04-17-2013, 08:48 PM | #1 |
Replacing rear window on 1952 1/2 ton
I have purchased a new peice of glass as well as the seal for the rear of my 1952 Chevy truck. I have read several threads regarding replacing this window but none of them state if a sealer is used on the seal or not? The new seal comes with the chrome bead lock, is this enough or should i be setting it with some 3M sealant? Thanks in advance..
04-17-2013, 09:33 PM | #2 |
Re: Replacing rear window on 1952 1/2 ton
I put mine in two weekends ago.
I soaped up the seal and installed it, then worked the glass in with a body filler squeege. Once it was in, I went inside the cab and put that bead lock in. After it was all said and done, it fit incredibly snug, but I still will run a light sealer around it just to give me a little insurance. I will be doing this with the front glass too. Posted via Mobile Device
"Dixie" - 1988 Chevrolet V30 CC DRW "3+3" | 7.4L 454 (L19) | TH400 | 4" lift | 35"s "Lucille" - 1949 Chevrolet 3100 (on hold) |
04-17-2013, 09:52 PM | #3 | |
Thanks for the input... I have changed many door and wing windows but this will be a first for this type of glass install. It seems to be very straight forward. Just like every other project.. the remove and replace is smallest part of the job.. I cant take anything apart with out cleaning sanding and painting which makes the job a week long project. |
04-17-2013, 11:39 PM | #4 | |
04-17-2013, 11:55 PM | #5 | |
Good luck. Posted via Mobile Device
04-18-2013, 02:01 AM | #6 | |
04-18-2013, 03:20 PM | #7 | |
You can do it without sealer too, like I mentioned in my first post, it gives me extra insurance on the leaks. I have a cross country trip coming up soon and I am not interested in having leaks.
12-03-2016, 03:10 PM | #8 |
Hey guys!
I just finished the 57 3100 vent and door windows, now ready to tackle the front and rear. I am sure I can do it, but are there any "special" tools I will need to do this? |
04-18-2013, 12:37 AM | #9 |
I've had mine in an out several times over the past 30 years and never put any sealer on it and have never had a leak except where the rubber shrank and the gap between the ends widened up. To clarify I used bulk window rubber from the local glass shop. The same stuff they use on a lot of farm equipment and heavy equipment.
04-18-2013, 06:53 AM | #10 |
Never seen one installed backwards but it can happen. The beadlocks go on the outside of the truck
04-18-2013, 12:03 PM | #11 |
I mounted mine with the lock bead on the inside of the cab beause I wanted a soomther look to the outside of the cab. I didn't see where it would really matter unless you were going for a 100% accurate restoration. I was not.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
04-18-2013, 03:18 PM | #12 |
Exactly why I did mine that way.
12-03-2016, 08:29 PM | #13 |
Here is a few great tools that are MUST in opinion.
http://www.hotrodders.com/forum/wind...ls-360386.html Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
