 to '87 and in the "old" body '88-'91 trucks. But every hard core offroader in the country is looking for the SRW Dana 60 for their project which means at least $1000 unless you happen to get a smokin' deal somehow. Most cost effective way to get some beef in the axle department would to buy a 3/4 4x4 Suburban. Early ones had full float 14 and Dan 44 while later ones had the semi-float 9.5" and 10 bolt front. The SF 14 is significantly stronger than a 12 bolt while the 10 bolt is about the same as the 44. Obviously, gear ratio needs to be same F and R.
i did get lucky and found a 78 3/4 ton truck and robbed the axles and transmission/tcase off of it. The rear was a 14b (i assume it is a full float?). The front is unfortunately a d44 (i think). the tcase is an NP205.
So should i beef up the guts of both internally? add kingpin knuckles to the d44 front and do the high crossover steering? I assume my current tcase is an np203 because i think it only has 4hi, 4lo, and N. Last edited by 65malibu; 11-25-2011 at 01:31 AM. |
If your on 35s and not driving hard at all just maybe a few times a year save the axle money and put it elsewhere unless you have a gold mine then go crazy =-p
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
#9 | |
A 14B has 14 diff cover bolts. If its a Full Floater, it has 5 bolts holding the pinion into the front of the diff. Also, it'll have 8 lug hubs and the hub will protrude past the wheel mounting surface (WMS). It would not make sense to add king pins to a Dana 44. The inner "c" and knuckle would cost way more than a used Dana 60. I just sold two completely rebuilt units with crossover for 1200, jsut to give you an idea. Then you'd still cut the old "c" off and weld the new ones on at the right angle. |
To beef up the Dana 44, pick up some alloy axles with Spicer U-joints. Rebuild it will all new bearings and seals. Throw on a set of Warn Premium locking hubs. Drive it until you absolutely need a Dana 60.
I am a huge fan of WFO Concepts, so I'll pimp them here: they've got everything you need to rebuild that with crossover. They're answer any questions you may have along the way. With 35s and reasonable driving, it'll last a long time. I ran mine with 35s for years through the Rubicon and low gears. NV4500 - its only a manual trans. It is special because it was one of the first "granny low" boxes with an Overdrive. It came behind diesel engines (among other things), so it can handle power. Its not special because it uses very expensive oil, hard to find parts, and expensive. If you resourceful, you can overcome the high cost and hard to find issues. Some will argue that it had reliability issues. I've never had one, but read a ton about them. |
Grease Monkey
I'd stick to what you have. You have absolutely no need for a Dana 60. That is for hard core wheel only. Its your money, but it will run you $1000 - $2000 for a D60.
Sounds good. I need to start researching what i need in order to rebuild the D44 front. Thanks
I agree with 1TonFun. You don't need a Dana 60.
Call Trevor or Dell at WFO Concepts. Tell them what kind of wheeling you do. They'll tell you how to build the Dana 44. They WILL NOT sell you anything you don't need. Even if you don't buy from them, they'll give you great advise. |
Will do! Thanks so much for helping me out guys. I'll learn eventually.
