Passenger side rocker
Has anyone replaced the front passenger side rocker panel? If so do you have any tips, as the only one available is from a truck and it is too wide at the rear. I have not been able to find a burb only rocker.
Thanks Jason Posted via Mobile Device |
Restoration Virgin!
Re: Passenger side rocker
I read through this thread....click on member 'hart_rod' build thread he references in this....he used a truck rocker that he modified....good luck!
http://67-72chevytrucks.com/vboard/s....php?p=3421559
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
Thanks for the link. It helped a bunch. Looks like I should have left that piece in place instead of cutting it out
Restoration Virgin!
Jason....keep an eye out on the parts forum for someone cutting up a burb....good luck!
EDIT....you may want to touch bases with this guy to see if he still has that portion of the burb he offered....just a thought?? http://67-72chevytrucks.com/vboard/s...d.php?t=409903
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 05-01-2012 at 04:03 PM. |
