Chassis Reinforcement
Did anyone tried to reinforce the chassis? My truck in the paint shop and they found out the chassis up front is little bit twisted and noticed that the chassis is not the greatest design by GM and I was thinking of putting up bridge between the chassis to hold it more tighter does anyone have ideas on this?
Re: Chassis Reinforcement
2wd or 4wd, if 4wd has it been abused because that usually leads to frame problems
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
#3 | |
If I box the frame it wont pass the inspection so any other idea's? Posted via Mobile Device
couldnt you like box it?
San Antonio, TEXAS -Frog -I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it. |
Buy a new tube chassis or live with the redvines quality frame we have.
Otherwise box it and hope the inspectors are morons Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
If the frame was bent in an accident it can be pulled straight... It could be the bends it got were minor enough a previous owner chose not to bother with the expense of pulling it straight. Unless you are planning on working the truck hard or abusing it, once pulled straight it shouldn't have a problem with re-bending... I've had a frame fixed from an accident in a truck only to have it hit again, held up well enough that even though it bent a second time it was still able to be straightened back within specs again, and hasn't suffered anything ill since then...
I will try to fabricate something that will make the chassis more stiffer
Could make a few brackets that bolt on in key areas to bring it in shape.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] ![]() 1999 k3500 crew cab dually 6.5tdi/4l80e |
