12-26-2011, 06:14 PM | #1 |
200r4 Shift Linkage ?
I just installed a 200r4 in place of a TH350 and am having issues hooking up the column **** linkage. Anybody out there who has done this swap have pictures of the shift linkage set-up? I'm trying to use all the stock components from the th350, maybe that's were I'm going wrong. I'd appreciate any advice.
72 SWB 2WD, complete frame off resto |
12-26-2011, 06:47 PM | #2 |
Re: 200r4 Shift Linkage ?
no such thing as 200r4
12-26-2011, 06:56 PM | #3 |
Sierra Grande Club
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
12-26-2011, 09:05 PM | #4 |
Uploaded pictures.
01-22-2015, 10:10 PM | #5 |
If you're going to bust him on it being a 200-4R then at least throw -something- helpful in the post. Maybe a coupon code or a joke.
Anyhow, I got mine to work perfectly by flipping the frame mount over and using it upside down, plus a few shims to move it inboard a little. Works great. If it's not obvious from that description (and it may not be) I can take a photo for you.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
12-26-2011, 10:46 PM | #6 |
Has more rust than truck...
If you cant get it to work, a Lokar ACA-1800 will work with a 200-4r
http://www.summitracing.com/parts/LOK-ACA-1800/ |
12-26-2011, 10:57 PM | #7 |
That is strange. Are you using the same brackets that were on hte truck when you removed the TH350? I have put in a 700r4 and had not problem. I see that the linkage is shifted to the center. The 224r isn't that much thinnner is it. Maybe a different bracket that bolts to the frame?
12-26-2011, 11:00 PM | #8 |
Sierra Grande Club
Is picture #4 the problem?
12-27-2011, 11:32 AM | #9 |
Picture #5 is really showing the problem. You can see that I've used a few nuts to "shim" the pivot bracket towards the center of the driveline to make it all work. I just really don't want to leave it this way if there is a better way to tackle the issue.
12-27-2011, 02:16 PM | #10 |
Looks to me like you may need to remake the bracket with the pin so it gets closer to the transmission. Either that or remake the part the bolts to the transmission to get it closer to the frame.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
12-27-2011, 02:32 PM | #11 |
Sierra Grande Club
How long is the bracket in your #4 picture? I just looked at mine and think it my be longer? I'm talking about the part that's on the transmission & pivots on the pin.
12-27-2011, 03:04 PM | #12 |
It's about 4.5 long
12-27-2011, 04:18 PM | #13 |
Sierra Grande Club
Ok, it's the same as mine.
What about cutting it and welding in a splice to make it longer?
01-22-2015, 10:42 AM | #14 |
I have a question about these "Pivot" brackets that mount to the frame, and maybe this will answer the problem he's having....
is there are difference in the brackets for a TH400 truck -vs.TH350 with regards to the pivot bracket that mounts to the chassis? I'm betting the one he has was originally for a TH400 being a wider transmission, not enough distance to close the gap on the 200 Metric trans.......correct me if I'm wrong....that's my guess.... Ben |
12-27-2011, 04:11 PM | #15 |
I am subscribing to this because I have a 200r4 in my 69 and I plan on using my column shifter.
Sean "If your gonna be dumb, you gotta be tough" 1960 Chevy Impala Sedan - my 25 year search is over!! 1969 C-10 longbed - Nice day DD 1970 Chevy Nova - Street and Strip Project 2002 Acura MDX my DD 2007 Honda Odssey - My Wife's "Mommy Van" |
01-22-2015, 11:38 AM | #16 |
I have the Lokar on my 700R4. I did have to make a slight bend in the rod. If all else fails, give it a shot.
It works well, was simple to install and looks good too.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
01-22-2015, 06:57 PM | #17 |
I used the same linkage when I swapped from TH350 to 2004r so it should work. My old linkage was worn so I switched to the universal one from CPP and I works much better and is much quieter.
01-22-2015, 09:01 PM | #18 |
Quit if it's not FUN!!!
I had the same issue with my 200. I took the bellcrank off and dug up a steel spacer with a (3/8?) I.D. about 1" long. Temporally stuck a 3/8 bolt thru the hole with the spacer on the outside (sorry I don't have a picture). Ran a weld bead around the spacer and ,voila, worked like a charm! I'm thinking the 200 is a little more narrow than the 350/400 at that point. Whatever, mine has worked fine with no issues.
P.S., Speedway has a column indicated with the O/D shift pattern that is almost a direct bolt-on my '70 steering column.
MY MOTTO: Eat it all up, Wear it out, Use the last few drops, Spend all you've got, Late in life, you'll think of the things you didn't do, not the things you did. - Get out and experience life ! . Robbie Robinson a.k.a. TobyArnot (Toe Bee or not toe bee) |
01-22-2015, 10:17 PM | #19 |
I figured I'd get photos now rather than wait. They look a lot like dk's above. I'll only post the bracket end as the rod end looks the same as above: 1-2" of space length at the column connection.
Let me know if this helps, I'm curious.
01-24-2015, 05:42 PM | #20 |
I happened to have my truck on a lift this morning and I got a picture of the reworked bellcrank. Thought I'd share it FWIW.
