Old 08-13-2012, 03:19 PM   #1
Hayjay13
'51 3100 Rust-O-Rod
First time on this site. I got a bug in me and decided to take on a old car build. When I happened upon AD truck from SW Missouri I starting the planning and ordering. I'm all about handling and balance so this is what I came up with...
LQ4 6.0 with a carb conversion, 750 Demon carb
T-56 6-speed from a 04-07 Cadillac CTS-V
Heidt's superride 2 with 550# springs
05-06 GTO independent rear with coilover conversion
GTO/C5/C6 Vette brakes
Pictures:
Hayjay13 is offline   Reply With Quote
Old 08-13-2012, 03:20 PM   #2
Hayjay13
Re: '51 3100 Rust-O-Rod
Some more...
-Old tractor pan seat with fabricated seat backs and adjustable brackets
-Tubular floor subframe with removable floor and trans tunnel
-Very, very stiff frame...
Old 08-13-2012, 03:23 PM   #3
Hayjay13
More
-Manual wipers...
-Wilwood 3 master cylinder setup with balance bar on brakes
-custom linkage for shifter
Old 08-13-2012, 03:24 PM   #4
Hayjay13
More...
-Aim Mychron 3 race digital dash
-Drive shaft shop custom drive shaft
- dual 3" X-over exhaust with 10 series flowmasters
- Simpson cam lock 4-point harnesses
Old 08-13-2012, 03:40 PM   #5
seanery
seanery's Avatar
sweet!
seanery is offline   Reply With Quote
Old 08-13-2012, 05:11 PM   #6
shadow1967
shadow1967's Avatar
How did you get the front GTO brakes to mount on the mustang spindles?
Build for my 1959 Fleetside...
http://67-72chevytrucks.com/vboard/s...d.php?t=518308
shadow1967 is offline   Reply With Quote
Old 08-13-2012, 06:01 PM   #7
Hayjay13
Made a bracket from some 1/4" steel plate. Same design as the Heidt's kit that mounts the Willwood superlight calipers...which I still have if anyone is interested.
Old 08-13-2012, 06:52 PM   #8
oldman3
oldman3's Avatar
Killer....Jim
oldman3 is offline   Reply With Quote
Old 08-13-2012, 10:55 PM   #9
69CST-V
69CST-V's Avatar
You have awesome vision and skills to help us see it. Sweet build. I like where you're going with this.
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 08-14-2012, 08:17 AM   #10
wayne4252004
wayne4252004's Avatar
Killer project. Where did you find the tractor seats?
wayne4252004 is offline   Reply With Quote
Old 08-14-2012, 12:02 PM   #11
Hayjay13
Ebay. The home for tons of crap...
Old 08-14-2012, 08:24 AM   #12
focusedontheprize
focusedontheprize's Avatar
Very cool setup. Interested to see the finished product from just this work.
Question:
I am just started to get my toes into Chassis Engineering. In the future, I would like to put something underneath my '49 that is autocross worthy. I have miles to go (in the learning section) before I even do. However, when I see guys who run a more "complex" suspension setup, I see a large amount of them reusing the stock frame (boxing and bracing).
Is the frame really that structurally sound than just boxing and bracing it will allow you to run it hard?
Reason I ask, I never pictured these frames to be setup (dimensions and geometry) for running this as an autocross setup even with the bracing and boxing. Seems I was wrong, but I am wondering what I missed.
Thanks.
focusedontheprize is offline   Reply With Quote
Old 08-14-2012, 09:35 AM   #13
mknittle
mknittle's Avatar
Question:
Thanks.
Herb Adams Book Chassis engineering will help.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 08-14-2012, 12:21 PM   #14
Hayjay13
Question:
Thanks.
It's an interesting balance. A race car chassis is tuned through the suspension. That lessens the variability and helps consistent feedback. A street car has compliance in the chassis for comfort and cost. The older trucks are designed for ultimate compliance. Riveted frames are great for driving all over a farm pasture and not developing stress cracks. I wanted to use some of the frame for my build but realized early the original cross bracing and C-channel wasn't going to cut it. The size of the beam itself isn't bad (roughly 6X3" in some areas). So the issue becomes how its boxed and what system is used for torsional rigidity. I used a series of cross members and triangulated that all together. I also solid mounted the engine and cab. The cab has a rigid subfloor that helps stiffness. Now, this is never going to be as stiff and caged vehicle or anything that has a frame further away from the axis of torsion (like a good unibody or monocoque), but pretty good none the less.
The wheelbase is 116" I believe. This makes a terrible auto-X vehicle. Mixed with the width and vision perspective and you have a cone eater. I wanted to take my truck to a solo event for giggles but haven't got there yet. Any chassis can be tuned if you put the time and effort in. My opinion:
1. Ditch the front suspension
2. 4-link a rear end
3. Box the frame from the front coil mounts to the rear coilover mounts
4. Add extra bracing at transmission mount and 4-link mount
5. Get everything reasonably low (engine and suspension) to control polar moments. *don't exceed the suspension's optimal position because you'l get all types of bump induced crap*
Old 08-14-2012, 01:15 PM   #15
focusedontheprize
Just snagged his book a few weeks ago and started it on Sunday. Taking notes. It is a great read.
Very interesting. Thanks for the response. Either way, a "cone eater" is not what I am thinking. If yours is a cone eater, mine will be a "wall pounder".
Awesome ride though.
Old 08-14-2012, 04:17 PM   #16
Chevette
Chevette's Avatar
Interesting. I like what you're doing. I do wonder though, with the cornering capability of that hot rod, how you're going to keep your ass in that tractor seat.
56 Chevy PU
http://67-72chevytrucks.com/vboard/s...d.php?t=531955
Question: Know how to sell your truck for $50,000?
Answer: Spend $100,000 building it.
Chevette is offline   Reply With Quote
Old 08-14-2012, 09:14 PM   #17
Hayjay13
4-point
Old 08-20-2012, 02:43 PM   #18
_Ogre
_Ogre's Avatar
friday was cool, saturday was a 6 mile long, 5 lane parking lot
nice ride, my butt hates your seats
shop air compressor timer
Old 08-20-2012, 06:27 PM   #19
hotrod1
56 - autocross
hotrod1's Avatar
This is great. Can u show more pics of the motor mounts and also how they attached to the frame?
I like the dataloger. Did you make the mount in the dash or did it come with a weldable metal insert?
hotrod1 is offline   Reply With Quote
Old 08-26-2012, 09:55 PM   #20
Hayjay13
Motor mount - 3/16 steel with a gusset. Also made the column mount for the AIM Mychron.
Old 10-05-2012, 12:54 PM   #21
69CST-V
69CST-V's Avatar
Any updates?
Bryce
Company Trucks
Old 10-05-2012, 03:56 PM   #22
Hayjay13
Originally Posted by 69CST-V View Post
Any updates?
It's done in the spirit of the rat. This is up at Woodward Dream Cruise.
Old 10-05-2012, 09:32 PM   #23
69CST-V
69CST-V's Avatar
Man that's bad arse. Great job.
Bryce
Company Trucks
