Old 02-19-2013, 11:00 AM   #1
aggie91
I'm just glad to be here!
aggie91's Avatar
Brake Master Cylinder Selection
I am putting together my son's truck and need advice on what size master cylinder to use. I would like to use the stock '82 power booster, but I am not committed to that. If there is a good kit with the booster and master, then I would be open to get that.
Our brake set up is this:
Front, Corvette C5 two piston calipers with 13" discs.
Rear, Corvette C5 single piston caliper with 12" discs with mechanical parking brake.
What bore size should I use for the master cylinder? I want to keep power brakes for this truck. If I decide later to upgrade to a hydroboost system, can I use the same master cylinder?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-20-2013, 09:20 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Brake Master Cylinder Selection
Found this on the internet about c5 brakes in a 1st gen Camaro.
I think some of the same thinking would apply.
http://www.camaros.net/forums/showthread.php?t=163007
Anyone else have first hand knowledge of C5 brakes?
You might contact member way2lo2.
Keith
Convert to disc brakes.
Old 02-21-2013, 10:30 AM   #3
aggie91
aggie91's Avatar
Thanks, Keith.
I will call Borris, he is the one I got my front set up from.
Karl
The LST Challenge:
brakes, corvette, master cylinder
