02-15-2012, 04:09 PM | #1 |
still have engin problems
checked vacuum at rear of carb 15 inches checked intake no leaks new gasket carb to intake carb is a rochester 2 barrel checked trans level it's ok truck will not idle in gear it stalls almost instantly. please any thoughts thanks much RV
02-15-2012, 05:26 PM | #2 |
Re: still have engin problems
i had this problem with my truck, turned out the fuel pump was bad and as soon it was under load it died, problem went away with the new pump, maybe its something you could try.
02-15-2012, 07:21 PM | #3 |
Active Member
A little more info>> Year and engine.
Fuel pump could be the problem but can you run the vehicle at all? In other words does it die as soon as you put it in gear? |
02-16-2012, 05:25 PM | #4 | |
02-16-2012, 07:13 PM | #5 |
Active Member
I've had torque converter/transmission do the same thing before. Assuming that not the problem, you need to check a few other things first.
Do you have the original points distributor or HEI? First check the vacuum advance to make sure it's working properly. If it's HEI, check the timing again and insure it's set at app. 10-12 degrees BTDC at idle. Then increase the rpms and check that the total advance is about 30-35 give or take and see if that helps. If it's non HEI then do the same thing but use the actual spec setting for initial timing. Don't forget to plug the line from the carb to vacuum advance. |
02-18-2012, 01:34 PM | #6 | |
02-15-2012, 07:38 PM | #7 |
is a fungineer
What's your RPM at idle in park?
2003 S10, 2.2 auto- the daily driver, currently with a 2"/2" drop and some minor engine bolt-ons 1978 Impala 2-door, race 350/T350 - the new race car, in progress 1968 Chevy C10 longbed- 3/5 drop, currently undergoing a heart transplant |
02-17-2012, 09:51 AM | #8 |
sounds like the torque Converter is not releasing at idle
02-17-2012, 12:50 PM | #9 |
I agree! Put the rear of the truck on jack stands and start it. If it idles and the wheels turn, you've found your problem. If it's a lock up convertor, it's may just be a bad torque convertor solenoid in the transmission.
02-18-2012, 01:29 PM | #10 |
thanks for the info will try if i find its the converter what do i do ????
02-18-2012, 04:05 PM | #11 |
well i tried what you suggested. jacked it up started it let it warm up put it in gear ran just fine when i put on the brakes it stalled did this severl times same thing . so i would guess its the torque convertor. some facts the trany is out of a 77 chevelle inline 6 , pulled trany drained & changed filter,trany had only 40 k on it,reassembled it with the right fly wheel and mounted to my 283, is there any easy out of this or do i have to pull the trany ,i have limited equpt. and am working on a gravel floor. hope by the beginning of next week it will be over 40 degrees up here. thanks much for the help RV
02-19-2012, 06:59 PM | #12 |
sorry i'm still learning how to navigate this site . iguess its the torque conv. it runs in gear with the wheels in the air ,but stalls when i apply the brake.i guess there is no easy way out of this .if i must drop the trany thinking of putting a 3 or 4 sp. back in , any thoughts on this.thanks for your help.RV
02-19-2012, 11:36 PM | #13 |
I seriously doubt its a torque converter issue. Unless its a lockup torque converter its not possible for it to stall the engine.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
02-21-2012, 06:55 PM | #14 |
jack the idle up a little a and see what happens when u put it into gear but do it on an open street if it just take off it's the torque converter !!
