Old 03-04-2013, 01:39 AM   #1
azdude1964
azdude1964's Avatar
My 64 copperhead
Here is my 1964 prostreet version of copperhead. 496 bbc efi. th350 narrowed 9 52" WIDE.15x 14 with 4.5 backspace. ccp mod spindles coilover rear . custom oak bed and fuel cell. gonna build a stainless tank soon.
efi 496bbc th350 custom brakes narrowed 9 coilover rear.
azdude1964 is offline   Reply With Quote
Old 03-04-2013, 01:48 AM   #2
azdude1964
azdude1964's Avatar
Re: My 64 copperhead
here some more pics. interior and rear disc with e brake.
Old 03-04-2013, 01:51 AM   #3
azdude1964
azdude1964's Avatar
this is the last pic truck is almost done..I'll get a better pic up soon.
Old 03-04-2013, 08:43 AM   #4
kgmunro
Awesome!
kgmunro is offline   Reply With Quote
Old 03-04-2013, 10:30 AM   #5
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Nice truck... nice job..
Where is the hood??
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 03-04-2013, 12:11 PM   #6
1963c-10
1963c-10's Avatar
Welcome....Great looking truck. For those of us doing big block conversions....what frame mods did you do and what headers/exhaust did you run? I see you did some firewall work also.
1964 Short bed trailer
Old 03-05-2013, 01:06 AM   #7
azdude1964
azdude1964's Avatar
cut the firewall and set it back 4 inch as for the frame notched the crossmember for exhaust.headers are for a 67-72 c10 hookers jet hot coated. custom motor mounts and trans crossmember. running a Ron Davis radiator.
Old 03-05-2013, 01:09 AM   #8
azdude1964
azdude1964's Avatar
here are some mods of the firewall.
Old 03-05-2013, 01:11 AM   #9
azdude1964
azdude1964's Avatar
pic of the firewall painted
Old 03-05-2013, 01:15 AM   #10
mud.man.rj
mud.man.rj's Avatar
Firewall doesn't look easy but looking at the truck was well worth it, perfect stance with my favorite engine, a Big block. We may need more pic's though, got us hooked now.
mud.man.rj is offline   Reply With Quote
Old 03-05-2013, 01:12 AM   #11
azdude1964
azdude1964's Avatar
i am going to start on another truck soon and will show all my work.
Old 03-05-2013, 01:21 AM   #12
azdude1964
azdude1964's Avatar
the hood is a up22 fiberglass hood needs a lot of work. it on the wall in one of the pics.
Old 03-06-2013, 01:19 AM   #13
Captainfab
60-66 Nut
Welcome to the forum
Very nice truck
Gotta love a tunnelramed big block.
Old 03-06-2013, 08:18 AM   #14
flips72
flips72's Avatar
truck is awesome, great work and welcome.
flips72 is offline   Reply With Quote
Old 03-06-2013, 04:24 PM   #15
azdude1964
azdude1964's Avatar
Old 03-06-2013, 06:20 PM   #16
66-PMD-GMC
66-PMD-GMC's Avatar
OK, I see it now.
I had one of those L88 hoods. I traded it for a factory 63-66 GMC hood that I liked better on my truck.
Like your truck dude.
Projects..
440CID 2X4 Pontiac
Old 03-06-2013, 07:26 PM   #17
azdude1964
azdude1964's Avatar
66-Pdm-gmc are you going to goodguys this week end?
Old 03-06-2013, 09:17 PM   #18
66-PMD-GMC
66-PMD-GMC's Avatar
No, I have a truck that needs to be done in 2 weeks so I need to work..
Projects..
440CID 2X4 Pontiac
Old 03-08-2013, 10:48 PM   #19
Bomp
Bomp's Avatar
Nice wild looking truck!
Bomp is offline   Reply With Quote
Old 03-10-2013, 06:45 PM   #20
flips72
flips72's Avatar
are you planning on racing the truck any, if so got any ideas what kind of times your looking for?
Old 03-11-2013, 12:50 AM   #21
azdude1964
azdude1964's Avatar
ill run it once in awhile engine makes 750 plus hp and700ft tq. will be foot braking it. so 10.40 or so i think. bomp your truck is gonna be so cool thanks everyone for the feed back.
Old 04-01-2013, 09:55 AM   #22
66-PMD-GMC
66-PMD-GMC's Avatar
Why was it necessary to set the firewall back?
Was it clearance issues or were you only trying to improve balance in the truck?
I have a big block mocked up on a cab and chassis and it seems to fit fine..
But it is looking a little nose heavy.
Any words of advice?
Projects..
440CID 2X4 Pontiac
Old 04-01-2013, 11:36 AM   #23
azdude1964
azdude1964's Avatar
The reason was so i could put the bbc where the sbc goes .also really just widen it for the ablity to take the valve covers off and more access to the back of the engine. was able to use headers for 67-72 bbc hooker. hope this helped.p.s.first firewall was not to pretty so redid it second one is the way to go .use 16 ga, cold rolled. i.e painted one
Old 04-01-2013, 11:40 AM   #24
azdude1964
azdude1964's Avatar
also aloud me to run dual fans and a serp drive system.
Old 04-01-2013, 12:43 PM   #25
66-PMD-GMC
66-PMD-GMC's Avatar
OK,
I have the motor mount frame brackets from a 72 GMC that was originally a big block truck.
The brackets and cross member are being used in a 65 build.
(I am also using the 72 frame)
The brackets are different than small block brackets I have here as I compared them side by side.
They allow the motor to sit lower and back.
I had it all mocked up and didn't notice any clearance issues before taking it apart again.
I will check clearance again once I get the cab back on the frame but I really like how your firewall came out so if things are too tight I may just copy your design.
Projects..
440CID 2X4 Pontiac
