02-14-2013, 12:29 PM | #1 |
Lift gate slides to gas assist shocks
Has anyone done this conversion? I know hart rod did it. Here is link to his. http://67-72chevytrucks.com/vboard/s...d.php?t=220511
I started to do it last night and found out it not as easy as the 67-72 guys have it. I'm probably going to machine up some bungs and move the mount point on the door. I'm using a 11.5" compressed, 19.5" extended 60lbs each. If anyone has done this mod let me know. Posted via Mobile Device |
02-14-2013, 08:33 PM | #2 |
Re: Lift gate slides to gas assist shocks
Thanks for this! I'm gonna put struts on my 63 and those cables are just what I need for the tailgate.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
02-18-2013, 09:06 PM | #3 |
What are the benefits of going with the struts and the cables, versus factory hardware?
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
02-19-2013, 11:02 AM | #4 |
The price.lol try finding a good pair of factory slides
02-19-2013, 04:30 PM | #5 |
Ah.
I've got a good pair, and another that could be good if straightened and given some lovin'. I'll have to think about what the final plan is going to be... I like the idea of being able to roll with the rear window open, if I'm hauling long 2x4s or something. If I'm not mistaken, the factor pieces lock in the upright position, don't they? -Brad
02-19-2013, 08:44 PM | #6 |
Chevy addict
You'll be surprised at what all comes in the open rear window at 60mph
02-19-2013, 09:50 PM | #7 | |
Judging on what's on my rear barn-doors, I'd say road grime, any fluids leaking off the bottom of the engine, trans or rear, and general crud. -Brad
02-21-2013, 03:08 PM | #8 |
Well I got the gas struts on but they don't open nearly as much as I want. I had to get shorter shocks and move one of the mounting points. The way our hinges open make the shock compress more in mid stroke then at full close. I'm going to figure out a different way to make it work.... In the future, not now.
02-22-2013, 09:24 AM | #9 |
I have car A.D.D.
Do you have any pictures? I'm curious about how you did it and where the door sits now.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
02-27-2013, 11:08 PM | #10 |
Any updates to this?
I just picked up a clean 66 Burb and would like to do his conversion to mine. Also, what are you using for a latch? Is there an adjustment procedure to get this thing to stay closed? Any help would be appreciated Posted via Mobile Device |
04-15-2013, 08:12 AM | #11 |
very interested in this procedure please send updates and parts used
09-24-2013, 05:18 PM | #12 |
Same here, trying to convert mine but need some guidance
09-24-2013, 06:32 PM | #13 |
I am looking for some junk rear window slides with good mounting brackets on each end. I found a bunch of slides that are exact dimension but have the wrong brackets riveted on them. I will get some pics. Jim
10-02-2013, 01:21 PM | #14 |
I just did this but the struts wouldnt fit in the jamb ,so i went to camper supply and bought some balls already mounted on l brackets mounted them on inside there exposed when closed but work great if you pm me your ph# i can send you pics could not down load not real computer savy
10-09-2013, 05:02 PM | #15 |
Sorry guys I didn't see all the responses to my post. The shocks I got do not open up my hatch enough. The pivot point needs to be moved higher on the hatch. In order to do that the hatch needs to be clearenced so the shock will fit in when closed. Check out the pics of the suburban Roadster Shop was building.
12-10-2014, 02:04 PM | #16 |
Ephesians 2:8
I started on mine just last night. Only got one side done. Still waiting on second Rod to ship...
I had to push it up the last 2 inches or so, I think the second strut will take care of that though. Click on photo for a video
72 Suburban making it mine My 79 C10 story 79 C10 LS swap 94 LS swapped Daily Driver Tahoe Limited Instagram - @piersonclassics 83 K20 Farm Truck Build |
12-12-2014, 11:12 PM | #17 |
